Alternate same as departure?
Old December 7th 04, 08:57 PM
Ron Natalie
Steven Barnes wrote:
Aren't alternates also used by ATC for lost comm fun?
ATC has no clue as to what your alternate is.
Old December 7th 04, 09:57 PM
On 7 Dec 2004 12:17:31 -0800, "Michael"
Whenever I make a business trip from Houston to Austin when the weather
is iffy in Austin but not in Houston, I file my alternate back in
Houston. If I can't get in at Austin, it does me no good to get in
somewhere 50 miles away with no arrangements for ground transport. I'm
going to miss my meeting anyway, so I might as well turn around and go
home.
Michael
So what difference does it make what your alternate is?
If you want to go back to Houston, you go back to Houston, whether
your alternate is Houston, New Orleans or Hong Kong.
You don't have to go to your alternate if you don't wnat to, ever.
Old December 7th 04, 10:17 PM
C Kingsbury
"Roy Smith" wrote in message
"Brien K. Meehan" wrote:
I've also tried to file flight plans with the alternate the same as the
departure, and they wouldn't take it. I didn't argue, and just gave
another nearby alternate (e.g. DET instead of PTK).
This one I just don't understand. What alternate you file has
absolutely no impact for ATC. It's a regulatory obligation that the
pilot has to comply with to be legal. There's no reason at all that FSS
or ATC should give a rats ass what your alternate is, and for an FSS guy
to refuse to accept your stated alternate is absurd. I'd have told the
guy to just enter the flight plan the way I read it to him.
When I file I'll give them the flight plan first without the alternate, then
listen to the briefing, and use that to figure out whether I need an
alternate and what the best one is. Most of the time I need to remind them
not to hang up on me after they finish giving me the weather. Most of the
time I'm filing with Bridgeport.
-cwk.
  #24
Old December 7th 04, 10:18 PM
C Kingsbury
wrote in message ...
I know of an operator who operates a Gulfstream 5 on a regular basis from
LAX to HNL. During the winter when the weather is really churning in the
islands with a tropical convergence and all that brings, he files LAX as
his alternate.
Wow. Talk about the mother of all 180 degree turns!
-cwk.
  #25
Old December 7th 04, 10:20 PM
Roy Smith
In article . net,
his alternate.
Doesn't hold a candle to Apollo 13.
  #26
Old December 7th 04, 10:39 PM
Michael
iYou don't have to go to your alternate if you don't wnat to,
ever./i
True. But why bother with working out your actual Plan B, making sure
fuel and weather are going to be OK for it - and then filing something
else? I generally make it a point to file as my alternate what I
really intend to use, unless legalities prevent me from doing so.
Michael
  #27
Old December 7th 04, 11:01 PM
On 7 Dec 2004 14:39:26 -0800, "Michael"
ever./i
Michael
You said this:
"Whenever I make a business trip from Houston to Austin when the
weather is iffy in Austin but not in Houston, I file my alternate back
in Houston. If I can't get in at Austin, it does me no good to get in
somewhere 50 miles away with no arrangements for ground transport"
implying that you would be stuck going "fifty miles away" just because
it was filed as an alternate.
This isn't true, and maybe it wasn't what you intended to suggest.
You could go back to Houston regardless.
If you intended to say that it saved the trouble of a separate flight
plan to a different alternate to compute fuel requirements, I agree.
  #28
Old December 7th 04, 11:08 PM
Brien K. Meehan
Roy Smith wrote:
Technically, they should let you do that, but I'm sure there's some
operational reason why it's easier on ATC to have two distinct flight
plans, so I'm willing to go with the flow on this. The pilot and ATC
need to act as a team for things to work efficiently. If one team
member says, "please just do it my way" and it's no big deal to
comply,
there's no reason to get bent out of shape over it.
I think the briefer said that Detroit Approach requested or required
them to make a distinct plan for flights crossing their border, even if
you're not landing. If I'd go PTK-FNT-PTK, Flint would give me a new
clearance and new squawk code when I was done with the practice
approaches.
So, maybe that wouldn't apply to 3BS-LAN, but it would to 3BS-PTK. Hmm.
  #30
Old December 8th 04, 01:43 AM
Steven Barnes
"Dave Butler" wrote in message
news:1102448212.183819@sj-nntpcache-5...
Aren't alternates also used by ATC for lost comm fun? In radar
environments,
it's probably not as big of a deal. But when not in radar, if you miss
at
your destination, ATC has a pretty good idea where you're headed next if
you
listed an alternate. Or at least where you said you would head if things
didn't work out at the destination.
Nope, ATC doesn't even know what you filed as an alternate. It's not on
flight progress strip. DGB
Really. Well, other than making you think about what could go wrong and
providing more to learn for students, what is it actually used for? (or was
that the original question in this thread...)
Notes on NACO Obstacle Departure Procedures John Clonts Instrument Flight Rules 1 July 15th 04 10:20 PM
Interesting Departure Procedu MRB Trixy Two Richard Kaplan Instrument Flight Rules 26 February 18th 04 11:42 PM
Alternate Intersection Name in Brackets? Marco Leon Instrument Flight Rules 7 January 22nd 04 04:55 AM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
Alternate requirements Anthony Chambers Instrument Flight Rules 8 September 17th 03 09:45 PM
