primary flight instruments on partial panel
Old August 28th 06, 05:51 PM posted to rec.aviation.ifr
Ronnie
Default primary flight instruments on partial panel
Greg,
From the Instrument Flying Handbook in the primary / supporting
method, the primary instrument is the one that provides a direct
indication of the parameter you are trying to control.
Therefore, compass would be considered the primary heading
instrument in partial panel for straight flight. If you are trying
to maintain a given heading, the compass is the primary instrument.
During a standard rate turn, you are trying to maintain the rate of
the turn. The turn coordiator or turn indicator becomes primary
during the turn.
From a practical point, the compass is difficult to interpret during
anything but straight and level flight. A ground track from a GPS
or Loran provides a good substitute for the DG during partial panel
situations. During partial panel, I tend to use the turn coordinator to
keep the wings level, ground track readout for heading info and timed
turns to make heading changes.
Ronnie
"Greg" wrote in message
In primary and supporting method of attitude instrument flying, which
do you consider the primary instrument for bank in the partial panel
situation (loss of both attitude indicator and heading indicator)?
Turn coordinator or magnetic compass?
thank you
Greg
greggordon.org/flying
Old August 28th 06, 06:21 PM posted to rec.aviation.ifr
Gary Drescher
"Ronnie" wrote in message
news
Greg,
Right, but Greg asked about the primary instrument for bank, not heading.
--Gary
during the turn.
Ronnie
thank you
Greg
Old September 1st 06, 04:18 AM posted to rec.aviation.ifr
Allan9
Years ago a FSDO/GADO Inspector pulled that one on me on a instrument flight
check.
Al
If you've got a good ADF you can tune in an AM broadcast station and
that makes a dandy DG replacement. Pick a station that's far enough
away that azimuth to the station is approximately constant but close
enough that you get a good strong signal. Not that most planes have
ADFs these days, and the ones that do exist tend to be pretty cruddy.
Stupid Question Crash Lander Piloting 35 July 23rd 06 02:39 AM
CRS: V-22 Osprey Tilt-Rotor Aircraft Mike Naval Aviation 0 October 14th 05 08:14 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
