Morgans wrote:
"Ernest Christley" wrote Well, it was until you showed how it is clearly impossible 8*) Actually, the original post wasn't asking about putting floats on a Delta, I was just saying that the mechanism chosen by John Dyke might possibly be a solution for retracting floats. If I were to pick a solution for floating a Delta, I'd change to a rear mounted ducted fan engine and seal the belly. Humm, what about CG issues? Are you going to put the people way up in the nose, or just add a large chunk of concrete where the engine used to be? g As for all the aerodynamic effects or moving around a large portion of the airplane, you weren't expecting a fully engineered solution in an off-hand internet post, were you? Well, from you, I expected nothing less, than an engineered design modification plan, with all of the "t's" dotted, and the "i's" crossed! Or something like that! ;-)) You set the bar much to high. CG issue. It would have to be a nearly complete re-design, moving the pilot really far forward with his feet crammed up into the nose, much like the Air-Cam. It's worth noting that the wheels on the Delta cause a nose-down vector when in the down position. This goes away when they're retracted, but is compensated for by the CG shift aft just slightly. The net effect is no pitch change. Many of the aerodynamic issues you brought up earlier could be dealt with a combination of choosing different lengths for the front and rear legs, and having the floats retract behind a stationary faring. I'll work out some exact numbers some day AFTER I get the current one flying with boring wheels 8*) |
![]() Long ago I came across an article in an aviation magazine describing (and having photos of) a set of "retractable" floats on a Cub. These were pivoted on fore-and-aft pins at the mains so that they swung outward far enough to give the wheel (which was still there and fit into a well in the float when the float was down) access to the surface. There were various cables and struts to make the things work. They had small tailwheels on them to keep the tips of the ground. The whole setup seemed to work fine. Wish I knew where I could find that article. Dan |
Ernest Christley wrote:
Morgans wrote: "Ernest Christley" wrote Well, it was until you showed how it is clearly impossible 8*) Actually, the original post wasn't asking about putting floats on a Delta, I was just saying that the mechanism chosen by John Dyke might possibly be a solution for retracting floats. If I were to pick a solution for floating a Delta, I'd change to a rear mounted ducted fan engine and seal the belly. Humm, what about CG issues? Are you going to put the people way up in the nose, or just add a large chunk of concrete where the engine used to be? g As for all the aerodynamic effects or moving around a large portion of the airplane, you weren't expecting a fully engineered solution in an off-hand internet post, were you? Well, from you, I expected nothing less, than an engineered design modification plan, with all of the "t's" dotted, and the "i's" crossed! Or something like that! ;-)) You set the bar much to high. CG issue. It would have to be a nearly complete re-design, moving the pilot really far forward with his feet crammed up into the nose, much like the Air-Cam. It's worth noting that the wheels on the Delta cause a nose-down vector when in the down position. This goes away when they're retracted, but is compensated for by the CG shift aft just slightly. The net effect is no pitch change. Many of the aerodynamic issues you brought up earlier could be dealt with a combination of choosing different lengths for the front and rear legs, and having the floats retract behind a stationary faring. I'll work out some exact numbers some day AFTER I get the current one flying with boring wheels 8*) Hi Earnest. Is this thread dead yet? I had this brilliant idea about a decade ago for a very low drag amphib by building the cleanest fuselage possible aerodynamically (sealed to water so it would float, of course), then use a retractable hydrofoil to lift the hull out of the water & onto plane. I was really impressed with myself until I saw an article about a NASA experiment 2 or 3 decades ago where they tried it, both with 'airfoil' shaped foils & with wedge shaped foils, using a Lake amphib as the test bed. IIRC, it worked fine & allowed the plane to operate in significantly higher waves (something like 2 feet) than it was designed for. Charlie |
Insurance out of hand? - AOPA flying clubs high perf retractable | Ron | Piloting | 4 | February 18th 05 08:40 AM |
Insurance requirements out of hand? - AOPA high perf retractable for Flying Clubs | ron | Piloting | 6 | February 16th 05 03:33 AM |
floats coming on and off | Robert M. Gary | Piloting | 9 | August 16th 04 08:26 PM |
floats | el gran cantinflas | Rotorcraft | 4 | May 24th 04 06:19 AM |
Pop out floats on a 206BIII | Mike Th... | Rotorcraft | 23 | September 6th 03 10:16 AM |
