Build an RV of ???
(Added rec.aviation.homebuilt to newsgroups header.)
Newps wrote: Capt. Geoffrey Thorpe wrote: "William Snow" wrote in message . .. I am considering building an RV-7A. I currently own an Arrow. I would like to have an airplane that will cruise at about 200, with a 200 Hp engine in order to keep the fuel burn numbers within reason. Is the RV the way to go or am I missing something?? Any words of wisdom would be greatly appreciated and probably heeded. William L. Snow, PE CP, IA, ASEL If your objective is to fly, find a used one for sale somewhere. If you objective is to enjoy the process of building your own airplane, then build one. Your stated objectives are 200 mph, 200 hp - sounds to me like you want to fly, not build. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. RV's are great if you don't need to carry anything other than a toothbrush. Even for the RV-10? Unless the pilot and any passengers are morbidly obese, I'd think there would be enough useful load to carry moderate amounts of luggage. While I've been less than thrilled by the rather low useful loads of the other RV's, they aren't that bad. |
Build an RV of ???
Jim Logajan wrote:
(Added rec.aviation.homebuilt to newsgroups header.) Newps wrote: Capt. Geoffrey Thorpe wrote: "William Snow" wrote in message om... I am considering building an RV-7A. I currently own an Arrow. I would like to have an airplane that will cruise at about 200, with a 200 Hp engine in order to keep the fuel burn numbers within reason. Is the RV the way to go or am I missing something?? Any words of wisdom would be greatly appreciated and probably heeded. William L. Snow, PE CP, IA, ASEL If your objective is to fly, find a used one for sale somewhere. If you objective is to enjoy the process of building your own airplane, then build one. Your stated objectives are 200 mph, 200 hp - sounds to me like you want to fly, not build. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. RV's are great if you don't need to carry anything other than a toothbrush. Even for the RV-10? Unless the pilot and any passengers are morbidly obese, I'd think there would be enough useful load to carry moderate amounts of luggage. While I've been less than thrilled by the rather low useful loads of the other RV's, they aren't that bad. The -7 & -8 have very reasonable useful loads, as 2 seat a/c go. Full fuel, 2 normal (not super-)sized adults, & ~100 lbs of baggage should get you through at least a week of travel. My wife & I are both a bit under the FAA 'standard'; we've camped for a week at major flyins without over-grossing either the -4 or the folks around us. (Includes clothes, tent, sleeping bags, softside cooler, sandwich food & breakfast food for the week.) Obviously, this can't be done if you throw anything that catches your eye into the plane. Charlie flying -4, -7 in the oven |
Similar Threads | ||||
Monster garage car/plane build | Corky Scott | Home Built | 23 | June 10th 05 02:29 PM |
Letter from Jess Meyers | Badwater Bill | Home Built | 142 | July 21st 04 02:17 AM |
Could Canada Build | Charles Talleyrand | Military Aviation | 22 | July 11th 04 10:05 PM |
I Wanna Build an Aeroplane | Badwater Bill | Home Built | 71 | August 19th 03 02:24 PM |
[Fwd: Why I'll never build a kit plane.] | Corky Scott | Home Built | 16 | July 28th 03 01:56 AM |
