![]() Mike the Strike wrote: Fred: You should really check your facts before posting twaddle! Clearly I should have said to ask any physicist or astronomer who is conversant with atmospheric refraction, which you clearly are not. Because of variations in refraction, sunset (the time when the limb of the sun becomes invisible to an observer) may vary by several minutes from that calculated by the accepted formula. This formula assumes a constant refraction that is unlikely to be exact for any specific place or time. Mike This is like the advice from the old joke about the guys who get lost in a balloon, then ask someone on the ground where they are, and the person on the ground tells them they are up in the air in a balloon. The joke is that the person on the ground must be a lawyer, beacuse his answer was technicaly correct, but totally useless. Same goes for actual sunset. Unless you are on a ship at sea, you won't have a clear level horizon to observe actual sunset. So the refraction issue is moot. And if you wait until you observe actual sunset in flight, the sun will have already set on the ground. The predicted sunset time is the only thing relevant for flight planning. |
Doug Haluza wrote:
The predicted sunset time is the only thing relevant for flight planning. It is interesting that part 61 and part 91 define regulations that refer to sunrise and sunset but that the FAA provides no definition of what those terms mean. At least I couldn't find those definitions. I expected to find them in part 1. I used to fly a lot in an Aerona Chief that did not meet night lighting requirements. A sunrise/sunset time table was always available for flight planning, but I don't know if it agreed with whatever time table FAA was using. I once landed a minute before sunset (according to my table) after an xc flight and was still in motion on the airport after sunset. Neither tower nor ground control expressed any concern. I know I can call flight service and ask for sunset time for my local airport. Their reply is "I can give you sunset for Phoenix, is that close enough?" If I say yes, does that become the offical sunset time for my local airport? Given the uncertainty of the actual official sunset time I repeat my request that SAA's sunset time be used only to determine the "end of soaring flight" and not used to determine the validity of the entire flight. Andy |
Andy wrote:
Given the uncertainty of the actual official sunset time I repeat my request that SAA's sunset time be used only to determine the "end of soaring flight" and not used to determine the validity of the entire flight. I like that suggestion. What about it Doug? Jack |
Hi Andy,
"Andy" wrote in message oups.com... Doug Haluza wrote: The predicted sunset time is the only thing relevant for flight planning. It is interesting that part 61 and part 91 define regulations that refer to sunrise and sunset but that the FAA provides no definition of what those terms mean. At least I couldn't find those definitions. I expected to find them in part 1. I used to fly a lot in an Aerona Chief that did not meet night lighting requirements. A sunrise/sunset time table was always available for flight planning, but I don't know if it agreed with whatever time table FAA was using. I once landed a minute before sunset (according to my table) after an xc flight and was still in motion on the airport after sunset. Neither tower nor ground control expressed any concern. I know I can call flight service and ask for sunset time for my local airport. Their reply is "I can give you sunset for Phoenix, is that close enough?" If I say yes, does that become the offical sunset time for my local airport? Given the uncertainty of the actual official sunset time I repeat my request that SAA's sunset time be used only to determine the "end of soaring flight" and not used to determine the validity of the entire flight. Andy I must respectfully disagree. If we just use sunset as the end of soaring flight that gives an unfair advantage to a pilot that is far from home or at altitude when the sun sets. He/she should have planned ahead and landed on time. Paul Remde |
Isn't it exactly the same "advantage" any motorglider has when they
start the engine far from home and get scored up to that point? Andy's suggestion will allow pilots to land back home safely few minutes after sunset if necessary rather then land out to get scored, or fly back home and don't get scored at all... Ramy Paul Remde wrote: Hi Andy, I must respectfully disagree. If we just use sunset as the end of soaring flight that gives an unfair advantage to a pilot that is far from home or at altitude when the sun sets. He/she should have planned ahead and landed on time. Paul Remde |
![]() Ramy wrote: Isn't it exactly the same "advantage" any motorglider has when they start the engine far from home and get scored up to that point? Andy's suggestion will allow pilots to land back home safely few minutes after sunset if necessary rather then land out to get scored, or fly back home and don't get scored at all... No it's not the same. The MG is not breaking a FAR by starting the engine. Flying a sailplane after sunset without position lights is ILLEGAL. Time and position is something our FRs measure quite accurately, and "official" sunset is available before the flight. There is no excuse or "fudge factor" as is possible within some limits on altitude and SUA penetration. Until recently, I was unaware of the difference between "night flight" and need for position lights, so thought it was OK to fly until 30 minutes beyond sunset. I now know it is not. I know I've busted this rule in the past out of ignorance, but not in the last 5-10 years if I recall. As with any law, ignorance is not an excuse, so I would have not hesitated to witdraw a claim that proves a violation on my part. -Tom |
Tom, I was referring to the "competitive advantage" comment by Paul,
not to the legal issue. I think it is unlikely that someone will take advantage of it and plan to land after sunset. But since you mentioned the FAR, not only many pilots such as you and me were not completely aware of it, but the badge and record committe as well as some of the SSA-OLC committe were not aware, and as such many badges and records over the years (including one state record of mine) were approved although landed after sunset. Ramy 5Z wrote: Ramy wrote: Isn't it exactly the same "advantage" any motorglider has when they start the engine far from home and get scored up to that point? Andy's suggestion will allow pilots to land back home safely few minutes after sunset if necessary rather then land out to get scored, or fly back home and don't get scored at all... No it's not the same. The MG is not breaking a FAR by starting the engine. Flying a sailplane after sunset without position lights is ILLEGAL. Time and position is something our FRs measure quite accurately, and "official" sunset is available before the flight. There is no excuse or "fudge factor" as is possible within some limits on altitude and SUA penetration. Until recently, I was unaware of the difference between "night flight" and need for position lights, so thought it was OK to fly until 30 minutes beyond sunset. I now know it is not. I know I've busted this rule in the past out of ignorance, but not in the last 5-10 years if I recall. As with any law, ignorance is not an excuse, so I would have not hesitated to witdraw a claim that proves a violation on my part. -Tom |
