Preserving Epoxy (Epoxicles ???)
Old August 31st 06, 11:44 PM posted to rec.aviation.homebuilt
Morgans[_4_]
Default Preserving Epoxy (Epoxicles ???)
"T o d d P a t t i s t" wrote
Pull the bag out,
squeeze out air, close it, knead the two components
together, use a pencil to push all the mixed epoxy to one
corner, snip off that corner and apply like a frosting bag -
the bigger the snipped corner the more you can apply
quickly. Tiny jobs use tiny snips.
Nice trick! I can guarantee that I will be using that method in the future!
g
Thanks!
Jim in NC
Old September 1st 06, 09:18 PM posted to rec.aviation.homebuilt
Evan Carew
Orval Fairbairn wrote:
In article .com,
"steveukman" wrote:
I am seeking advice about mixing and storing epoxy.
This also works on epoxy primers, and, to a limited extent, 2-part
polyurethane paints. I would imagine that it also works on fuel tank
sealants.
Freezing slows down the chemical reaction and greatly extends pot life.
Its been a while since I took organic chem, but I seem to remember a
rule of thumb that said organic reactions slow down by half every 2
degrees C lower you take them.
Old September 1st 06, 09:22 PM posted to rec.aviation.homebuilt
Evan Carew
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dennis Johnson wrote:
"steveukman" wrote in message
For 15 bucks you can buy an electronic scale on EBay with an accuracy of a
tenth of a gram that will allow you to mix tiny batches of epoxy.
Personally, I wouldn't feel comfortable with using previously frozen, mixed
epoxy for an airplane unless the epoxy manufacturer okayed it, but I'm a
coward. My advice is to get an accurate scale and only mix as much as you
need.
Remember, prepreg is purchased frozen & kept in a cooler until needed.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
iD8DBQFE+JadpxCQXwV2bJARAoZNAKCKBSpwiyfp1kqy6PACMw 3SYMGlugCgpJ2p
rN2zDFhC5XKnxaYb5hlIdDU=
=dNQi
-----END PGP SIGNATURE-----
Epoxy for Fuel Tanks Doug Palmer Home Built 1 April 12th 06 02:53 AM
Dupont Corlar epoxy primer? [email protected] Home Built 1 May 18th 05 07:30 PM
Epoxy Bonding to Aluminum and Magnesium Ryan Young Home Built 25 September 16th 04 02:45 AM
Question about epoxy resin chemistry.. Chris Home Built 26 April 15th 04 12:55 AM
