Ferrying Aircraft
Old September 16th 06, 06:27 PM posted to rec.aviation.piloting
Robert M. Gary
Default Ferrying Aircraft
I'm not sure what you base that on. The courts have ruled that logging
free flight time is commercial and requires a commercial rating.
-Robert, CFII
Stache wrote:
John you can use your PPL for this no special certificate is required
as long as you hold the rating as a private pilot. In some case you
may have to be instrument rated depending on the length of the flight
and weather conditions.
Stache
Old September 16th 06, 09:31 PM posted to rec.aviation.piloting
Stubby
I don't have a FAR/AIM here, but I do seem to remember there are a
number of exceptions that allow things such as ferrying planes, flying
around political candidates, and humanitarian work such as delivering
patients. Correct me if I'm wrong.
-Robert, CFII
Stache
Old September 16th 06, 11:57 PM posted to rec.aviation.piloting
Jim Logajan
I think the following is the relevant regulation:
§ 61.113 Private pilot privileges and limitations: Pilot in command.
(a) Except as provided in paragraphs (b) through (g) of this section, no
person who holds a private pilot certificate may act as pilot in command
of an aircraft that is carrying passengers or property for compensation
or hire; nor may that person, for compensation or hire, act as pilot in
command of an aircraft.
(b) A private pilot may, for compensation or hire, act as pilot in
command of an aircraft in connection with any business or employment if:
(1) The flight is only incidental to that business or employment; and
(2) The aircraft does not carry passengers or property for compensation
or hire.
(c) A private pilot may not pay less than the pro rata share of the
operating expenses of a flight with passengers, provided the expenses
involve only fuel, oil, airport expenditures, or rental fees.
(d) A private pilot may act as pilot in command of an aircraft used in a
passenger-carrying airlift sponsored by a charitable organization
described in paragraph (d)(7) of this section, and for which the
passengers make a donation to the organization, when the following
requirements are met:
(1) The sponsor of the airlift notifies the FAA Flight Standards District
Office with jurisdiction over the area concerned at least 7 days before
the event and furnishes—
(i) A signed letter from the sponsor that shows the name of the sponsor,
the purpose of the charitable event, the date and time of the event, and
the location of the event; and
(ii) A photocopy of each pilot in command's pilot certificate, medical
certificate, and logbook entries that show the pilot is current in
accordance with §§61.56 and 61.57 of this part and has logged at least
200 hours of flight time.
(2) The flight is conducted from a public airport that is adequate for
the aircraft to be used, or from another airport that has been approved
by the FAA for the operation.
(3) No aerobatic or formation flights are conducted.
(4) Each aircraft used for the charitable event holds a standard
airworthiness certificate.
(5) Each aircraft used for the charitable event is airworthy and complies
with the applicable requirements of subpart E of part 91 of this chapter.
(6) Each flight for the charitable event is made during day VFR
conditions.
(7) The charitable organization is an organization identified as such by
the U.S. Department of Treasury.
(e) A private pilot may be reimbursed for aircraft operating expenses
that are directly related to search and location operations, provided the
expenses involve only fuel, oil, airport expenditures, or rental fees,
and the operation is sanctioned and under the direction and control of:
(1) A local, State, or Federal agency; or
(2) An organization that conducts search and location operations.
(f) A private pilot who is an aircraft salesman and who has at least 200
hours of logged flight time may demonstrate an aircraft in flight to a
prospective buyer.
(g) A private pilot who meets the requirements of §61.69 may act as a
pilot in command of an aircraft towing a glider or unpowered ultralight
vehicle.
Old September 17th 06, 12:04 AM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
-Robert, CFII
But there is no requirement that you must log every flight, and even if
you did log such flight there is no requirement to show this
information anyone except what is required to prove currency.
Old September 17th 06, 06:18 AM posted to rec.aviation.piloting
Robert M. Gary
The problem will happen if you put yourself out for hire. If you post
an ad to ferry planes, clearly you are commerical. However, if a friend
happens to need his plane moved you should be ok as a private.
Insurance will be another thing.
-Robert
Old September 17th 06, 04:28 PM posted to rec.aviation.piloting
Grumman-581[_3_]
I've had this happen before... Quite a few years ago, a buddy of mine bought
a new plane, although he was still workiing on his PPL... I flew up to the
seller's location with him via Southwest and then I flew it back to HOU...
As a student pilot, he was definitely not PIC... It wasn't a commercial
endeavor nor did I consider the logging of the flight time to be any sort of
compensation -- it was just helping out a buddy... Hell, when I needed my
plane moved from Iowa back down to Houston, he did it for me since he was
already up there for Oshkosh anyway and it saved me a trip via commercial
airline doing the shuffle myself... Regardless of what is written in the
FARs, I don't think a friend helping out a friend in such a situation should
be classified as a commercial flight...
Old September 17th 06, 07:42 PM posted to rec.aviation.piloting
Huck
It all comes down to who looks and what that person{faa} deems as
payment. If you advertise as a ferry pilot you need a comercial period.
If you are just helping a buddy move an airplane a private is fine
because you are not "holding out" or receiveing payment. I also say
lets have some common sense here people if you think that a brand new
private pilot should be moving airplanes all over the country with
little or no experience is just silly. I have pilots that have in
excess of 200-300 hrs but have never left the state. In this day and
age of TFR's and the crazy weather that we seem to be having these
days. Please take your time and plan everything well. I think this
takes the training that a commercial rating{preferably IFR rated}
supplies.
Matt Tiberii
Comm ASEL AMEL ASES INSTRUMENT
CFI CFII
Old September 17th 06, 11:18 PM posted to rec.aviation.piloting
supplies.
Matt Tiberii
CFI CFII
I agree with you for the most part, but except for TFR's I don't think
weather is any worse nowadays than it used to be. In fact, we have much
better tools for weather avoidance and navigation than in the past, so
all other things being equal a pilot is better equipped and safer today
for a ferry trip than in the past. However, that does not mean that a
newly minted PP should attempt such a thing.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