It certainly is a competitive advantage for one pilot to be pushing the
envelope on flying to the point where he is potentially forced to violate the FARs vs. another pilot who is planning ahead and flying conservatively enough to make sure that he stays legal. Mike Schumann "Ramy" wrote in message ups.com... Tom, I was referring to the "competitive advantage" comment by Paul, not to the legal issue. I think it is unlikely that someone will take advantage of it and plan to land after sunset. But since you mentioned the FAR, not only many pilots such as you and me were not completely aware of it, but the badge and record committe as well as some of the SSA-OLC committe were not aware, and as such many badges and records over the years (including one state record of mine) were approved although landed after sunset. Ramy 5Z wrote: Ramy wrote: Isn't it exactly the same "advantage" any motorglider has when they start the engine far from home and get scored up to that point? Andy's suggestion will allow pilots to land back home safely few minutes after sunset if necessary rather then land out to get scored, or fly back home and don't get scored at all... No it's not the same. The MG is not breaking a FAR by starting the engine. Flying a sailplane after sunset without position lights is ILLEGAL. Time and position is something our FRs measure quite accurately, and "official" sunset is available before the flight. There is no excuse or "fudge factor" as is possible within some limits on altitude and SUA penetration. Until recently, I was unaware of the difference between "night flight" and need for position lights, so thought it was OK to fly until 30 minutes beyond sunset. I now know it is not. I know I've busted this rule in the past out of ignorance, but not in the last 5-10 years if I recall. As with any law, ignorance is not an excuse, so I would have not hesitated to witdraw a claim that proves a violation on my part. -Tom |
Paul Remde wrote:
I must respectfully disagree. If we just use sunset as the end of soaring flight that gives an unfair advantage to a pilot that is far from home or at altitude when the sun sets. He/she should have planned ahead and landed on time. And exactly which time would that be, Paul? You seem to have lost track of the story so far: Doug wants to be able to pick illegal flights on OLC but he's having trouble deciding which flights are illegal because he doesn't know when it's "sunset" (as 'un'defined in the FARs) at all the places OLC flights go to. Last night two astronomers locked horns and are heading for the jugular over when sunset might be. Now read on: I know this won't help but in Oz the rules a 1. "Night" is the period between the end of evening civil twilight and the beginning of morning civil twilight. 2. CASA (FAA equivalent) publishes beginning and end of daylight graphs for latitudes from 0 to 45 throughout the year. 3. Daylight flight occurs between those times after converting local time to Standard/Daylight Time. Note that daylight "ceases" at a particular longitude solely dependent on its latitude. No allowance for terrain, etc. But the following is also in the AIP: "Users ... should note that the parameters used in compiling the ... Graphs do not include the nature of the terrain ... other than a cloudless sky and unlimited visibility ... Consequently, the presence of cloud cover, poor visibility or high terrain to the west of an aerodrome will cause daylight to end ... earlier than that extracted from the appropriate graph. Allowance should made for these factors when planning a flight..." The rules are reasonable but are no help in maintaining a level playing field for a gliding competition. So, Doug. Make up your mind what arbitrary rule you would like to implement for the SSA-OLC and publish it. Let's say - evening civil twilight at the latitude. Stop using the FAA as an excuse and a crutch. Stand on your own feet. Make a rule. Publish it. Enforce it. Cop the flak. GC |
Hi,
I have a crazy, wild suggestion.... Fly your task so that you land before any known definition of sunset and you will never need to worry. That is what most pilots do. Those that do not are not playing fair - in my opinion. Paul Remde "Graeme Cant" gcantinter@tnodedotnet wrote in message ... Paul Remde wrote: I must respectfully disagree. If we just use sunset as the end of soaring flight that gives an unfair advantage to a pilot that is far from home or at altitude when the sun sets. He/she should have planned ahead and landed on time. And exactly which time would that be, Paul? You seem to have lost track of the story so far: Doug wants to be able to pick illegal flights on OLC but he's having trouble deciding which flights are illegal because he doesn't know when it's "sunset" (as 'un'defined in the FARs) at all the places OLC flights go to. Last night two astronomers locked horns and are heading for the jugular over when sunset might be. Now read on: I know this won't help but in Oz the rules a 1. "Night" is the period between the end of evening civil twilight and the beginning of morning civil twilight. 2. CASA (FAA equivalent) publishes beginning and end of daylight graphs for latitudes from 0 to 45 throughout the year. 3. Daylight flight occurs between those times after converting local time to Standard/Daylight Time. Note that daylight "ceases" at a particular longitude solely dependent on its latitude. No allowance for terrain, etc. But the following is also in the AIP: "Users ... should note that the parameters used in compiling the ... Graphs do not include the nature of the terrain ... other than a cloudless sky and unlimited visibility ... Consequently, the presence of cloud cover, poor visibility or high terrain to the west of an aerodrome will cause daylight to end ... earlier than that extracted from the appropriate graph. Allowance should made for these factors when planning a flight..." The rules are reasonable but are no help in maintaining a level playing field for a gliding competition. So, Doug. Make up your mind what arbitrary rule you would like to implement for the SSA-OLC and publish it. Let's say - evening civil twilight at the latitude. Stop using the FAA as an excuse and a crutch. Stand on your own feet. Make a rule. Publish it. Enforce it. Cop the flak. GC |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 08:11 PM |
