NATCA Going Down in Flames
Old September 13th 06, 06:04 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
Default NATCA Going Down in Flames
"bdl" wrote in message
Yes, you do, since you said that incapacitation do to drowsiness was
not an acceptable excuse for sick leave.
I didn't say that. I said the policy does not permit use of sick leave for
drowsiness.
They provided it. They felt that controllers could be groggy coming
out of their nap onto their shift.
They did? Cite please.
It doesn't matter what their reason is though.
Shouldn't any change in policy be justified?
They set the rules.
Why are you so anti-authority?
I'm not. Why are you so imperceptive?
  #542
Old September 13th 06, 06:06 PM posted to rec.aviation.piloting
Jose[_1_]
Hmm. Might it have increased taxe revenue too? Thereby allowing more
bridge maintenance?
Maybe. However I suspect not by much.
How about those bridge maintenance crews didn't
have to spend as much time working around graffitti? Perhaps they took
more pride in their work? Gave that extra 10%?
I doubt it actually.
Made them feel [... t]hat their work wasn't just trashed to no avail by the
next street gang?
Maintanance isn't just paint that gets trashed by a street gang.
Jose
There are more ways to skin a cat than there are cats.
  #543
Old September 13th 06, 06:08 PM posted to rec.aviation.piloting
Controllers in radar facilities (those dark windowless rooms) should be
able to wear shorts as well?
Sure. Why not?
Do you wear jeans in the winter?
I did.
Or is the dress code requirement of
dress pants ok then?
I don't like it for winter either.
Is this a temperature issue, or an authority issue for you?
It appears to be an authority issue for FAA management.
  #544
Old September 13th 06, 06:15 PM posted to rec.aviation.piloting
bdl
FAA management is the authority.
  #545
Old September 13th 06, 06:25 PM posted to rec.aviation.piloting
Of course. The question is why are they making an issue of it?
  #546
Old September 13th 06, 06:29 PM posted to rec.aviation.piloting
bdl
drowsiness.
Even drowsiness to the extent of incapacitation? If they are so drowsy
they are not at 100% for work they shouldnt' be there.
http://www.avweb.com/eletter/archive.../717-full.html
quote
Among the FAA's new work rules imposed on air traffic controllers last
week was a ban on napping during breaks and, predictably perhaps, the
agency and the controllers union differ on the impact of such a rule.
"Even though they're on break, they can be called back to work at any
time," FAA spokeswoman Laura Brown told The Associated Press. "If they
had to be called back to work traffic and they had been sleeping, they
would be groggy."
/qoute
It was justified.
  #547
Old September 13th 06, 06:43 PM posted to rec.aviation.piloting
Grumman-581[_3_]
ps.com...
Sounds like we need to fix the A/C.
That's what I suggested previously... If you want to make them quit wearing
shorts, just turn up the A/C...
  #548
Grumman-581[_3_]
ink.net...
It's not broken, it's just not up to the task. Should we spend your tax
dollars to upgrade it so that controllers can be comfortable and efficient
while wearing pants or should we just allow them to dress comfortably
under
the present conditions?
The former because not everyone likes to wear shorts...
  #549
Grumman-581[_3_]
I want them alert BEFORE they return to work a position. I want them
at a minimum to be AWAKE when they are at the facility. On duty or on
break. If they've got nothing to do they can read the controller's
manual again. Or maybe the AIM.
I thought you wanted them *awake*... Reading the AIM is *not* conducive for
that...
  #550
Old September 13th 06, 07:02 PM posted to rec.aviation.piloting
Allen[_1_]
ink.net...
Then you want them permitted to nap while on break.
How long is the break period?
Allen
An ACE goes down in flames. PoBoy Naval Aviation 25 December 9th 05 01:30 PM
AOPA and ATC Privatization Chip Jones Instrument Flight Rules 139 November 12th 03 08:26 PM
AOPA and ATC Privatization Chip Jones Piloting 133 November 12th 03 08:26 PM
