Hawker vs. Glider Midair - with photo!
Old August 31st 06, 05:50 PM posted to rec.aviation.piloting,rec.aviation.soaring
Jim Vincent
Default Hawker vs. Glider Midair - with photo!
"alexy" wrote in message
"Kingfish" wrote:
Larry Dighera wrote:
-on. It seems far more likely that this
was not head on. From the glider's perspective the jet was an unmoving
object somewhere in the sky, while from the jet's perspective, the
glider was a moving object directly ahead.
Alex -- Replace "nospam" with "mail" to reply by email. Checked
infrequently.
If I read your logic, the jet is unmoving because it is in steady flight
(not circling), so it stays in one position relative to the glider. Whereas
the glider is circling and so moves back and forth to some extent. Well,
given the small diameter of a thermalling glider, I think for all intents,
the glider would have been effectively a small dot in the sky except for the
last seconds. The power pilot had some clues, but it is still darn
difficult to see other gliders sometimes. Heck, I've been in thermals where
the other glider never saw me.
Old September 1st 06, 01:13 AM posted to rec.aviation.piloting,rec.aviation.soaring
alexy
infrequently.
You're probably right. It just seemed to me that talk about how hard a
glider is to see head-on might not have been a relevant comment. And
given their relative speeds, without working the math, I'd guess that
the glider was probably at all times between the jet's 11:00 and 1:00,
while the jet might have been in front of, behind, or at any point to
the side of the glider.
Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently.
Old September 1st 06, 03:24 AM posted to rec.aviation.piloting,rec.aviation.soaring
Yuliy Gerchikov
"Jim Vincent" wrote in message
I think for all intents, the glider would have been effectively a small
dot in the sky except for the last seconds.
No, it's the Hawker that was a small (2 meters) motionless white dot in the
white sky. The thermalling glider was an 18-meter white cross moving against
the desert background.
The jet was descending, wasn't it? That means no soot trail. Which, I am
convinced, is the only part of the jet visible head-on from far enough to
have any practical chance at all to evade, at glider speed.
Yuliy
Hawker vs. Glider Midair - with photo! Darkwing Piloting 151 September 5th 06 05:19 PM
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
