Jim Carter wrote:
This question is the result of the wrong runway issue at LEX last weekend. Not having flown an EFIS or EFMS myself, I'm not sure of the "into position checklist items". For example, in a standard steam-gauge panel one of the last things we check is to align the directional gyro with the runway heading and compass. With an EFIS or EFMS, is there any such last minute check, or is the heading assumed to be correct because it was aligned by the GPS when the bird came out of the chocks? Why would the EFIS be any different than an HSI (or as Bob already posted the 707 RMI). It still has a heading which ought to be verified with some real reference (Whiskey compass or runway). Of course it's easy to get complacent. Back when I had a regular DG that had to be set, I cross checked it against the compass/runway on takeoff as a matter of course (since it was almost assuredly wrong). Now that I have a slaved HSI, it's almost always right so I could see forgetting to check it. Of course, I also have GPS plotting my position on the Jepp airport diagram page if the field has an instrument approach so I probably was one up on these Conair guys. |
Ron Natalie wrote: Why would the EFIS be any different than an HSI (or as Bob already posted the 707 RMI). It still has a heading which ought to be verified with some real reference (Whiskey compass or runway). It is verified, by two redundant computers that will set a warning flag if they're off by more than a few degrees. (4 degrees in the plane I fly.) If either gyro isn't tracking correctly, or isn't agreeing with the actual magnetic heading (sensed by two independent flux gates), the warning will trigger the second the airplane makes its first turn on the ground. This system provides MORE accuracy and MORE redundancy than correcting a manual DG to a whiskey compass, and frees the crew to check the myriad of things that do require human interaction to verify before flight. Now that I have a slaved HSI, it's almost always right so I could see forgetting to check it. These airplanes have more than a slaved HSI. They have two (or more) separate, independent remote heading gyros, slaved to two (or more) separate, independent heading sensors (flux gates). If anyone ONE of those 4+ systems reads differently from the others, a warning will trip. I think you guys are barking up the wrong tree here. This isn't a case of losing redundancy, it's the case of an automatic system being able to do a better job than a human at this particular task. (Do you think an old-style, manual variable-pitch prop is a better system than a constant-speed prop, because it keeps the pilot more involved? I sure don't.) |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
