![]() wrote in message ... When they say "Maintain XXXXX altitude" after having received an approach clearance you have to maintain the altitude. Obviously, you can't continue the approach and maintain 3,000. So, you comply with the latest clearance. No doubt that it is a squeeze play, but the controller apparently had a good reason. What good reason might there be? Once he deletes the restriction and, if at the point you are too high to continue the approach, then you so advise him. The restriction was superfluous for the next five miles, as he was that far outside of ELESE and 3000 was the minimum altitude until that fix. This scenerio will (or should) only happen in a radar environment. This scenario can happen only in a radar environment because IFR/VFR separation is not provided in a nonradar environment. |
![]() "Steven P. McNicoll" wrote: This scenerio will (or should) only happen in a radar environment. This scenario can happen only in a radar environment because IFR/VFR separation is not provided in a nonradar environment. I have no experience with that. I related my experience that this happened several times over the years flying into LAX where practice approaches and VFR aircraft were not involved. |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
