Marco Leon wrote:
Peter, How about replacing it with a Garmin GTX 320A with an adapter for ~$1300? I will do that if/when my tube goes. I'm having an extended "warming" problem with my KT76C where it takes sometimes 10-15 minutes for it to respond to ATC. I brought it in for a $250 checkup and it passed with flying colors. When I inquired about the tube maybe needing replacement my avionics guy said it was around $500-$700 to replace the tube. However, he said that the antenna was most likely the culprit and that I should replace the small flagpole type with a blade first. Makes sense but I'm not so sure an antenna problem will give me the same symptoms so I'm prepping myself for a unit replacement. Marco Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Narco makes the AT165 in a version that is a slide-in replacement for the KT-76. I've got an AT165 in my plane, and I like it. It is has a solid state transmitter, so there are no worries about a tube wearing out. The interogation decode and reply generation is all digitally timed from a quartz crystal, so unlike older transponders it also will not go out of calibration. |
Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco |
Marco Leon wrote:
Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco I know it takes my encoder about 7 minutes to warm up. It is connected to my GPS and I get "No Altitude" until it does. The transponder will have its own "encoder" within it. It may also take awhile to warm. I have the KT78. It would be nice if there was a little ready light. -- Regards, Ross C-172F 180HP KSWI |
The 76C has an altitude display so you can see when this
happens. Bill Hale Ross Richardson wrote: Marco Leon wrote: Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco I know it takes my encoder about 7 minutes to warm up. It is connected to my GPS and I get "No Altitude" until it does. The transponder will have its own "encoder" within it. It may also take awhile to warm. I have the KT78. It would be nice if there was a little ready light. -- Regards, Ross C-172F 180HP KSWI |
Marco Leon wrote:
Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco Yes, the older encoders are designed that way. They use a heater to get the temperature to a known value to stabilize the pressure reading. Mine is a Trans-Cal encoder, and it takes about 8 minutes on a 60 degree day. Takes longer on a cold day. The transponder (a Narco AT165) has an altitude readout, which shows 0 until the encoder comes alive. |
Ray Andraka wrote:
: Yes, the older encoders are designed that way. They use a heater to get : the temperature to a known value to stabilize the pressure reading. : Mine is a Trans-Cal encoder, and it takes about 8 minutes on a 60 degree : day. Takes longer on a cold day. The transponder (a Narco AT165) has : an altitude readout, which shows 0 until the encoder comes alive. Reads '0'? IIRC, the grey code doesn't allow all high or all low signals, so the transponder should know it's bogus information. Seems like a bad design decision to read valid info with an invalid signal. My newly-installed KT-79 and oldly-installed KX-135 read '---' and 'No Altitude', respectively until the Narco AR-850 encoder warms up... 2-3 minutes on a standard day. Probably 3-4 at 20 degrees F. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Ray Andraka wrote:
Yes, the older encoders are designed that way. They use a heater to get the temperature to a known value to stabilize the pressure reading. Mine is a Trans-Cal encoder, and it takes about 8 minutes on a 60 degree day. Takes longer on a cold day. The transponder (a Narco AT165) has an altitude readout, which shows 0 until the encoder comes alive. This process starts when the electrical/avionics are turned on correct? I was thinking about putting the transponder (in my case a King KT76A) in "ALT" instead of "STANDBY" at startup to help speed up the process but now I'm thinking that it wouldn't make a difference. Over the last 4-5 flights, New York TRACON has been complaining that they only get a primary target during the early parts of my flight and thus have refused radar service. Of course, on my way back to the airport, it would start working. Given that the transoponder was given a clean bill of health from a bench check, the encoder seems to be the next logical troubleshooting step. Replacing my pole antenna with a blade-type (at the recommendation of the shop) does not seem like it would be the solution to the problem given the symtoms. Marco |
A primary target is one that is not giving any transponder reply; they are
painting you strictly from skin reflection. Why would you think that the altitude encoder has anything to do with that problem? A bench check tells you that the box is working. It says nothing about the antenna or feedline. Jim Over the last 4-5 flights, New York TRACON has been complaining that they only get a primary target during the early parts of my flight and thus have refused radar service. Of course, on my way back to the airport, it would start working. Given that the transoponder was given a clean bill of health from a bench check, the encoder seems to be the next logical troubleshooting step. Replacing my pole antenna with a blade-type (at the recommendation of the shop) does not seem like it would be the solution to the problem given the symtoms. Marco |
RST Engineering wrote:
A primary target is one that is not giving any transponder reply; they are painting you strictly from skin reflection. Why would you think that the altitude encoder has anything to do with that problem? A bench check tells you that the box is working. It says nothing about the antenna or feedline. Hmmm. I'm not sure if the controller said that I have no "mode C" or if they were just getting a "primary target." Being under a Mode C Veil, they deny service just the same. I thought it may be the encoder because of the significant delay I experience in getting radar contact with ATC seemed to make sense with others' experiences in their encoder warm-up times. Another point of info, when ATC claims that they don't see me, I do notice that the Reply Light is not flashing. When it does, ATC sees me a minute or two later after their radar sweeps. So, if it *was* the encoder and not the transponder, I should still see the Reply Light flashing, correct?? If so, it sounds like I need to replace the antenna first before thinking about the transponder. Marco |
| Thread Tools | |
| Display Modes | |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| KT76C Mode C transponder - what is it worth? | Mike Rapoport | General Aviation | 1 | November 21st 04 06:56 AM |
| KT76C Mode C transponder - what is it worth? | G.R. Patterson III | Owning | 0 | November 21st 04 06:56 AM |
| KT76C Mode C transponder - what is it worth? | Mike Rapoport | Owning | 0 | November 21st 04 02:46 AM |
| Bendix Transponder | DesotoHS2005 | Owning | 0 | August 1st 03 12:10 AM |
