![]() Ron Natalie wrote: There is NO SUCH RULE. FAR 91.113 http://www.airweb.faa.gov/Regulatory...C?OpenDocument (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories-- (1) A balloon has the right-of-way over any other category of aircraft; [(2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.] However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. |
5Z wrote:
Ron Natalie wrote: There is NO SUCH RULE. FAR 91.113 http://www.airweb.faa.gov/Regulatory...C?OpenDocument (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories-- (1) A balloon has the right-of-way over any other category of aircraft; [(2) A glider has the right-of-way over an airship, powered parachute, weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.] However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. THat clause applies only when coverging other than head-on or nearly so. Head-on (or nearly so) or overtaking operations has rules that are not affected by aircraft category. |
![]() Ron Natalie wrote: Head-on (or nearly so) or overtaking operations has rules that are not affected by aircraft category. But we are talking about airplanes running over gliders. That will most likely be a non headon situation, and in that case the airplane shall avoid the glider. Of course, that's just like saying the pedestrian has right of way in a crosswalk - some dopes think that stepping out in front of a car will somehow magically make 1) the driver notice them, 2) allow the driver to stop in time. -Tom |
![]() "5Z" wrote in message oups.com... Ron Natalie wrote: There is NO SUCH RULE. FAR 91.113 http://www.airweb.faa.gov/Regulatory...C?OpenDocument (d) Converging. When aircraft of the same category are converging at approximately the same altitude (except head-on, or nearly so), the aircraft to the other's right has the right-of-way. If the aircraft are of different categories-- (1) A balloon has the right-of-way over any other category of aircraft; [(2) A glider has the right-of-way over an airship, powered parachute, As long as the glider doesnt pull out in front of the other aircraft. There are no absolutes. If you are going the speed limit in a car and someone runs out in front of you its not always your fault. weight-shift-control aircraft, airplane, or rotorcraft. (3) An airship has the right-of-way over a powered parachute, weight-shift-control aircraft, airplane, or rotorcraft.] However, an aircraft towing or refueling other aircraft has the right-of-way over all other engine-driven aircraft. |
"Aluckyguess" wrote:
As long as the glider doesnt pull out in front of the other aircraft. Please explain the maneuver you have in mind here. How does a glider "pull out in front of" a biz jet? Maybe after overtaking him?g -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
Hawker vs. Glider Midair - with photo! | Darkwing | Piloting | 151 | September 5th 06 05:19 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
