Continental O-200 ?
Old September 21st 06, 01:55 AM posted to rec.aviation.homebuilt
Jerry Springer
Default Continental O-200 ?
Bret Ludwig wrote:
Stealth Pilot wrote:
snip
totally clueless nonsense brown eyes.
aircraft have a pressure plenum. almost no aircooled aircraft engine
are free cooled engines. everything with a cowling uses the very
effective technique of the pressure plenum.
I'd suggest you learn about them.
Stealth Pilot
The pressure plenum using ram air works at a given narrow range of
power settings, airspeeds and outside temperature. Ever see what
happens when a turbo Bonanza pilot at cruise pulls the power back and
puts the nose down into the yellow arc? CRACK!!!!! go the jugs!
PFM, although they had other problems, figured correctly that a blower
with well-designed thermostatic controls worked a lot better. You
couldn't shock cool one.
The old Connies, DC7s, etc. did very well with sophisticated cowlings
and high delta heat air cooled cylinder heads. But they were not
aerobatic, had a flight engineer just to run the power plants, like a
submarine, and the only sudden descents they dealt with were if they
had a cabin depressurization. If that happened they didn't bitch that
loudly at swapping out all four before the next flight-they swapped
engines all the time at the ramp with passengers watching in those
days.
If the massive death count of the Bonanza tells us anything, besides
that Beech management should have been shot at sundown on the ramp off
Webb Rd, it' s that single pilot IFR needs single lever power control.
Stupid, stupid, ignorant person.
Old September 21st 06, 05:48 PM posted to rec.aviation.homebuilt
Bret Ludwig
Jerry Springer wrote:
snip
Yes you are, as you insist on proving repeatedly. Go back to your
freak show on TV you load.
Old September 22nd 06, 01:46 AM posted to rec.aviation.homebuilt
Jerry Springer
snip
Pudwig, the things you write here over and over show that you are an
ignorant person. You are not smart enough to build your own airplane and
find fault with anyone that does design and built airplanes. What a
pathetic life you must live. You are not even smart enough to quote
enough of the previous message so people well know what you are talking
about. As I said YOU are a stupid, stupid person.
Old September 22nd 06, 10:47 AM posted to rec.aviation.homebuilt
Stealth Pilot
On Fri, 22 Sep 2006 00:46:26 GMT, Jerry Springer
snip
he certainly hasnt realised why I use the brown eyes comment :-)
Stealth Pilot
Hard Starting Cold Continental Engines M.E. Borner Owning 16 December 6th 05 04:13 AM
Continental IO-520A operating data? Michael Owning 7 November 26th 04 08:38 PM
Continental A65-8 engines on EBAY [email protected] Aviation Marketplace 0 November 16th 04 04:30 AM
Continental Airlines Complaint - A Newspaper article John B. Piloting 40 October 21st 03 04:07 PM
Continental IO-360 question Jeff P Owning 0 September 21st 03 08:03 PM
