Marking sheetmetal
Old September 17th 06, 02:37 AM posted to rec.aviation.homebuilt
JJS
Default Marking sheetmetal
"Michael Horowitz" wrote in message
I want to mark sheetmetal for bending.
Can't use a scribe because I'll weaken the metal.
Magic Marker is too thick.
Pencil doesn't show.
What do you use? - Mike
Word on the RV lists is that blue fine tip Sharpies are the way to go. For
some reason the blue ink lasts longer. Sharpies' lives can be extended by
injecting lacquer thinner with a needle and syringe once they start running
out of ink. Van's says that for a mark that needs to show through primer it
is ok to use an electric "vibrating" engraving pencil in spite of
admonitions against marking with a scribe.
Joe Schneider
Cherokee 8437R
RV-7 in the works
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old September 17th 06, 05:59 AM posted to rec.aviation.homebuilt
Drew Dalgleish
On Sat, 16 Sep 2006 20:37:39 -0500, "JJS" jschneider@re
Joe Schneider
Cherokee 8437R
RV-7 in the works
Cumon Joe a shapie costs a dollar do we really need to make it last
longer ?
Old September 17th 06, 06:26 AM posted to rec.aviation.homebuilt
Morgans[_2_]
longer ?
They don't last very long when you forget and leave the cap off, do they?
g
There is a version of a marker that clicks like a retractable ink pen,
though, and they work pretty good. The problem is that the point is not
nearly as sharp.
Anyone ever try to sharpen a sharpie? It seems like there should be a way,
somehow.
Jim in NC
Old September 21st 06, 10:15 PM posted to rec.aviation.homebuilt
Ebby
I take needle nose pliers and pull the point out about an 1/8 in or so then
use my razor knife to repoint the wick. Works for awhile and the wick is
over an inch long so it still. hmmmm. well it still wicks!
"Ebby"
Hatz Classic s/n37
Camden, NY
"Morgans" wrote in message
longer ?
g
nearly as sharp.
way,
somehow.
Jim in NC
Old September 18th 06, 02:43 AM posted to rec.aviation.homebuilt
longer ?
Sure, it's only a buck. But it only quits at night or on the
weekend when the stores that sell Sharpies are all closed.
Dan
Old September 18th 06, 03:53 AM posted to rec.aviation.homebuilt
Peter Dohm
longer ?
Dan
It also quits just out revenge because you failed to cap it securely--for a
ridiculously short period of time. :-(
The obvious solution is to stock spares.
Peter
Wire marking Scott Vetter Restoration 1 December 1st 04 03:23 AM
