mike regish writes:
Yes. The rudder pedals move with aileron control inputs. And yes, they can be moved independently of the ailerons due to the spring configuration. So they move, but you can feel the movement and override it if you want? I guess that's okay. I have an aversion to true fly-by-wire systems, but if you know what it's doing and you can override it, it's probably still safe. It makes slipping down final in a crosswind a little more difficult since you have the usual control forces due to aerodynamic pressure plus the pressure applied by the springs. That's why I prefer to crab down final and straighten out just before the wheels touch down. That's also easier on the passengers. The crabbing technique is the only one I've tried in the sim thus far. It was impossible with just a keyboard; adding a joystick made it possible, although it's not easy. A J-3 is a Piper Cub. Thanks. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: mike regish writes: Yes. The rudder pedals move with aileron control inputs. And yes, they can be moved independently of the ailerons due to the spring configuration. So they move, but you can feel the movement and override it if you want? I guess that's okay. I have an aversion to true fly-by-wire systems, but if you know what it's doing and you can override it, it's probably still safe. You can feel it slightly. However it takes very little effort to override it by pressing the rudder. Actually, in my Mooney is gives a bit too much rudder such that I give a little bit of outside rudder when I roll into a turn. This works the same as your Cessna nosewheel vs rudder. On the ground the rudder on the Cessna is a little harder to press because you are moving the tire against the pavement but you can still get rull deflection of the rudder. -Robert |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
1-34 Rudder | DGRTEK | Soaring | 23 | February 16th 04 04:36 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
