On Wed, 30 Aug 2006 22:40:01 -0400, "Gary Drescher"
wrote: "Bill Zaleski" wrote in message .. . FAR 61.57 (d) sets the requirements to act as PIC if (c) is not met. No, it asserts *a* requirement that has to be met if (c) is not met (or rather, if c has not been met for six months). It does not state that (c) must also be met. Of course not. Why should (d) reaffirm (c)? Or reaffirm any other FARs? The point is that nothing says that (c) *doesn't* still have to be met. In general, you're required to obey *every* regulation. You can't decide that because you're complying with one, you can ignore another one (unless the wording explicitly says that). (d) is the controlling paragraph for one out of currency, not (c). There's nothing in the FARs that says (c) doesn't apply too. (d) takes over and stands alone. But it doesn't say that anywhere in the FARs. This is how it was explained to me. Did the explainers say how they arrived at their interpretation that (d) sets forth a substitute requirement rather than an additional requirement? If so, would you tell us their explanation? If one can assume that 6 approches are also needed, then the verbiage of (d) could also be construed to mean that you must be 6 months out of currency in order to do an IPC. How would that follow? Where does (d) say that? There are questions in the instrument knowledge test question pool whose correct answers support this. The faq's, that by letter of memorandum were once stated as FAA policy, used to support this. Advisory Circular 61-98A, although out of date, supports this. It may well be that the FAA takes that position. All I'm saying is that if so, they're contradicting what the FARs clearly state. --Gary Yes, the FAR's are clear here, if you read the paragraph that applies to what you are seeking. How much simpler can it be than to read the titles of (c) and (d) (c) Instrument experience: This is what you have to do to determine your current state of required instrument experience. This is all it addresses and nothing more. IF you decide that you are not current, you are done with this paragraph and it does not apply to you any longer (for the moment). Go to paragraph (d) for further guidance. (d) IPC: This is what you have to look at and do to GET current, depending on whether you are out of currency by more than 6 months, (IPC), or less than six months, (do the damn approaches OR do an IPC anyway). It says "a person who does not meet (c)", can't be PIC until you do the stuff spelled out in (d), (not necessarily the paragraph (c) stuff, unless you qualify). If you are doing an IPC, you are not bound by the requirements of (c) or it would be included in the verbage. This refers you back to (c), but only gives relief via approaches if you are within 6 months of your last currency, and provides the option of completing the 6 approaches. It is the guideline for getting current, and the IPC does not mandate anything outside of the task table in the Instrument PTS. Although it doesn't state so, an IPC is ALWAYS an option, regardless of currency status, Paragraph (d) is clearly relief from paragraph(c) via the IPC route alone. It in no way suggests that you have to do both. Since I am always willing to listen and learn, let me pose this to the logic that applies to intrepretation of the FAR's. Is it a violation of 91.126 (b) (1) when you make a right turn to join a left downwind from a 45 degree entry? Strict interpretation says yes, common sense says no. |
... (c) Instrument experience: This is what you have to do to determine your current state of required instrument experience. This is all it addresses and nothing more. IF you decide that you are not current, you are done with this paragraph and it does not apply to you any longer (for the moment). Of course it still applies. It applies by saying you can't be PIC under IFR or IMC. And it keeps saying that as long as you haven't completed six approaches within the past six months. The whole crux of our disagreement is that you keep repeating that (c) stops applying at some point, but you don't say *why* you think it stops applying. That is, you don't cite any wording in the FARs saying that (c) stops applying. (d) IPC: This is what you have to look at and do to GET current, It's *one* of the things you have to do in order to be PIC under IFR or IMC. Nothing says that all the *other* requirements don't still apply. For instance, you'd still have to be medically qualified/certified, even though (d) doesn't explicitly reaffirm that requirement. You