Alternate same as departure?
Old December 6th 04, 05:54 PM
dlevy
Default Alternate same as departure?
Can you file the departure airport as the alternate?
Two airports in the middle of nowhere 40 miles apart. I can't think of
another reasonable option.
Old December 6th 04, 06:01 PM
Dave Butler
Certainly. Nobody cares or checks on what you've filed anyway. If they did,
there's nothing wrong with having the departure airport as a filed alternate.
Old December 6th 04, 06:21 PM
Roy Smith
Sure you can file your origin as your alternate. There's no reason
not to. All an alternate means is someplace you've pre-computed you
should (according to specific criteria laid out in part 91) be able to
get into if your destination becomes unusable.
If your goal is to get someplace, turning around and going back home
may not be very useful, but it's certainly legal.
Old December 6th 04, 08:15 PM
Stan Gosnell
"dlevy" wrote in news:7_0td.36539$Dm2.20820
@bignews1.bellsouth.net:
Certainly. I do it all the time. As long as it meets the weather
requirements and you have the fuel onboard, you can use it.
Regards,
Stan
Old December 6th 04, 08:49 PM
Paul Tomblin
I'm pretty sure one of the cross country questions in the IFR "written"
does exactly that.
Paul Tomblin http://xcski.com/blogs/pt/
Simulated editor war, conducted by seasoned professionals in a controlled
environment. Don't try this at home.
-- Christian Bauernfeind
Old December 6th 04, 09:13 PM
Does it qualify as an alternate?
Old December 6th 04, 09:21 PM
dlevy
I should have mentioned I wouldn't depart if it didn't qualify as an
alternate.
Old December 6th 04, 11:14 PM
Matt Whiting
Sure, why not?
Matt
Old December 7th 04, 07:24 AM
Brien K. Meehan
Roger wrote:
I filed from 3BS direct MBS VOR, LAN, AMN, 3BS.
There was a pause and the briefer said, I think I can see a way to
save you a lot of gas if you are willing to go direct.
Actually, I've filed similar plans with Lansing, and they wouldn't let
me. They insisted that I file at least 2 plans, one departing Midland
and the other departing Lansing.
I've also tried to file flight plans with the alternate the same as the
departure, and they wouldn't take it. I didn't argue, and just gave
another nearby alternate (e.g. DET instead of PTK).
Notes on NACO Obstacle Departure Procedures John Clonts Instrument Flight Rules 1 July 15th 04 10:20 PM
Interesting Departure Procedu MRB Trixy Two Richard Kaplan Instrument Flight Rules 26 February 18th 04 11:42 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 04:55 AM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
Alternate requirements Anthony Chambers Instrument Flight Rules 8 September 17th 03 09:45 PM
