Roy Smith wrote in message ...
Apparently, if you file IFR HPN - MMU, you get a clearance which starts "CMK CMK275R SAX039R SAX" (i.e. fly outbound on the CMK 275 until you intercept the SAX 039, then fly that inbound to SAX). In the good old days of 2 VOR receivers, this is trivial to fly; the radios don't know or care that the cross-radial fix you're going to doesn't have a name. But, how would you fly that with a GPS? I've been puzzling over that one for a week or so now, and the best I can come up with is to use the GPS's OBS mode to track outbound on the CMK 275, and set up a VOR receiver to indicate the crossing radial. Can anybody figure out a way to set it up purely on the GPS? I'm using a CNX-80, but it might be interesting to see how other units would do it too. Use the GPS's OBS mode to fly outbound on the radial from the first VOR. Then call up the second VOR on the GPS (for example through the Nearest function or the VOR page or on any other information page). There you will see the actual radial/bearing from or to the second VOR depending on how you have set it up. Once you reach the required radial from the second VOR you go direct to or continue using the OBS mode with the second VOR as a new waypoint. Gerd, ATP T182 C-FDOW |
gwengler wrote:
Use the GPS's OBS mode to fly outbound on the radial from the first VOR. Then call up the second VOR on the GPS (for example through the Nearest function or the VOR page or on any other information page). There you will see the actual radial/bearing from or to the second VOR depending on how you have set it up. Once you reach the required radial from the second VOR you go direct to or continue using the OBS mode with the second VOR as a new waypoint. Sounds like a good plan, thanks! |
Roy Smith wrote:
Sounds like a good plan, thanks! Yes, thanks! I was going over the 430 manual last night trying to find something of this sort, but I missed it. Those flying behind the navcoms in newer Cessnas have a similar/easier option. The nav side can be set to display the to/from radial instead of the standby frequency. I liked the awareness that provided, given that I could see "how close I was" to some chosen radial even before the needle had "come alive". - Andrew |
Andrew Gideon wrote:
Roy Smith wrote: Sounds like a good plan, thanks! Yes, thanks! I was going over the 430 manual last night trying to find something of this sort, but I missed it. Those flying behind the navcoms in newer Cessnas have a similar/easier option. The nav side can be set to display the to/from radial instead of the standby frequency. I liked the awareness that provided, given that I could see "how close I was" to some chosen radial even before the needle had "come alive". You can do that on the CNX-80 too. In NAV mode, hit the MON soft-key to put it in monitor mode. It then shows you the from radial of the VOR in the standby slot. |
No SID in clearance, fly it anyway? | Roy Smith | Instrument Flight Rules | 195 | November 28th 05 10:06 PM |
Clearance: Direct to airport with /U | Judah | Instrument Flight Rules | 8 | February 27th 04 06:02 PM |
Q about lost comms on weird clearance | Paul Tomblin | Instrument Flight Rules | 34 | February 2nd 04 09:11 PM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
Big John Bites Dicks (Security Clearance) | Badwater Bill | Home Built | 27 | August 21st 03 12:40 AM |