agree with *that*, don't you? So why don't you agree that the requirement in (c) also still applies? It says "a person who does not meet (c)", can't be PIC until you do the stuff spelled out in (d), Almost. It refers to a person who does not meet (c) *and* who has not done so for six months. Let's say you're such a person. So now (d) says that if you *don't* do the stuff in (d), you can't be PIC in IFR/IMC. But it never says that if you *do* the stuff in (d), you can be PIC in IFR/IMC without *also* meeting all *other* stated requirements (for example, the medical requirement, or the six-in-six requirement). No requirement is waived unless the wording *says* it's waived. Paragraph (d) is clearly relief from paragraph(c) via the IPC route alone. It in no way suggests that you have to do both. Of course it doesn't say you have to do both, just like it doesn't say you have to have a medical certificate. Those requirements are stated *elsewhere*, and there's no need for (d) to repeat or reaffirm them. But (d)--like any other regulatory paragraph--applies *in addition* to all the other stated requirements, unless there's wording that specifically waives those requirements. And there isn't. (Again, I'm just addressing what the FARs actually say, which can be different from how the FAA interprets or enforces them.) --Gary |
On Thu, 31 Aug 2006 10:13:23 -0400, "Gary Drescher"
wrote: "Bill Zaleski" wrote in message .. . (c) Instrument experience: This is what you have to do to determine your current state of required instrument experience. This is all it addresses and nothing more. IF you decide that you are not current, you are done with this paragraph and it does not apply to you any longer (for the moment). Of course it still applies. It applies by saying you can't be PIC under IFR or IMC. And it keeps saying that as long as you haven't completed six approaches within the past six months. The whole crux of our disagreement is that you keep repeating that (c) stops applying at some point, but you don't say *why* you think it stops applying. That is, you don't cite any wording in the FARs saying that (c) stops applying. (d) IPC: This is what you have to look at and do to GET current, It's *one* of the things you have to do in order to be PIC under IFR or IMC. Nothing says that all the *other* requirements don't still apply. For instance, you'd still have to be medically qualified/certified, even though (d) doesn't explicitly reaffirm that requirement. You agree with *that*, don't you? So why don't you agree that the requirement in (c) also still applies? It says "a person who does not meet (c)", can't be PIC until you do the stuff spelled out in (d), Almost. It refers to a person who does not meet (c) *and* who has not done so for six months. Let's say you're such a person. So now (d) says that if you *don't* do the stuff in (d), you can't be PIC in IFR/IMC. But it never says that if you *do* the stuff in (d), you can be PIC in IFR/IMC without *also* meeting all *other* stated requirements (for example, the medical requirement, or the six-in-six requirement). No requirement is waived unless the wording *says* it's waived. Paragraph (d) is clearly relief from paragraph(c) via the IPC route alone. It in no way suggests that you have to do both. Of course it doesn't say you have to do both, just like it doesn't say you have to have a medical certificate. Those requirements are stated *elsewhere*, and there's no need for (d) to repeat or reaffirm them. But (d)--like any other regulatory paragraph--applies *in addition* to all the other stated requirements, unless there's wording that specifically waives those requirements. And there isn't. (Again, I'm just addressing what the FARs actually say, which can be different from how the FAA interprets or enforces them.) --Gary I have explained it to you exactly as it was explained to me by FAA personel at the top of the regulatory chain. I understand it and accept it. Do what you please. |
... I have explained it to you exactly as it was explained to me by FAA personel at the top of the regulatory chain. Sure, and I'm not disputing the accuracy of your report of what they said. I just wanted to know if they ever explained how they get from what 61.57d says (long-lapsed currency *not* reestablished *unless* IPC) to their interpretation that an IPC *alone* suffices to reestablish long-lapsed currency. Your report confirms that, as I expected, they asserted their interpretation without ever justifying it. --Gary |
Turn it around...
