Mxsmanic wrote:
Jim Logajan writes: details snipped Maybe someday the FAA and/or ICAO will consider replacing analog radios with a more capable digital system.... All very interesting, but one of the criteria that any new system would have to satisfy is that it would have to work in parallel with the existing system. Adding features to the new system that are not available in the old system would create dangerous differences between the two. Seeing fancy displays in the ATC or tower for the lucky digital users won't help deal with traffic from old AM users, and it might even confuse things enough to cause problems. A highly advanced solution would require replacing everything at once, which isn't going to happen. A simpler solution that just provides better quality audio could coexist with older systems without a problem. Analog AM and FM are fundamentally incompatible with each other. Analog AM and digital encoding over spread-spectrum are fundamentally incompatible with each other. You asked why AM is being used and not FM and all I'm pointing out is that if you are willing to consider any new system that is incompatible with an older system (like FM replacing AM), you may as well do it with something more advanced and capable, like digital packets over spread spectrum (which could be considered a relative to FM). One does _not_ need to implement any of the fancier capabilities that I mentioned. I stated them only as what could be easily done once the capability is in place. Analog cell phones are being replaced with digital cell phones, so I fully expect the same co-existence can be done with a changeover from analog aviation radio to digital radio. There would be no need to replace everything at once and I'm not sure why you think that would need to be the case. |
On Sat, 02 Sep 2006 21:06:47 -0000, Jim Logajan
wrote in : Analog cell phones are being replaced with digital cell phones, so I fully expect the same co-existence can be done with a changeover from analog aviation radio to digital radio. They operate on different frequency bands, so that is not a good analogy unless you can get the FCC to commit to allocating frequency spectrum for aviation use. There would be no need to replace everything at once and I'm not sure why you think that would need to be the case. Because it is unlikely the FCC will agree to allocate additional frequency spectrum for the proposed new communications system. |
Larry Dighera wrote:
Because it is unlikely the FCC will agree to allocate additional frequency spectrum for the proposed new communications system. The frequency allocation would need to be changed or added to on an international scope, so I believe the operative organizations would be the ITU and the ICAO or IATA - the FCC would simply enforce the change within the U.S. Like you, I would have thought new allocations or changed allocations would be hard, but changes are made every four years and in the GHz range they seem to been more readily done; e.g.: http://www.boeing.com/connexion/news...r_030707j.html |
Jim Logajan writes:
Analog AM and FM are fundamentally incompatible with each other. Not if they are on different frequencies. Analog AM and digital encoding over spread-spectrum are fundamentally incompatible with each other. Analog AM is used for digital spread-spectrum encoding. AM is the modulation. Digital is the encoding. Spread-spectrum is just a frequency and bandwidth assignment. You asked why AM is being used and not FM and all I'm pointing out is that if you are willing to consider any new system that is incompatible with an older system (like FM replacing AM), you may as well do it with something more advanced and capable, like digital packets over spread spectrum (which could be considered a relative to FM). Switching from AM to FM doesn't involve incompatibilities. You can run both in parallel indefinitely, providing identical services (just as some commercial radio stations have broadcasts on both AM and FM simultaneously). Introducing FM doesn't obsolete any of the AM equipment. Adding all sorts of digital gadgets is quite a different matter. Now you are adding functionality that will be available only to the FM/digital community. This introduces potential safety and usability issues. Stacking transmissions digitally isn't going to work when the same transmissions must be mirrored on analog AM--and they have to be if you want to maintain safety and keep controller workload reasonable. One does _not_ need to implement any of the fancier capabilities that I mentioned. I stated them only as what could be easily done once the capability is in place. A change from AM analog to anything else would be glacially slow, and small steps are safest. I see a direct safety benefit in having the clarity of FM transmission. I don't see a direct safety benefit in having other unnecessary features, and I do see potential risks. Analog cell phones are being replaced with digital cell phones ... Analog cell phones were replaced with digital well over a decade ago throughout the world, except for a couple of countries. There would be no need to replace everything at once and I'm not sure why you think that would need to be the case. The need arises as soon as you add new functionality. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Switching from AM to FM doesn't involve incompatibilities. You can run both in parallel indefinitely, providing identical services (just as some commercial radio stations have broadcasts on both AM and FM simultaneously). Introducing FM doesn't obsolete any of the AM equipment. Regarding your argument in the paragraph above and the one below... Adding all sorts of digital gadgets is quite a different matter. Now you are adding functionality that will be available only to the FM/digital community. This introduces potential safety and usability issues. Stacking transmissions digitally isn't going to work when the same transmissions must be mirrored on analog AM--and they have to be if you want to maintain safety and keep controller workload reasonable. ....honestly don't make any sense to me. In the first paragraph you see no problem with two transmitters being used to transmit the same thing using different frequencies and different modulation techniques, and in the second paragraph you do. I think you could turn the first paragraph into the second or vice-versa with appropriate special pleading - which is why I'm confused about why you find a switch from AM to FM a better transition than any other transition. I guess I just don't see what you see. |
Jim Logajan writes:
...honestly don't make any sense to me. In the first paragraph you see no problem with two transmitters being used to transmit the same thing using different frequencies and different modulation techniques, and in the second paragraph you do. The second instance involves additional or different information being transmitted over one channel, but not the other. The first instance involves only a reduction of noise; the information content is the same in both channels. I think you could turn the first paragraph into the second or vice-versa with appropriate special pleading - which is why I'm confused about why you find a switch from AM to FM a better transition than any other transition. I guess I just don't see what you see. I don't know if it's better than any other transition; I just think that something should be done to improve the archaic system that exists now. -- Transpose mxsmanic and gmail to reach me by e-mail. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
AirCraft Radio Communications | [email protected] | Rotorcraft | 0 | November 13th 03 12:48 AM |
