retractable floats?
Old September 18th 06, 01:04 AM posted to rec.aviation.homebuilt
Ernest Christley
Default retractable floats?
Morgans wrote:
Fun thought problem, huh?
Well, it was until you showed how it is clearly impossible 8*)
Actually, the original post wasn't asking about putting floats on a
Delta, I was just saying that the mechanism chosen by John Dyke might
possibly be a solution for retracting floats. If I were to pick a
solution for floating a Delta, I'd change to a rear mounted ducted fan
engine and seal the belly.
As for all the aerodynamic effects or moving around a large portion of
the airplane, you weren't expecting a fully engineered solution in an
off-hand internet post, were you?
Old September 18th 06, 01:13 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Humm, what about CG issues? Are you going to put the people way up in the
nose, or just add a large chunk of concrete where the engine used to be? g
Well, from you, I expected nothing less, than an engineered design
modification plan, with all of the "t's" dotted, and the "i's" crossed! Or
something like that! ;-))
Jim in NC
Old September 18th 06, 12:23 PM posted to rec.aviation.homebuilt
Ernest Christley
You set the bar much to high.
CG issue. It would have to be a nearly complete re-design, moving the
pilot really far forward with his feet crammed up into the nose, much
like the Air-Cam.
It's worth noting that the wheels on the Delta cause a nose-down vector
when in the down position. This goes away when they're retracted, but
is compensated for by the CG shift aft just slightly. The net effect is
no pitch change.
Many of the aerodynamic issues you brought up earlier could be dealt
with a combination of choosing different lengths for the front and rear
legs, and having the floats retract behind a stationary faring. I'll
work out some exact numbers some day AFTER I get the current one flying
with boring wheels 8*)
Old September 18th 06, 03:02 PM posted to rec.aviation.homebuilt
Long ago I came across an article in an aviation magazine
describing (and having photos of) a set of "retractable" floats on a
Cub. These were pivoted on fore-and-aft pins at the mains so that they
swung outward far enough to give the wheel (which was still there and
fit into a well in the float when the float was down) access to the
surface. There were various cables and struts to make the things work.
They had small tailwheels on them to keep the tips of the ground. The
whole setup seemed to work fine.
Wish I knew where I could find that article.
Dan
Old September 23rd 06, 07:08 PM posted to rec.aviation.homebuilt
Charlie[_1_]
be? g
crossed! Or
like the Air-Cam.
no pitch change.
Hi Earnest. Is this thread dead yet?
I had this brilliant idea about a decade ago for a very low drag amphib
by building the cleanest fuselage possible aerodynamically (sealed to
water so it would float, of course), then use a retractable hydrofoil to
lift the hull out of the water & onto plane. I was really impressed with
myself until I saw an article about a NASA experiment 2 or 3 decades ago
where they tried it, both with 'airfoil' shaped foils & with wedge
shaped foils, using a Lake amphib as the test bed. IIRC, it worked fine
& allowed the plane to operate in significantly higher waves
(something like 2 feet) than it was designed for.
Charlie
Insurance out of hand? - AOPA flying clubs high perf retractable Ron Piloting 4 February 18th 05 08:40 AM
Insurance requirements out of hand? - AOPA high perf retractable for Flying Clubs ron Piloting 6 February 16th 05 03:33 AM
floats coming on and off Robert M. Gary Piloting 9 August 16th 04 08:26 PM
floats el gran cantinflas Rotorcraft 4 May 24th 04 06:19 AM
Pop out floats on a 206BIII Mike Th... Rotorcraft 23 September 6th 03 10:16 AM
