In article 9rrJg.24072$W01.11777@dukeread08, "Mark Manes"
wrote: Mode S has several advantages. ATC interrogation pulses can be directed to a specific aircraft or all Mode S aircraft. I know the advantages from an ATC POV, but what is the advantage for the aircraft owner? -- Bob Noel Looking for a sig the lawyers will hate |
Bob Noel schrieb:
I know the advantages from an ATC POV, but what is the advantage for the aircraft owner? To be allowed to fly in controlled airspace at all? In Europe, Mode S will be mandated, because ATC claims Mode C reaches its limits. This means in the forseeable futu No Mode S, no fly in controlled airspace. Stefan |
On Thu, 31 Aug 2006 12:52:11 +0200, Stefan
wrote in : Bob Noel schrieb: I know the advantages from an ATC POV, but what is the advantage for the aircraft owner? To be allowed to fly in controlled airspace at all? In Europe, Mode S will be mandated, because ATC claims Mode C reaches its limits. This means in the forseeable futu No Mode S, no fly in controlled airspace. Would that Mode S requirement be a result of the implement ion of outsource ATC? |
Larry Dighera schrieb:
Would that Mode S requirement be a result of the implement ion of outsource ATC? No, why should it? Mode S implementation is very expensive for ATC. It's as I said: They say that in certain regions iof Europe, Mode C reaches its limits. As I don't know anything about it, I have to believe it. From http://www.eurocontrol.int/msa/public/faq/faq.html: Mode S is being deployed because the current SSR systems have reached the limit of their operational capability. This takes the form of exceeded maximum number of targets, RF pollution, lost targets, identity errors and Mode A code shortage. Mode S is therefore a necessary SSR replacement in airspace subject to high levels of traffic density. Stefan |
On Thu, 31 Aug 2006 16:47:21 +0200, Stefan wrote:
Mode S is being deployed because the current SSR systems have reached the limit of their operational capability. This takes the form of exceeded maximum number of targets, RF pollution, lost targets, identity errors and Mode A code shortage. Mode S is therefore a necessary SSR replacement in airspace subject to high levels of traffic density. I've some difficulty understanding this. From reading here, I've been lead to believe that aviation is more common in the US than in the EU. Given this, I have to assume that a locality like the KEWR/KLGA/KJJK area would have a higher aircraft density than anywhere in Europe. No? If so, then how can a locality like that not be suffering from the same problem as that described in the cited text? I fly in this area, and I've never noted identity errors nor have I ever been denied service due to an insufficiency of mode A codes. - Andrew |
Andrew,
If so, then how can a locality like that not be suffering from the same problem as that described in the cited text? Excellent question. That's why many have doubts about Eurocontrol's claims. But it's all too late... -- Thomas Borchert (EDDH) |
Andrew Gideon schrieb:
I've some difficulty understanding this. From reading here, I've been lead to believe that aviation is more common in the US than in the EU. Given this, I have to assume that a locality like the KEWR/KLGA/KJJK area would have a higher aircraft density than anywhere in Europe. No? Frankly, I don't know. No doubt there will be some spam can drivers who know as little as I do about ATC who will tell you that the specialists at Eurocontrol have no clue, that everything is better elsewhere and that Eurocontrol's agenda is to stop all aviation in Europe anyway... an attitude which is pretty much en vogue right now. I'm somewhat untypical as I don't share this attitude. I frankly admit that I don't know enough to judge their claim, so I have to believe it. I don't believe that Eurocontrol is just a bunch of idiots and sadists. Nonetheless some thoughts: The primary concern is not the number of transponder codes. It's the fact that when lots of transponders which are located near each other (angle wise) respond simultaneously, the system breaks down. I don't have the exact numbers handy, but there is a discrimination limit. And there have already been reports of lost targets. (No, I won't go through the hassle to dig the report out, so you can choose to believe or not believe in my memory.) There are some parts in Europe which are surprisingly congested, and the airspace in those parts tends to be extremely complex. Maybe Europeans just care more about such lost targets than Americans? And then, they are not saying that the traffic has already exceeded their capacity. They say it will reach its limits soon. I think it's a responsible move to try to proactively solve the problem before the system breaks down. Stefan |
wrote in : Larry Dighera schrieb: Would that Mode S requirement be a result of the implemention of outsource ATC? No, why should it? Because the corporation providing ATC services under contract to the government(s) thinks it's a good idea? Mode S implementation is very expensive for ATC. Perhaps the ATC contractor can get the funds necessary to implement Mode S equipment installation from the government(s), and then use the added functionality provided by Mode S to enhance their revenue stream in the future. It's as I said: They say that in certain regions iof Europe, Mode C reaches its limits. As I don't know anything about it, I have to believe it. Either believe it, or do the research necessary to verify the allegation. From http://www.eurocontrol.int/msa/public/faq/faq.html: Mode S is being deployed because the current SSR systems have reached the limit of their operational capability. This takes the form of exceeded maximum number of targets, RF pollution, lost targets, identity errors and Mode A code shortage. Mode S is therefore a necessary SSR replacement in airspace subject to high levels of traffic density. Can European airspace possibly be more congested than that in the US, say Chicago or Los Angeles? |
No, why should it? Because the corporation providing ATC services under contract to the government(s) thinks it's a good idea? Obviously, they do. Either believe it, or do the research necessary to verify the allegation. In this particular case, I choose to believe it. You can handle it als you want. Stefan |
Larry Dighera wrote: Can European airspace possibly be more congested than that in the US, say Chicago or Los Angeles? Enroute? yeah, I think so. -- Bob Noel Looking for a sig the lawyers will hate |
18 Oct 2005 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | October 19th 05 02:19 AM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
