Hawker vs. Glider Midair - with photo!
Old September 1st 06, 08:40 AM posted to rec.aviation.piloting,rec.aviation.soaring
Yuliy Gerchikov[_1_]
Default Hawker vs. Glider Midair - with photo!
"Ramy" wrote in message
Yuliy, I assume this is the degrees off center for the jet pilot,
Correct -- assuming the jet is flying straight. (Note that if glider is
manoeuvring at all, the angles are even less, i.e. closer to jet's 12
o'clock.)
BTW, remember the 26.5 degrees figure? One o'clock would be 30 degrees, of
course (...off-course).
what will it be for the glider pilot under similar conditions.
360, of course.
but sounds like we, as the slower aircraft, need much more
scanning then other faster aircrafts
Of couse, the faster aircrafts need to scan more for the faster aircrafts
yet...
Yuliy
Ramy
Yuliy Gerchikov wrote:
"Aluckyguess" wrote in message
How can a glider hit an airborne jet from the side? It can happen, but
the glider is well in front of the jet until the point of impact.
Good timing
Assuming glider Vne of 150 kts and jet speed of 300 kts, the widest
possible
azimuth angle from jet to glider is 26.5 degrees off center at any time
before impact (linear path).
At a more typical for a thermalling glider 60 kts this angle is reduced
to
11.3 degrees.
Which one do you call "from the side"?
Yuliy
  #122
Old September 1st 06, 09:02 AM posted to rec.aviation.piloting,rec.aviation.soaring
Montblack[_1_]
("Graeme Cant" wrote)
That's true for you and me. But the courts and the insurance companies
and the FAA will certainly find a way no matter how hard it is. They tend
to work at these things more persistently than you and I do.
"Insurance companies are the most religious people in America - everything
is an act of God."
The 'big sky' (at 16,000 ft.) wasn't big enough.
No fault to either pilot.
(Under 12,000 ft. is a different matter, in my book)
"Next case."
Montblack
  #123
Old September 1st 06, 12:00 PM posted to rec.aviation.piloting
[email protected][_1_]
On Thu, 31 Aug 2006 23:43:58 -0400, alexy wrote:
On Thu, 31 Aug 2006 16:17:59 -0400, "Morgans"
wrote
Did you hear about the one that survived the SAM strike?
No, but I would like to!
Basically, an African dignitary (president?) was riding along in a
Hawker escorted by at least one Angolan fighter.
Another Angolan fighter launched two heat-seekers at it.
Sounds like a different kind of SAM! g
  #124
Old September 1st 06, 12:01 PM posted to rec.aviation.piloting
DOH - sorry about that, engage brain before fingers...
mumble, mumble, mumble.
TC
  #125
Old September 1st 06, 01:22 PM posted to rec.aviation.piloting
Matt Barrow
"Grumman-581" wrote in message
On Fri, 01 Sep 2006 02:15:16 +1000, Graeme Cant
gcantinter@tnodedotnet wrote:
Like when I hit another car from behind, prima facie it's my fault.
Not always... I had an incident where that was not the case...
http://grumman581.googlepages.com/19...erokeesport4x4
Interesting story...and it holds even if the braking is not deliberate (such
as the close pull in/across and brake).
  #126
Old September 1st 06, 02:26 PM posted to rec.aviation.piloting,rec.aviation.soaring
Matt Barrow
Default Hawker vs. Glider Midair - random thoughts
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
I also knew that they had taken
off over gross on that flight, from things that I heard them say before
takeoff.
I'm curious, did they show you the W&B sheet for the flight? How did you
know they over gross?
Read!
  #127
Old September 1st 06, 02:38 PM posted to rec.aviation.piloting,rec.aviation.soaring
Gig 601XL Builder
"Matt Barrow" wrote in message
takeoff.
Read!
You are saying you heard the pilots say they were over gross? Or did they
just say they were heavy? If I heard two pilots say they were over gross I
think I'd get my ass off the plane.
  #128
Old September 1st 06, 03:34 PM posted to rec.aviation.piloting,rec.aviation.soaring
Matt Barrow
takeoff.
Read!
Not me, the OP.
Or did they just say they were heavy? If I heard two pilots say they were
over gross I think I'd get my ass off the plane.
Just before takeoff?
Hopefully the OP will clarify.
  #129
Old September 1st 06, 04:23 PM posted to rec.aviation.piloting,rec.aviation.soaring
snoop
GC, you may say "ALWAYS, but I like to say "never say never". Put your
lawyer hat back on for a second. What if, for the sake of discussion,
its 3 o'clock in the morning on a freeway, and you hit the guy on the
bike, having not seen him, until the last second? You the big car
driver have done everything right, but the bike did not make himself
seen, and he was on the freeway where he was not suppose to be. As
we've seen in all these threads, lots of variables to wade through.
Graeme Cant wrote:
Aluckyguess wrote:
It's no excuse to hitting a guy on a bike that you were in a big car
travelling very fast even if you were under the speed limit.
Not always.
ALWAYS, prima facie.
GC
GC
  #130
Old September 1st 06, 04:37 PM posted to rec.aviation.piloting
He glid.
He gled.
I've glodden in the past.
We will glod in the future.
He glid, she gled, we will glod. :-)
Best regards,
Jer/ "Flight instruction and mountain flying are my vocations!"
Jer/ (Slash) Eberhard, Mountain Flying Aviation, LTD, Ft Collins, CO
CELL 970 231-6325 EMAIL jeratfrii.com http://users.frii.com/jer/
C-206 N9513G, CFII Airplane&Glider FAA-DEN Aviation Safety Counselor
CAP-CO Mission&Aircraft CheckPilot BM218 HAM N0FZD 240 Young Eagles!
Midair near Minden Fred Soaring 52 September 1st 06 11:41 AM
Cloud Flying Shawn Knickerbocker Soaring 48 August 30th 06 07:21 AM
Refinish a Glider in Europe Jim Culp Soaring 0 November 18th 05 04:00 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