example 61.57 a. No pilot may my fly under IFR or in conditions less than basic VFR unless they have passed an IPC. b. Not withstanding a., if the pilot has flown 6 hours and 6 approaches within the previous 6 calendar months the IPC need not be completed. Gary, we have been doing this IFR thing for over 30 years and we have taken many checkrides from the FAA for part 141 and 135 [and other parts] and this is a question that is always covered. The IPC replaces the 6 and 6. Every IPC starts the 6 month clock again. "Gary Drescher" wrote in message . .. | "Bill Zaleski" wrote in message | ... | (c) Instrument experience: This is what you have to do to determine | your current state of required instrument experience. This is all it | addresses and nothing more. IF you decide that you are not current, | you are done with this paragraph and it does not apply to you any | longer (for the moment). | | Of course it still applies. It applies by saying you can't be PIC under IFR | or IMC. And it keeps saying that as long as you haven't completed six | approaches within the past six months. | | The whole crux of our disagreement is that you keep repeating that (c) stops | applying at some point, but you don't say *why* you think it stops applying. | That is, you don't cite any wording in the FARs saying that (c) stops | applying. | | (d) IPC: This is what you have to look at and do to GET current, | | It's *one* of the things you have to do in order to be PIC under IFR or IMC. | Nothing says that all the *other* requirements don't still apply. For | instance, you'd still have to be medically qualified/certified, even though | (d) doesn't explicitly reaffirm that requirement. You agree with *that*, | don't you? So why don't you agree that the requirement in (c) also still | applies? | | It says "a person who does not meet (c)", can't be PIC | until you do the stuff spelled out in (d), | | Almost. It refers to a person who does not meet (c) *and* who has not done | so for six months. Let's say you're such a person. So now (d) says that if | you *don't* do the stuff in (d), you can't be PIC in IFR/IMC. But it never | says that if you *do* the stuff in (d), you can be PIC in IFR/IMC without | *also* meeting all *other* stated requirements (for example, the medical | requirement, or the six-in-six requirement). No requirement is waived unless | the wording *says* it's waived. | | Paragraph (d) is clearly relief from paragraph(c) via the IPC route | alone. It in no way suggests that you have to do both. | | Of course it doesn't say you have to do both, just like it doesn't say you | have to have a medical certificate. Those requirements are stated | *elsewhere*, and there's no need for (d) to repeat or reaffirm them. But | (d)--like any other regulatory paragraph--applies *in addition* to all the | other stated requirements, unless there's wording that specifically waives | those requirements. And there isn't. | | (Again, I'm just addressing what the FARs actually say, which can be | different from how the FAA interprets or enforces them.) | | --Gary | | |
"Jim Macklin" wrote in message
news:JvDJg.6481$SZ3.2118@dukeread04... Turn it around... example 61.57 a. No pilot may my fly under IFR or in conditions less than basic VFR unless they have passed an IPC. b. Not withstanding a., if the pilot has flown 6 hours and 6 approaches within the previous 6 calendar months the IPC need not be completed. Yes, that would be totally different. In your hypothetical rewriting of the FARs, the second clause explicitly states an *exception* to a requirement ("need not be completed"). But in the *actual* wording, the second clause instead explicitly states a *requirement* ("may *not* serve *unless*"). That's been my point all along: you're trying to construe a *requirement* as an *exception to other requirements*, but the wording doesn't express an exception. Your hypothetical rewriting is actually a good illustration of how an exception would be worded; that wording is precisely what's missing from the actual FARs in question. Gary, we have been doing this IFR thing for over 30 years and we have taken many checkrides from the FAA for part 141 and 135 [and other parts] and this is a question that is always covered. As I have explained many, many times, that just tells us what the FAA's position is. But I've never disputed what their position is. I just maintain that their position does not match what the FARs say. Nothing about your 30 years of experience addresses *that* question. Rather, that question is addressed by analyzing the wording of the FARs, as I have done here in detail. --Gary |
Then I suggest that you write the FAA and your congressman
to require that the FAA clarify, in the regulations, what has been the regulation, policy and interpretation of FAR 61.57, so that you're pleased with the resulting text. Understand that nothing will change, just an expenditure of a few $100,000 for public hearings, and printing. "Gary Drescher" wrote in message . .. | "Jim Macklin" wrote in message | news:JvDJg.6481$SZ3.2118@dukeread04... | Turn it around... | example 61.57 a. No pilot may my fly under IFR or in | conditions less than basic VFR unless they have passed an | IPC. | | b. Not withstanding a., if the pilot has flown 6 hours and 6 | approaches within the previous 6 calendar months the IPC | need not be completed. | | Yes, that would be totally different. In your hypothetical rewriting of the | FARs, the second clause explicitly states an *exception* to a requirement | ("need not be completed"). But in the *actual* wording, the second clause | instead explicitly states a *requirement* ("may *not* serve *unless*"). | | That's been my point all along: you're trying to construe a *requirement* as | an *exception to other requirements*, but the wording doesn't express an | exception. Your hypothetical rewriting is actually a good illustration of | how an exception would be worded; that wording is precisely what's missing | from the actual FARs in question. | | Gary, we have been doing this IFR thing for over 30 years | and we have taken many checkrides from the FAA for part 141 | and 135 [and other parts] and this is a question that is | always covered. | | As I have explained many, many times, that just tells us what the FAA's | position is. But I've never disputed what their position is. I just maintain | that their position does not match what the FARs say. Nothing about your 30 | years of experience addresses *that* question. Rather, that question is | addressed by analyzing the wording of the FARs, as I have done here in | detail. | | --Gary | | |
