Bendix KT76C transponder requires major repair: Options?
Old September 14th 06, 06:41 PM posted to rec.aviation.owning
Marco Leon
Default Bendix KT76C transponder requires major repair: Options?
RST Engineering wrote:
A primary target is one that is not giving any transponder reply; they are
painting you strictly from skin reflection. Why would you think that the
altitude encoder has anything to do with that problem?
A bench check tells you that the box is working. It says nothing about the
antenna or feedline.
Hmmm. I'm not sure if the controller said that I have no "mode C" or if
they were just getting a "primary target." Being under a Mode C Veil,
they deny service just the same. I thought it may be the encoder
because of the significant delay I experience in getting radar contact
with ATC seemed to make sense with others' experiences in their encoder
warm-up times.
Another point of info, when ATC claims that they don't see me, I do
notice that the Reply Light is not flashing. When it does, ATC sees me
a minute or two later after their radar sweeps. So, if it *was* the
encoder and not the transponder, I should still see the Reply Light
flashing, correct??
If so, it sounds like I need to replace the antenna first before
thinking about the transponder.
Marco
Old September 14th 06, 06:48 PM posted to rec.aviation.owning
RST Engineering
"Marco Leon" wrote in message
flashing, correct??
The encoder working or not working has absolutely nothing to do with the
reply light.
Why don't you consider running some tests before shotgunning parts that may
or may not be bad?
Old September 14th 06, 07:36 PM posted to rec.aviation.owning
Ray Andraka
flashing, correct??
reply light.
or may not be bad?
The reply light should come on whenever the transponder decodes a valid
interrogation and generates a reply. The reply can be suppressed by an
interrogation coming too soon after a previous one, by the box being put
in standby, or with an externally applied suppress signal. If the
encoder ready is hooked up to that suppress signal, it would prevent a
reply...but it isn't supposed to be connected that way. That input is
meant for other equipment to assert if a transponder reply would mess up
the equipment function. It is typically used for DME to suppress a
transponder transmission while the DME is waiting for a reply.
More likely, your transponder may be out of calibration. Older
transponders (I'm familiar with the guts of the Narco line) like the
Narco AT150 and earlier use resistor-capacitor combinations to set the
delays for the interogation decode. If the values drift or the trimming
pots move slightly, your transponder may no longer reliably decode
interrogations. The delay is also somewhat temperature sensitive to the
extent that temperature changes the values of the components slightly.
It could be your transponder needs to be recalibrated.
Old September 14th 06, 07:41 PM posted to rec.aviation.owning
Marco Leon
reply light.
That's why I'm thinking it's the antenna.
or may not be bad?
Like what? I had the King KT76A benched-checked and it came through
with flying colors. They checked the impedance of the antenna and found
that it was low (high?) but within tolerances. Cleaning some contacts
improved it slightly. That's probably why they suggested I replace the
antenna.
Would you know if a bench check would tell them if the transponder tube
took too long to warm up? Since I had to fly the plane there, it would
have been "warm" already.
Marco
Old September 14th 06, 07:48 PM posted to rec.aviation.owning
Ross Richardson[_2_]
reply light.
or may not be bad?
antenna.
Marco
When I have had my transponder checked it was always in the the "field",
transponder in the plane.
Regards, Ross
C-172F 180HP
KSWI
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport Owning 0 November 21st 04 01:46 AM
Bendix Transponder DesotoHS2005 Owning 0 July 31st 03 11:10 PM
