Mxsmanic wrote:
Peter Duniho writes: I lower the flaps for the preflight inspection so that I can properly inspect the flap mechanisms, but then retract them after engine start and before taxiing. Doesn't flap movement require engine power? Depends on the aircraft. Some planes they are purely mechanical from the flap handle in the cockpit. In others they are electric. On my plane they are hydraulic, which is run from the engine if it is running but has a backup "wobble pump" which I can use to retract them on the ground if I forget to do so before shutdown. My plane specs flaps up or 1/2 for takeoff (short field takeoff done with 1/2). Landing can be done with any setting of flaps. |
Ron Natalie writes:
Depends on the aircraft. Some planes they are purely mechanical from the flap handle in the cockpit. I'm surprised that a small handle in the cockpit would provide enough leverage to lower flaps. Isn't there are a lot of aerodynamic pressure to overcome against them (at least if they are lowered in flight)? I'm always surprised by how much is still mechanically linked in aircraft. I'm not necessarily saying that's bad--simple is reliable, generally speaking--but somehow I don't picture control surfaces as something that one could easily move without assistance. I suppose small planes are lighter than they appear, and just because the wings look relatively big doesn't mean that they are heavy or hard to move. My plane specs flaps up or 1/2 for takeoff (short field takeoff done with 1/2). Landing can be done with any setting of flaps. I've always been landing with flaps down completely, and usually taking off with some flaps, as I had read that this was necessary (and I had seen accident reports about pilots who crashed because they took off without first lowering flaps). But from what you and others here say it sounds like I have considerably more discretion in whether or not I lower flaps for both operations. Are there good reasons to lower flaps in flight, outside take-off and landing? I've thought that they would be useful for increasing drag and lowering airspeed, but since they apparently cannot be used at high speeds I guess this isn't a good idea. Sometimes if one must descend rapidly just idling the throttle doesn't seem to be enough to stay below hazardous speeds, and few aircraft seem to have speed brakes. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Ron Natalie writes: Depends on the aircraft. Some planes they are purely mechanical from the flap handle in the cockpit. I'm surprised that a small handle in the cockpit would provide enough leverage to lower flaps. Who said the handle is small? Some of these "handles" are 2 - 3 feet long. Margy Isn't there are a lot of aerodynamic pressure to overcome against them (at least if they are lowered in flight)? |
Margy Natalie writes:
Who said the handle is small? Some of these "handles" are 2 - 3 feet long. Where are they in the cockpit? I haven't seen many small cockpits; is there a picture on the Net of one that has this kind of lever? It sounds like it would be awkward to use in flight. I go by what I've seen in the handful of pictures of cockpits that I've encountered. Most of these are of jet aircraft, and the flap lever is longer than most but hardly long enough to provide much leverage. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: Margy Natalie writes: Who said the handle is small? Some of these "handles" are 2 - 3 feet long. Where are they in the cockpit? I haven't seen many small cockpits; is there a picture on the Net of one that has this kind of lever? It sounds like it would be awkward to use in flight. I go by what I've seen in the handful of pictures of cockpits that I've encountered. Most of these are of jet aircraft, and the flap lever is longer than most but hardly long enough to provide much leverage. In the StingSport LSA it's right where you would expect to find your Toyota parking brake handle... in fact, it looks suspiciously like a Toyota parking brake handle... grin -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
Mxsmanic wrote:
Margy Natalie writes: Who said the handle is small? Some of these "handles" are 2 - 3 feet long. Where are they in the cockpit? I haven't seen many small cockpits; is there a picture on the Net of one that has this kind of lever? It sounds like it would be awkward to use in flight. I go by what I've seen in the handful of pictures of cockpits that I've encountered. Most of these are of jet aircraft, and the flap lever is longer than most but hardly long enough to provide much leverage. The lever arm for the flap handle in our RV-6 is something like two feet long. It works just like a parking brake, though the forces are higher (20lb maybe, up to 30+ when going to full). As for the other control surfaces--the stick is directly connected (via pushrods) to the ailerons and elevator. Even in flight, it takes a maximum of one finger and your thumb to move the control surface and make the airplane respond. It's not twitchy--the controls are just light and easy to manipulate. In pretty much every jet aircraft I can think of, the flap handle just manipulates some sort of rotary sensor or microswitch that tells the flaps where to go. |
Every airplane with flaps has speed limits with flaps
