Shadin Fuel flow
Old September 3rd 06, 01:58 AM posted to rec.aviation.owning
Viperdoc[_1_]
Default Shadin Fuel flow
Jim:
Given the choice, I think a multiprobe engine analyzer is a more useful
investment, particularly in a twin. It's amazing watching those CHT's climb
on a hot summer day, where a single probe probably wouldn't show any
potential problems. It also allows for more accurate leaning, and tells
exactly which plug is having a problem when one gets fouled.
I have a Shadin fuel flow as well as an engine analyzer, and really believe
that for around the same amount of money the analyzer is much more useful.
Good luck.
Jim N
Old September 3rd 06, 02:07 AM posted to rec.aviation.owning
Jim Burns
Thanks Jim,
I've got one on the way but that project will take a little longer.
"Viperdoc" wrote in message
Jim:
climb on a hot summer day, where a single probe probably wouldn't show any
believe that for around the same amount of money the analyzer is much more
useful.
Good luck.
Jim N
Old September 3rd 06, 10:03 PM posted to rec.aviation.owning
Frank Ch. Eigler
useful.
It must be too late now, but you could have used the same setup as I
did: a JPI EDM-760 with its optional fuel flow sensors. It talks to
the GPS of course and doesn't take up an additional instrument slot.
- FChE
Old September 3rd 06, 10:39 PM posted to rec.aviation.owning
Jim Burns
As a matter of fact the 760 that I have coming is the fuel flow model... do
you know if it will work with the Shadin transducers? The 760 literature
says it works with "several types of Shadin transducers"
"Frank Ch. Eigler" wrote in message
more
useful.
- FChE
Old September 4th 06, 09:47 PM posted to rec.aviation.owning
Frank Ch. Eigler
"Jim Burns" writes:
model... do you know if it will work with the Shadin transducers?
The 760 literature says it works with "several types of Shadin
transducers"
The 760 installation manual lists "Shadin PN 680501X / 680600X".
(But why not buy the JPI bundled fuel flow widgets then?)
- FChE
Old September 5th 06, 02:04 AM posted to rec.aviation.owning
Jim Burns
Thanks, I found the K factor setting that the JPI requires to use the Shadin
transducers. It shouldn't be a problem. Since the Shadin will be replacing
my primary FF I'll use the Shadin transducers. The fact that the JPI is set
up for fuel flow is really irrelevant to me, but as long as I'm running
wiring, I will use the feature if I don't have to shell out extra for their
transducers.
"Jim Burns" writes:
transducers"
- FChE
Old September 17th 06, 07:11 AM posted to rec.aviation.owning
Shadin
Default Shadin Manual
Jim:
Who did you ask at Shadin and what do you need?
Thanks,
Tom Alton
International Sales Manager
Shadin Avionics
952-924-1105
Why does fuel flow go UP when leaning on the ground? Roy Smith General Aviation 4 March 25th 06 01:27 AM
Arrow II fuel flow joe Owning 3 June 23rd 05 05:54 AM
Fuel Flow instrument Billc851 Home Built 18 March 19th 05 12:49 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
