Jim Burns wrote:
I just got off the phone with a VFR only pilot that will probably flew over 1000 hours this SUMMER and never enters B, C, or D. It's not impossible... hell it isn't even hard. Just ask the ag pilots. Jim I'm still trying to figure out how that's not hard. At least where I fly, it's very difficult to not enter controlled airspace. And where I used to fly? Very difficult to log 1000 hours VFR at any time of year. |
Avoid class A, B, C, D, & E.... 1 mile clear of clouds
Jim "Emily" wrote in message . .. Jim Burns wrote: I just got off the phone with a VFR only pilot that will probably flew over 1000 hours this SUMMER and never enters B, C, or D. It's not impossible... hell it isn't even hard. Just ask the ag pilots. Jim I'm still trying to figure out how that's not hard. At least where I fly, it's very difficult to not enter controlled airspace. And where I used to fly? Very difficult to log 1000 hours VFR at any time of year. |
Jim Burns wrote:
Avoid class A, B, C, D, & E.... 1 mile clear of clouds Jim I'm well aware of when radio contact with ATC and an IFR flight plan is is necessary, thank you. I simply fail to see how all of the above is not difficult. |
Take off from an airport with surface area G airspace. Climb beyond the
overlying Class E transition area, if such exists, fly below any overlying Class E, remaining in Class G. Around here this gives you from the surface up to 1200ft AGL not withstanding the required people, obstacle, and populated area type altitude clearance requirements. This is without entering controlled airspace.... "Emily" wrote in message . .. Jim Burns wrote: Avoid class A, B, C, D, & E.... 1 mile clear of clouds Jim I'm well aware of when radio contact with ATC and an IFR flight plan is is necessary, thank you. I simply fail to see how all of the above is not difficult. |
Jim Burns wrote:
Take off from an airport with surface area G airspace. Climb beyond the overlying Class E transition area, if such exists, fly below any overlying Class E, remaining in Class G. Around here this gives you from the surface up to 1200ft AGL not withstanding the required people, obstacle, and populated area type altitude clearance requirements. This is without entering controlled airspace.... Like I pointed out, where do I find a Class G airport near where I live? Simple...there aren't any. |
![]() "Emily" wrote in message . .. Like I pointed out, where do I find a Class G airport near where I live? Simple...there aren't any. Where do you live? |
Steven P. McNicoll wrote:
"Emily" wrote in message . .. Like I pointed out, where do I find a Class G airport near where I live? Simple...there aren't any. Where do you live? DFW. And no, the airports on the outskirts don't count, as they are at least a two hour drive from work/home. |
![]() "Emily" wrote in message . .. I'm still trying to figure out how that's not hard. At least where I fly, it's very difficult to not enter controlled airspace. You can enter controlled airspace VFR without using ATC. |
"Emily" wrote in message . .. I'm still trying to figure out how that's not hard. At least where I fly, it's very difficult to not enter controlled airspace. You can enter controlled airspace VFR without using ATC. Only class E. |
![]() "Emily" wrote in message . .. Only class E. Correct. |
An ACE goes down in flames. | PoBoy | Naval Aviation | 25 | December 9th 05 01:30 PM |
AOPA and ATC Privatization | Chip Jones | Instrument Flight Rules | 139 | November 12th 03 08:26 PM |
AOPA and ATC Privatization | Chip Jones | Piloting | 133 | November 12th 03 08:26 PM |
