![]() you are definately in need of a laxative. If you'd ever flown an O-200 you would realise that you are wrong. did you know that at 4,000rpm they deliver 150hp. great little engine. Stealth ( O-200 powered) Pilot But running it that RPM would take the TBO down drastically. I grew up in Miami, and used to hang around Tamiami airport. All those Pitts guys used to overspeed their engines like that. And most of them got around 300 hours before they needed to overhaul their engines. Those kinds of RPMs are okay for racing and aerobatics, but be ready for a very early overhaul. |
![]() But running it that RPM would take the TBO down drastically. I grew up in Miami, and used to hang around Tamiami airport. All those Pitts guys used to overspeed their engines like that. And most of them got around 300 hours before they needed to overhaul their engines. Those kinds of RPMs are okay for racing and aerobatics, but be ready for a very early overhaul. Are you sure about the RPM's contribution to the 300 Hr overhaul? I would imagine that crank stress due to gyro maneuvers, and full power climbs followed by immediate power off maneuvers might be a more dominating factor to short time between overhauls. Mike |
On Tue, 19 Sep 2006 10:53:19 -0500, pittss1c
wrote: But running it that RPM would take the TBO down drastically. I grew up in Miami, and used to hang around Tamiami airport. All those Pitts guys used to overspeed their engines like that. And most of them got around 300 hours before they needed to overhaul their engines. Those kinds of RPMs are okay for racing and aerobatics, but be ready for a very early overhaul. Are you sure about the RPM's contribution to the 300 Hr overhaul? I would imagine that crank stress due to gyro maneuvers, and full power climbs followed by immediate power off maneuvers might be a more dominating factor to short time between overhauls. Mike I've also heard that the guys installing 10 to 1 pistons are only getting 300 hours before overhaul. I'm building a Glasair 3, and know some other builders that have done that. It brings the power up to about 330, from 300hp. But to me isn't worth it. It enters into unknowns in regard to engine/propeller harmonics, drastically cuts down on the TBO, and does who knows what to the crank, bearings, and other engine parts. I talked to the late Bob Herendeen about that when he had just finished his G-3, and he said he did nothing to boost the engines power beyond what it was designed for. For reliability. I can only imagine that running up into the RPM's you are talking about could only involve similar stresses to the engine. |
On Tue, 19 Sep 2006 12:11:19 -0400, newsreader
wrote: On Tue, 19 Sep 2006 10:53:19 -0500, pittss1c wrote: But running it that RPM would take the TBO down drastically. I grew up in Miami, and used to hang around Tamiami airport. All those Pitts guys used to overspeed their engines like that. And most of them got around 300 hours before they needed to overhaul their engines. Those kinds of RPMs are okay for racing and aerobatics, but be ready for a very early overhaul. Are you sure about the RPM's contribution to the 300 Hr overhaul? I would imagine that crank stress due to gyro maneuvers, and full power climbs followed by immediate power off maneuvers might be a more dominating factor to short time between overhauls. Mike I've also heard that the guys installing 10 to 1 pistons are only getting 300 hours before overhaul. I'm building a Glasair 3, and know some other builders that have done that. It brings the power up to about 330, from 300hp. But to me isn't worth it. It enters into unknowns in regard to engine/propeller harmonics, drastically cuts down on the TBO, and does who knows what to the crank, bearings, and other engine parts. I talked to the late Bob Herendeen about that when he had just finished his G-3, and he said he did nothing to boost the engines power beyond what it was designed for. For reliability. I can only imagine that running up into the RPM's you are talking about could only involve similar stresses to the engine. 2500 continuous and 2750 rpm tops is set where it is because engines that loaf along at that get to TBO. TBO -time between overhauls- is a certified engine concept. take the engine over 2750 and there is no TBO because you have just negated the certification requirements. What I was getting to with brown eyes is that the engine is capable of doing a lot more than the pedestrian RPM's that get you the 2000 hours between teardowns. If you want the rpm's and the hp then accept that you are now driving an experimental engine with no known service history. ....which really is no different from his much loved car engines. Stealth Pilot |
![]() If you'd ever flown an O-200 you would realise that you are wrong. did you know that at 4,000rpm they deliver 150hp. great little engine. Stealth ( O-200 powered) Pilot But running it that RPM would take the TBO down drastically. I grew up in Miami, and used to hang around Tamiami airport. All those Pitts guys used to overspeed their engines like that. And most of them got around 300 hours before they needed to overhaul their engines. Those kinds of RPMs are okay for racing and aerobatics, but be ready for a very early overhaul. I believe that the Formula 1 racers generally got less TBO than that. I have no idea how much of that was overspeed vs how much was high power; but I am pretty sure that an overspeed of 33% on a certified aircraft would require an overhaul--regardless of the duration. Some of the regular posters are sure to know the rules on that. Peter |
Hard Starting Cold Continental Engines | M.E. Borner | Owning | 16 | December 6th 05 04:13 AM |
Continental IO-520A operating data? | Michael | Owning | 7 | November 26th 04 08:38 PM |
Continental A65-8 engines on EBAY | [email protected] | Aviation Marketplace | 0 | November 16th 04 04:30 AM |
Continental Airlines Complaint - A Newspaper article | John B. | Piloting | 40 | October 21st 03 04:07 PM |
Continental IO-360 question | Jeff P | Owning | 0 | September 21st 03 08:03 PM |
