KAP140 Autopilot Weirdness
Old September 9th 06, 07:51 AM posted to rec.aviation.owning
Brien K. Meehan
Default KAP140 Autopilot Weirdness
My autopilot has started fighting with me, and I'm afraid it's going to
win.
It's a 3-axis KAP140 in a Skyhawk SP. What it's doing is ... well, it
just starts turning.
After about an hour, it goes into a turn, unannounced. There doesn't
seem to be anything instigating it. It's usually to the left, and
always a "standard" turn.
It ignores the heading bug in HDG mode. It ignores the GPS or VOR head
in NAV mode. It also ignores the ROL mode, and the APR mode - yikes!
I don't know how far it would turn if I left it alone, because the few
times it's happened so far, I've been going somewhere.
Is this a common failure? Does anyone know what might be causing this?
Is my autopilot trying to kill me?
Old September 9th 06, 12:06 PM posted to rec.aviation.owning
Viperdoc[_1_]
I just went through the exact same behavior with my King autopilot. Assuming
the flight director responds to heading bug input, then the most likely
source is the roll servo. There are four drive transistors that can burn
out, and if you are lucky this is the only problem. However, the servo motor
can also be bad, and this can be expensive as well as time consuming if the
replacement is not available. It could also be a combination of both, as was
my case.
I have the old motor sitting in front of me now- it is amazingly small
considering the forces required, and also amazingly expensive ($1,500+). I
haven't gotten my bill yet, but I anticipate it'll be in the range of
$2,5000-3,000.
Good luck.
Old September 9th 06, 02:16 PM posted to rec.aviation.owning
Dan Luke
"Brien K. Meehan" wrote:
It's a 3-axis
Really?
Old September 9th 06, 02:24 PM posted to rec.aviation.owning
Matt Barrow
"Dan Luke" wrote in message
It's a 3-axis
Really?
Two regular axises...axeses...whatever, and an evil axis.
Old September 9th 06, 02:52 PM posted to rec.aviation.owning
Peter Clark
On 8 Sep 2006 23:51:56 -0700, "Brien K. Meehan"
win.
Unfortunately, it's quite common. Usually ends up being the roll
servo.
Old September 9th 06, 02:55 PM posted to rec.aviation.owning
Peter Clark
On Sat, 09 Sep 2006 11:06:07 GMT, "Viperdoc"
my case.
Skyhawks don't have a flight director
At least in mine, the roll servo is one large assembly which has the
motor and all the electronics, you can't just swap out any
subcomponants - the entire unit is replaced. At least it has a gear
at the end so you don't need to deal with any of the rigging to
replace it, pop the old one out, stick the new one in, test and return
to service.
Old September 9th 06, 05:17 PM posted to rec.aviation.owning
Jon Kraus
Interesting... I thought that the KAP140 was a 2-axis AP...
It sounds like your roll-servo is going south... Not bad to replace
because you just swap the old one out and the new one in..
Good luck!!
Jon Kraus
'79 Mooney 201
4443H @ UMP
win.
Old September 9th 06, 05:18 PM posted to rec.aviation.owning
Jon Kraus
Yea... Gotta have someway to combat that awful Skyhawk yaw..... ;-)
It's a 3-axis
Really?
Old September 9th 06, 10:33 PM posted to rec.aviation.owning
Viperdoc[_2_]
I realize most Skyhawks aren't going to have a FD, but it still sounds like
a roll servo as the source of the problem, unless there's a problem getting
the heading input to the servo.
Old September 9th 06, 11:05 PM posted to rec.aviation.owning
NW_Pilot
"Jon Kraus" wrote in message
It's a 3-axis
Really?
I am sure it is just 2 Axis with alt Hold !!!!!
How much is autopilot on commercial flights today? Mxsmanic Piloting 25 September 12th 06 06:41 AM
KAP140 autopilot and a KLN94 GPS question STICKMONKE Instrument Flight Rules 5 November 12th 05 04:06 AM
mitchell autopilot dave Owning 1 May 5th 04 06:11 PM
Chelton AP-3C autopilot Kyler Laird Owning 0 April 2nd 04 03:08 PM
KAP140 Autopilot Details News Instrument Flight Rules 27 October 22nd 03 02:01 AM