extended. If there is a positive stop, they may have a series of allowable speeds. The same sort of limits apply to landing gear extension and operation with the gear extended. In some airplanes the gear is not to be extended at speeds above a certain speed because the motor and linkage is not strong enough, but once fully extended and lock down, the airplane can be flown at a higher speed. Some airplanes can have the gear extended at very high speed in an emergency, but then the gear doors may be damaged and require replacement or adjustment before the next flight. Real airplanes and the simulators that exactly duplicate a particular airplane are flown by the identical procedures. Table-top PC "simulators" are more properly known as training devices and they mimic some generic airplanes. A real simulator costs more than the airplane it is duplicating, a Beechjet or Boeing simulator can cost $8-10 million dollars or more. It is worthwhile because it doesn't burn several thousand pounds of fuel per hour, can be run nearly 24/7, rarely kills anyone and it is a safe place to do things that can't be done safely in a real airplane. Also, it allows the airplane to be out earning revenue. Even a PC based training device is very useful for learning and practicing procedures, but you get what you pay for. A King Air trainer with out full visual and motion still allows learning all the systems and practicing the various emergency and abnormal procedures. "Mxsmanic" wrote in message ... | Ron Natalie writes: | | Depends on the aircraft. Some planes they are purely mechanical from | the flap handle in the cockpit. | | I'm surprised that a small handle in the cockpit would provide enough | leverage to lower flaps. Isn't there are a lot of aerodynamic | pressure to overcome against them (at least if they are lowered in | flight)? | | I'm always surprised by how much is still mechanically linked in | aircraft. I'm not necessarily saying that's bad--simple is reliable, | generally speaking--but somehow I don't picture control surfaces as | something that one could easily move without assistance. I suppose | small planes are lighter than they appear, and just because the wings | look relatively big doesn't mean that they are heavy or hard to move. | | My plane specs flaps up or 1/2 for takeoff (short field takeoff done | with 1/2). Landing can be done with any setting of flaps. | | I've always been landing with flaps down completely, and usually | taking off with some flaps, as I had read that this was necessary (and | I had seen accident reports about pilots who crashed because they took | off without first lowering flaps). But from what you and others here | say it sounds like I have considerably more discretion in whether or | not I lower flaps for both operations. | | Are there good reasons to lower flaps in flight, outside take-off and | landing? I've thought that they would be useful for increasing drag | and lowering airspeed, but since they apparently cannot be used at | high speeds I guess this isn't a good idea. Sometimes if one must | descend rapidly just idling the throttle doesn't seem to be enough to | stay below hazardous speeds, and few aircraft seem to have speed | brakes. | | -- | Transpose mxsmanic and gmail to reach me by e-mail. |
"Jim Macklin" writes:
A real simulator costs more than the airplane it is duplicating, a Beechjet or Boeing simulator can cost $8-10 million dollars or more. Are there full-motions simulators for specific GA aircraft, such as the Baron 58 that I've mentioned? The aircraft apparently costs about $1 million to purchase today, so I should think that someone would have simulators somewhere, but I don't know if a full-motion simulator would be economical. If one exists, it would be fun to fly it. It is worthwhile because it doesn't burn several thousand pounds of fuel per hour, can be run nearly 24/7, rarely kills anyone and it is a safe place to do things that can't be done safely in a real airplane. Also, it allows the airplane to be out earning revenue. Very similar to the reasons for using a PC-based simulator. You get many of the advantages and avoid many of the disadvantages of a real aircraft. Even a PC based training device is very useful for learning and practicing procedures, but you get what you pay for. A King Air trainer with out full visual and motion still allows learning all the systems and practicing the various emergency and abnormal procedures. Are there specific simulator packages for specific aircraft that run on a PC? I've only used MSFS, mainly because it has a very good all-around blend of the kinds of features one might want in a simulator, but I've heard that there are other programs that are very good for specific purposes, such as very intensive IFR training or very accurate flight models. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Are there full-motions simulators for specific GA aircraft, such as the Baron 58 that I've mentioned? Consider making or buying your own. Google for the keywords "full" "motion" "simulator" - you'll come up with a bunch of relevant hits. Here's some: Plans for allegedly building your own for under $350: http://www.acesim.com/main.html Another do-it-yourself set of plans: http://www.simcraft.com/phpPages/products/primusDIY.php Some vendors, no price info: http://www.noonco.com/flyer/ http://www.flightmotion.com/home.htm http://home.claranet.nl/users/wvdlel...h/index-e.html |
In article SwnOg.22694$SZ3.9372@dukeread04,
"Jim Macklin" wrote: Every airplane with flaps has speed limits with flaps extended. If there is a positive stop, they may have a series of allowable speeds. Why do you say "positive stop"? I think you're talking about: *23.1511***Flap extended speed. (a) The flap extended speed VFE must be established so that it is‹ (1) Not less than the minimum value of VF allowed in 23.345(b); and (2) Not more than VF established under 23.345(a), (c), and (d). (b) Additional combinations of flap setting, airspeed, and engine power may be established if the structure has been proven for the corresponding design conditions. I don't see anything there that mandates a "positive stop". |
