#221
Mxsmanic schrieb:
I do. Linux has the same problems for safety-of-life applications as Windows. All general-purpose operating systems have the same problems. Point is, stripped down and tweaked embedded versions are not "general purpose" operating systems, but highly specialized ones which are surprizingly reliable even if they are called Windows. Stefan (usually a declared Windows hater) |
#222
On Wed, 06 Sep 2006 22:50:20 GMT, "Grumman-581"
wrote: "Steven P. McNicoll" wrote in message link.net... Didn't all early radio use AM? Technically, they were probably digital... Dashes and dots... grin .-.. .. ...- . / ..-. .- ... - -.. .. . / -.-- --- ..- -. --. .-.. . .- ...- . / .- / -.-. ..- - . / .-- .. -.. --- .-- ---- --. .-. ..- -- -- .- -. ..... ---.. .---- .--.-. --. -- .- .. .-.. .-.-.- -.-. --- -- You're probably right but putting it into writing with dots & dashes drives me mad! After learning morse (up to 20 wpm) about 30 years before getting my PPL it was easy to ident the VOR's. My instructor was very unhappy that I would not write down the ID in dots & dashes. Claimed the iexaminor would not like it. He couldn't believe I found it difficult to understand morse written as you've done above. Just for fun I tried to decode your characters, took me a 2-3 minutes to make sense of it. Much easier to understand as a sequence of musincal type tones :-) |
#223
YOu don't want to talk about blech until you've had to change the cabin
airflow filter on a 727 in a cold hangar at 3 am with a hangover back in the days when you could smoke on board the aircraft. Nicotine, for those of you who haven't ever seen the raw stuff, mixed with all the rest of the crap that had flowed through the airplane, strongly resembles drippy malted snot. Jim "Emily" wrote in message . .. Just kidding. Have you ever seen a coffee pot just pulled off an airliner? Blech. |
#224
On 2006-09-06, Mxsmanic wrote:
Thomas Borchert writes: Windows isn't Windows, as you try to make it in your generalization - which in itslef implies a certain cluelessness with the topic. Windows isn't Windows? 'Windows' is mainly a marketing name. There is a world of difference between the Windows on GA GPS displays (it'll be the NT microkernel running software designed by the display maker and will NOT contain the Win32 subsystem nor the usual crufty device drivers) and Windows on a PC (which does include the Win32 subsystem and a lot of other cruft). It's the Win32 subsystem and various Windows drivers that people are complaining about when they complain about the stability/quality of Windows. Win32 itself is pretty vile - messy, looks like it was designed by a dozen teams who never communicated with each other. Like car crashes, most Windows crashes are caused by bad drivers. A GA GPS display with the NT microkernel won't contain these buggy drivers nor the hideous pile of cruft that is the Win32 subsystem. The NT kernel itself is small and fairly elegant (even if the VMM, in my opinion, leaves a lot to be desired). It's probably within the realm of practicality to certify the NT kernel to a certain level of reliability. (Whether it has been done or not I don't know). -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
#225
Dylan,
Like car crashes, most Windows crashes are caused by bad drivers. I like that ;-) FWIW, for the PC space, most of the bad drivers are made by legions of third-party hardware manufacturers. The fact that those legions exist makes Windows and PCs so cheap and pervasive. It also leads to problems. Which is why the hard- and software quasi-monopoly employed by Apple does not have these stability problems as much. It also explains the much lower marker share of Macs... Oh, another point: The stability of the Windows PC OS has improved dramatically with the last two or so versions. But, as you say, all this is completely irrelevant to the "Windows" used in avionics. -- Thomas Borchert (EDDH) |
#226
That's all you have to offer? If you have source, that's all you need. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#227
Dylan Smith writes:
'Windows' is mainly a marketing name. There is a world of difference between the Windows on GA GPS displays (it'll be the NT microkernel running software designed by the display maker and will NOT contain the Win32 subsystem nor the usual crufty device drivers) and Windows on a PC (which does include the Win32 subsystem and a lot of other cruft). Even the NT kernel has never been validated or certified for any safety-of-life use that I'm aware of. There's just too much code. It's the Win32 subsystem and various Windows drivers that people are complaining about when they complain about the stability/quality of Windows. Win32 itself is pretty vile - messy, looks like it was designed by a dozen teams who never communicated with each other. It received an infusion of the very poorly written code from Windows 95 when NT 4.0 was written, from what I recall. It made the OS more friendly, but less stable and secure. But apparently Microsoft felt that was what the market wanted, and they were probably right, at least with respect to desktop machines. Like car crashes, most Windows crashes are caused by bad drivers. Virtually all, not just most. A GA GPS display with the NT microkernel won't contain these buggy drivers nor the hideous pile of cruft that is the Win32 subsystem. The NT kernel itself is small and fairly elegant (even if the VMM, in my opinion, leaves a lot to be desired). It's probably within the realm of practicality to certify the NT kernel to a certain level of reliability. (Whether it has been done or not I don't know). Avionics software is sometimes verified instruction-by-instruction in its final binary form. I have a hard time believing that anyone would do that for NT, even for just the kernel. Even a Linux or UNIX kernel would be hard to verify. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#228
FWIW, for the PC space, most of the bad drivers are made by legions of third-party hardware manufacturers. The fact that those legions exist makes Windows and PCs so cheap and pervasive. It also leads to problems. Which is why the hard- and software quasi-monopoly employed by Apple does not have these stability problems as much. It also explains the much lower marker share of Macs... I find that companies that build nice hardware often build terrible drivers, and vice versa. You end up having to find a compromise: a vendor that produces reasonable hardware with reasonable drivers. If stability is a priority, then you must settle for mediocre hardware with good drivers; if features are a priority, you must settle for bug-laden, system-crashing drivers with great hardware. Oh, another point: The stability of the Windows PC OS has improved dramatically with the last two or so versions. Windows has been stable since NT was first released. NT 4 destabilized things a bit in its attempt to ape the features of Windows 95. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#229
Dylan Smith wrote:
Like car crashes, most Windows crashes are caused by bad drivers. The same is true of all operating systems; I once had a Sun Solaris system crash because the tape driver had a bug. It's been a while since I worked on any RTOS, but I seem to (probably incorrectly) recall that applications running on VxWorks (the OS used on the Mars Explorer, among other spacecraft) generally have full run of the memory. That is, there is no distinction between the app and the OS as far as access privileges to memory or I/O. And I'll admit it eventually doesn't matter how reliable the OS is once it passes a certain reasonable level, since the application(s) are always going to be less reliable. If your app crashes, you may not get a "blue screen" but the end result for the pilot is the same: they have to restart the app somehow, and a cold restart is generally the easiest. (Though if the OS is running okay it can tell when the app dies and do a warm restart on the pilot's behalf.) |
#230
"Grumman-581" writes:
The embedded flavors of Linux that you see on aircraft systems are *extremely* stripped down... Same with the embedded flavors of WinCE and WinXP... If they are stripped enough to be certifiably safe, they are not longer Linux or Windows. -- Transpose mxsmanic and gmail to reach me by e-mail. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
AirCraft Radio Communications | [email protected] | Rotorcraft | 0 | November 13th 03 12:48 AM |
