G1000 vs Steam guages initial thoughts...
Old September 1st 06, 06:04 AM posted to rec.aviation.ifr
Default G1000 vs Steam guages initial thoughts...
I have just finished two concurent aircraft learning programs
1)Getting my instrument currency back.
doing some paractice, taking a IPC.
All done in a round dial 172.
2)Getting checked out in a G1000 182.
I've finished the King G1000 VFR and IFR course and spent about
6 hours in the G1000, I've also finished theG1000 182 VFR checkout.
Today we went up and did some IFR work in the G1000 182.
My prior three flights were doing some instrument practice in the
round dial 172.
I'd been doing quite well at mastering the G1000, but putting the
hood on at 700 ft in the G1000 was really hard after flying my IPC
yesterday in a round dial 172.
Holding altitude is hard the Altitude bug is too small and the rate of
climb indicator is such a different presentaion tha tI find it hard to
track.
I t feels like transitioning back and froth from G1000 to round dials
is going to be hard.
When one uses the autopilot in the G1000 182, everything is easier,
one has lots of time to think and the situational awareness is
awesome.
I'm begining to believe that 90% of this is the autopilot and that the
super G1000 integration is not that big of a benift.
The things I really like:
1)Rock solid autopilot.
2)The terrain display.
3)The big map situational awareness.
4)Traffic.
If one upgraded an airplane to
1)Good autopilot
2)Big screen GPS with traffic and terrain
3)HSI
I believe that you will have gaind 90% of the benifit of a G1000 at a
fraction of the cost
One could probably get 75% of the way there with an Autopilot S mode
xponder and Garmin 496.
Old September 1st 06, 01:09 PM posted to rec.aviation.ifr
Jim Macklin
The G1000 is less expensive for a airframe manufacturer to
install. The big screens and moving maps are easy to
interpret and getting lost in the middle of an approach will
be hard to do. [As long as it works]. But when you learn to
navigate with no dials or steam gauges, you train your mind
to act as a "moving map" and you know the situation.
The pilots who learn from zero time with a glass cockpit
will have to be cross trained in some way to use the windows
and a sectional, or their partial panel procedures will be
reduced to hoping radar vectors are available to an airport,
since even in VFR, they may not be able to navigate.
The solid state gyros are the best thing IMHO, the weakness
in the small GA airplanes is the poor sensitivity and
accuracy of the gyros and the small size of the displays.
If you get to fly a King Air class airplane, with a gyro
package and displays that cost more than a new G1000 Cessna
172, you'll see 5 or 6 inch AI and HSI, in a dual
[independent] panel. It is easy to control and steady.
There is real performance monitoring of the gyros, not just
a failure on the power flag.
programs
about
checkout.
in the
| round dial 172.
putting the
flying my IPC
the rate of
find it hard to
| track.
round dials
is easier,
awareness is
| awesome.
and that the
| 4)Traffic.
| 1)Good autopilot
| 3)HSI
G1000 at a
Autopilot S mode
Old September 1st 06, 01:41 PM posted to rec.aviation.ifr
Roy Smith
Once you've got all electronic data in one place like a G1000 does, I would
think it would fairly straight forward to do some basic data consistency
checking.
For example, if the AI says you're in a 10 degree nose-up attitude, but
airspeed is near the top of the green arc and increasing (and altitude is
decreasing), something has to be wrong. Likewise, if the AI says you're
wings level, but your heading keeps changing, something has to be wrong (I
know, you need to factor in the slip/skid data, but you've got that too).
It's all the same cross-check we learned to do in instrument training, but
done by a machine that never gets bored, distracted, or confused. It may
have other failure modes, but bordom, distraction, and confusion are not
among them. Those are reserved for the wetware.
Old September 1st 06, 01:43 PM posted to rec.aviation.ifr
Matt Barrow
"Jim Macklin" wrote in message
news:6mVJg.6550$SZ3.5989@dukeread04...
Something like this might be more better!
http://www.xbow.com/Products/product...ls.aspx?sid=59
Old September 1st 06, 01:47 PM posted to rec.aviation.ifr
Matt Barrow
"Matt Barrow" wrote in message
Too quick on the SEND button
I was wondering if these could replace the mechanical gyros even if you're
still running steam gauges?
Old September 1st 06, 03:32 PM posted to rec.aviation.ifr
Sam Spade
The G-1000 probably works best when you either use it exclusively or
have a lot of total time and experience in going back and forth.
Your idea of upgrading an airplance with a good autopilot, big screen
GPS with traffic and terrain, and HSI is a good option. But, the HSI
should be an electronic, slewable display, otherwise you have lost a lot
of the real benefit of the G-1000's nav data situational awareness.
And, those standalone electronic HSIs are expensive puppies.
I think I would still opt for the new G600, with the Garmin autopilot.
The AHRS alone is so much better than the lousy gyros light aircraft
have been using for years.
The Garmin autopilot is truly integrated with the avionics and will be
ready to do RF legs when they come along in a couple of years, or so.
round dial 172.
track.
awesome.
4)Traffic.
1)Good autopilot
3)HSI
Old September 1st 06, 04:11 PM posted to rec.aviation.ifr
Jim Macklin
I guess I'm an old fart, I think that making it so easy that
mental skills might degrade. Just as PC users get used to
having spell-check, G1000 users might become so dependent
and "lazy" that they would have real problem with a failure
of the G1000 and the comm. radios.
"Roy Smith" wrote in message
| "Jim Macklin"
weakness
displays.
Cessna
just
G1000 does, I would
data consistency
| checking.
attitude, but
(and altitude is
AI says you're
has to be wrong (I
got that too).
confused. It may
confusion are not
Old September 1st 06, 04:14 PM posted to rec.aviation.ifr
Jim Macklin
Looks like a good application, the system drives what type
of display, a mechanical or electronic?
| "Jim Macklin" wrote
in message
to
will
learn to
mind
weakness
displays.
Old September 1st 06, 04:16 PM posted to rec.aviation.ifr
Jim Macklin
You'd need ARNIC or remote AI and HSI, either mechanical or
electronic, that appears to be a cabin class piece of
equipment.
| "Jim Macklin"
to
will
learn to
mind
weakness
displays.
Old September 1st 06, 05:07 PM posted to rec.aviation.ifr
Robert Chambers
Probably microsoft under the covers.
| "Jim Macklin" wrote
in message
to
will
learn to
mind
weakness
displays.
IPC G1000 [email protected] Instrument Flight Rules 38 September 3rd 06 12:22 AM
Steam guages [email protected] Instrument Flight Rules 14 February 5th 05 04:58 AM