On Thu, 31 Aug 2006 13:43:51 -0500, "Jim Macklin"
wrote: Then I suggest that you write the FAA and your congressman to require that the FAA clarify, in the regulations, what has been the regulation, policy and interpretation of FAR 61.57, so that you're pleased with the resulting text. Understand that nothing will change, just an expenditure of a few $100,000 for public hearings, and printing. Jim: I am done now giving free ground school. How about you? "Gary Drescher" wrote in message ... | "Jim Macklin" wrote in message | news:JvDJg.6481$SZ3.2118@dukeread04... | Turn it around... | example 61.57 a. No pilot may my fly under IFR or in | conditions less than basic VFR unless they have passed an | IPC. | | b. Not withstanding a., if the pilot has flown 6 hours and 6 | approaches within the previous 6 calendar months the IPC | need not be completed. | | Yes, that would be totally different. In your hypothetical rewriting of the | FARs, the second clause explicitly states an *exception* to a requirement | ("need not be completed"). But in the *actual* wording, the second clause | instead explicitly states a *requirement* ("may *not* serve *unless*"). | | That's been my point all along: you're trying to construe a *requirement* as | an *exception to other requirements*, but the wording doesn't express an | exception. Your hypothetical rewriting is actually a good illustration of | how an exception would be worded; that wording is precisely what's missing | from the actual FARs in question. | | Gary, we have been doing this IFR thing for over 30 years | and we have taken many checkrides from the FAA for part 141 | and 135 [and other parts] and this is a question that is | always covered. | | As I have explained many, many times, that just tells us what the FAA's | position is. But I've never disputed what their position is. I just maintain | that their position does not match what the FARs say. Nothing about your 30 | years of experience addresses *that* question. Rather, that question is | addressed by analyzing the wording of the FARs, as I have done here in | detail. | | --Gary | | |
Yes, you can lead a horse to water, but you can't make him
learn. Or, don't waste your time teaching a pig to sing, it annoys the pig and wastes your time. "Bill Zaleski" wrote in message ... | On Thu, 31 Aug 2006 13:43:51 -0500, "Jim Macklin" | wrote: | | Then I suggest that you write the FAA and your congressman | to require that the FAA clarify, in the regulations, what | has been the regulation, policy and interpretation of FAR | 61.57, so that you're pleased with the resulting text. | Understand that nothing will change, just an expenditure of | a few $100,000 for public hearings, and printing. | | | Jim: I am done now giving free ground school. How about you? | | "Gary Drescher" wrote in message | ... | | "Jim Macklin" wrote | in message | | news:JvDJg.6481$SZ3.2118@dukeread04... | | Turn it around... | | example 61.57 a. No pilot may my fly under IFR or in | | conditions less than basic VFR unless they have passed | an | | IPC. | | | | b. Not withstanding a., if the pilot has flown 6 hours | and 6 | | approaches within the previous 6 calendar months the IPC | | need not be completed. | | | | Yes, that would be totally different. In your hypothetical | rewriting of the | | FARs, the second clause explicitly states an *exception* | to a requirement | | ("need not be completed"). But in the *actual* wording, | the second clause | | instead explicitly states a *requirement* ("may *not* | serve *unless*"). | | | | That's been my point all along: you're trying to construe | a *requirement* as | | an *exception to other requirements*, but the wording | doesn't express an | | exception. Your hypothetical rewriting is actually a good | illustration of | | how an exception would be worded; that wording is | precisely what's missing | | from the actual FARs in question. | | | | Gary, we have been doing this IFR thing for over 30 | years | | and we have taken many checkrides from the FAA for part | 141 | | and 135 [and other parts] and this is a question that is | | always covered. | | | | As I have explained many, many times, that just tells us | what the FAA's | | position is. But I've never disputed what their position | is. I just maintain | | that their position does not match what the FARs say. | Nothing about your 30 | | years of experience addresses *that* question. Rather, | that question is | | addressed by analyzing the wording of the FARs, as I have | done here in | | detail. | | | | --Gary | | | | | | |
to require that the FAA clarify, in the regulations... Be careful what you wish for. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
GNS480 missing some LPV approaches | Dave Butler | Instrument Flight Rules | 1 | October 27th 05 02:24 PM |
FS2004 approaches, ATC etc | henri Arsenault | Simulators | 14 | September 27th 03 12:48 PM |
Logging instrument approaches | Slav Inger | Instrument Flight Rules | 33 | July 27th 03 11:00 PM |
Garmin Behind the Curve on WAAS GPS VNAV Approaches | Richard Kaplan | Instrument Flight Rules | 24 | July 18th 03 01:43 PM |
