Shadin Fuel flow
Old September 2nd 06, 12:49 AM posted to rec.aviation.owning
Stan Prevost[_1_]
Default Shadin Fuel flow
I owned a turbo Saratoga with a Shadin, and have flown a lot in another
identical airplane with a Shadin. Work fine. One strange thing in both
airplanes is that turning on the electric boost fuel pump causes a decrease
in the fuel flow indicated on the Shadin, by anywhere from 0.1 to 1.0 gph.
We spent a lot of effort in removing elbows, insulating the transducer and
fuel lines, relocating things, never changed it.
I always thought it was weird.
Stan
"Jim Burns" wrote in message
I'm currently in the process of obtaining quotes and researching Shadin's
DigiFlo-L fuel flow system. If there are any group members that have had
a
Shadin installed in their airplane, I'd love to hear from you.
My primary reason for choosing the Shadin over other fuel flow
meters/systems is that the Shadin is STC'd for primary replacement of our
Piper factory original fuel pressure type flow indicators. The original
fuel flow gauges actually have small fuel lines attached. 40 year old
copper fuel lines inside the cockpit do not make me especially
comfortable.
Shadin has been impossible to deal with concerning an install manual.
They
do not post them on their website and do not sell them without the unit.
I'd love to get a copy before I spend the money and throw this project
into
an A&P/AI's lap. If anybody can help me locate an install manual, I'd be
grateful.
Thanks,
Old September 2nd 06, 01:19 AM posted to rec.aviation.owning
Funny you should mention that,,, Mine does the exact same thing, but
it only happens at low powers settings like heading out to the active
while at taxi speed. Once airborne and making alot of power then the
readings are identical.
Ben
www.haaspowerair.com
Stan
Old September 2nd 06, 01:26 AM posted to rec.aviation.owning
Stan Prevost[_1_]
Mine did it at all power settings and altitudes.
Ben
decrease
gph.
and
Stan
Old September 2nd 06, 04:00 PM posted to rec.aviation.owning
Michelle P
Stan
a
comfortable.
They
into
grateful.
Thanks,
Stan,
Actually that makes sense. If you are pumping against the metering
device you will be initially raising the flow until the down stream
plumbing becomes "full". then things will slow down.
Michelle P
Old September 2nd 06, 06:07 PM posted to rec.aviation.owning
Stan Prevost[_1_]
"Michelle P" wrote in message
ink.net...
decrease in the fuel flow indicated on the Shadin, by anywhere from 0.1
to 1.0 gph. We spent a lot of effort in removing elbows, insulating the
transducer and fuel lines, relocating things, never changed it.
Stan
Stan,
Actually that makes sense. If you are pumping against the metering device
you will be initially raising the flow until the down stream plumbing
Michelle P
No, when I turn on the boost pump, thus increasing the fuel pressure to the
sensor and to the engine-driven pump, the flow indication decreases to a
new steady-state value until I turn it off, then it increases again to its
former steady-state indication. If I turn it on again, it decreases again.
Appears to be something unique to that sensor type since it does it in both
airplanes I fly that are equipped with the Shadin system.
Higher pressure giving lower flow indication is what is wierd. Actually, we
would like it to not change.
Old September 2nd 06, 10:53 PM posted to rec.aviation.owning
Dan Luke
the sensor and to the engine-driven pump, the flow indication decreases
to a new steady-state value until I turn it off, then it increases again
to its former steady-state indication. If I turn it on again, it
decreases again. Appears to be something unique to that sensor type since
it does it in both airplanes I fly that are equipped with the Shadin
system.
What kind of sensor is it? It's a turbine type, right?
we would like it to not change.
Interesting problem. Perhaps the higher static pressure is putting some
kind of friction load on the turbine shaft, maybe by deforming an o-ring
seal or some such.
Dan
C172RG at BFM
Old September 3rd 06, 01:26 AM posted to rec.aviation.owning
Stan Prevost[_1_]
"Dan Luke" wrote in message
It is a rotary sensor, but I'm not sure it is a turbine. Some type of
positive-displacement paddlewheel design.
seal or some such.
Something like that is all I could theorize, also. We suspected for a while
that we had bubbles giving abnormal high readings, and the increaed pressure
from the boost pump prevented the vapor bubble formation and thus lowered
the readings, but we did about everything that we could think of to
eliminate bubble formation, to no avail. I concluded it was the sensor
itself.
Why does fuel flow go UP when leaning on the ground? Roy Smith General Aviation 4 March 25th 06 01:27 AM
Arrow II fuel flow joe Owning 3 June 23rd 05 05:54 AM
Fuel Flow instrument Billc851 Home Built 18 March 19th 05 12:49 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
