Fuel pump cooling shroud?
Old September 4th 06, 10:34 PM posted to rec.aviation.owning
Jim Burns
Default Fuel pump cooling shroud?
Recently we had to replace one of the mechanical fuel pumps on our Aztec due
to a leaking diaphragm.
When talking to several A&P's about the expected life of these pumps and the
cause of failure, most sited heat transfer from the accessory case to the
pump and lack of cooling being the primary culprits. Some A&P's recommended
turning the vac pump outlet to direct air onto the top of the pump, others
said that the fuel flowing through the pump should cool it until you shut
the engine down, then the pump absorbs the engine heat and cooks the rubber
diaphragm.
Not that it would help after engine shut down but I ran across this on ebay
today... http://makeashorterlink.com/?T297322BD Does anybody in the group
have such a shroud on their fuel pump? Aircraft Make/model?
Thanks
Old September 5th 06, 02:45 AM posted to rec.aviation.owning
Ronnie
Jim,
We don't have these on our pumps on our Aztec.
I had the left mechanical fuel pump fail during takeoff
and the engine surged until I got the boost pump on
(yes, I know, it should have been on before).
The failed unit had a split in one of the folds in the
rubber diaphram about 3/4 of the way around. It
could keep the engine running in cruise, but not when
full power was called for.
I wrote my failure off to old age. From the logs, it appears
that the pump was more than 20 years old, so I figured it was
way past time for the rubber diaphram.
Ronnie
"Jim Burns" wrote in message
due to a leaking diaphragm.
the cause of failure, most sited heat transfer from the accessory case to
the pump and lack of cooling being the primary culprits. Some A&P's
recommended turning the vac pump outlet to direct air onto the top of the
pump, others said that the fuel flowing through the pump should cool it
until you shut the engine down, then the pump absorbs the engine heat and
cooks the rubber diaphragm.
ebay today... http://makeashorterlink.com/?T297322BD Does anybody in the
group have such a shroud on their fuel pump? Aircraft Make/model?
Thanks
Old September 5th 06, 05:10 AM posted to rec.aviation.owning
Most Piper small singles (PA28's) have exactly such a cooling shroud
around their mechanical fuel pumps. Perhaps you could talk you A&P into
installing them on your Aztec as a minor alteration?
Old September 5th 06, 01:06 PM posted to rec.aviation.owning
Jim Burns[_1_]
I could try, but I think "engine cooling and baffeling" is specifically
spelled out as a major alteration in the AC of 337 instructions. The ram
air source for the shroud would require a hole through the rear baffles.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 06:13 PM
Lyc IO-360 mech fuel pump suggestion Robert M. Gary Owning 2 February 6th 06 09:49 PM
Christen Fuel Pump troubleshooting ShawnD2112 Aerobatics 4 August 17th 03 12:08 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
