On 21 Sep 2006 10:05:32 -0700, "Bret Ludwig"
wrote: wrote: On 19 Sep 2006 18:03:00 -0700, "Bret Ludwig" - Lycoming BOb - Lycomings suck. So do you. Yada, Yada, yada. Once again,you do nothing but BLOW a stream of nonsense. Certified engines are the established kids on the block, dood. Learn to deal deal with it in a positive way! Your remarks do nothing for the advancement of alternate engine power. I would prefer to fly behind a certified power plant (or in front of one). Pratt and Whitney for instance. I'd rather trust a Lycoming than a Pratt & Whitney. I've been on too many flights where the old Pratt failed. Once a cylinder came right through the cowling. (DC-3 R-1830) And another time the engine sucked a valve (Martin 404 - R-2800) I've never had that happen with a Lycoming. But I have had problems with Continentials.(Beech Debonair) Lycomings are about the best of the recips. |
It's easy to sit on the ground and dream about developing and flying
in an "alternate" aircraft engine. But when airborne, in a homebuilt is not the time to mess around with these types of engines. As they say, it's better to be on the ground, wishing you were in the air, than to be in the air, wishing you were on the ground. |
![]() newsreader wrote: It's easy to sit on the ground and dream about developing and flying in an "alternate" aircraft engine. But when airborne, in a homebuilt is not the time to mess around with these types of engines. IOW there is no time to "mess around with" anything that is not a certified aircraft engine. If everyone thought like that the OX-5 would still be the "proven" aircraft engine. By now they would probably have the old beast putting out 300-400 hp and getting a whopping 500 hour TBO. Stick with certified engines in CERTIFIED AIRCRAFT, with TWO (or three or four) certified engines and a TWO MAN CREW. People like you make good airline pilots but belong nowhere near single engine single pilot aircraft. As they say, it's better to be on the ground, wishing you were in the air, than to be in the air, wishing you were on the ground. Worst case scenario: forced landing or bailout. It happens. Rarely. But if you are not prepared to do that DO NOT FLY EXPERIMENTAL AIRCRAFT. The "average person" is not supposed to be flying experimental aircraft. Does the average person build their own motorcycle or car? No they buy one designed, built and tested by trained professionals. You are WATERING DOWN this activity to something safely doable by idiots (with fat bank accounts, mostly from house morgtgages or consumer credit. GOD we need a Depression! Please Allah!!) |
![]() newsreader wrote: On 21 Sep 2006 10:05:32 -0700, "Bret Ludwig" wrote: wrote: On 19 Sep 2006 18:03:00 -0700, "Bret Ludwig" I'd rather trust a Lycoming than a Pratt & Whitney. I've been on too many flights where the old Pratt failed. Once a cylinder came right through the cowling. (DC-3 R-1830) And another time the engine sucked a valve (Martin 404 - R-2800) I've never had that happen with a Lycoming. But I have had problems with Continentials.(Beech Debonair) Lycomings are about the best of the recips. I watched a CFI/CFII/ATP young stud at a FBO I work at lose a O-235-L2C in the pattern and still wind up in a supermarket parking lot. Would have been a beautiful rollout if not for those pesky parking dividers! I also saw an ob/gyn with his wife and four rug rats in a cabin class twin run an engine up and for some stupid reason pull the prop ALL THE WAY BACK at full power. A cylinder on the right side of #2 came off and went through the cowling. If it had been a left hand jug one or more people would have died for certain. Sorry, I'd rather fly a Chevy. |
![]() Bret Ludwig wrote: I watched a CFI/CFII/ATP young stud at a FBO I work at lose a O-235-L2C in the pattern and still wind up in a supermarket parking lot. Would have been a beautiful rollout if not for those pesky parking dividers! I also saw an ob/gyn with his wife and four rug rats in a cabin class twin run an engine up and for some stupid reason pull the prop ALL THE WAY BACK at full power. A cylinder on the right side of #2 came off and went through the cowling. If it had been a left hand jug one or more people would have died for certain. Sorry, I'd rather fly a Chevy. So a ham-handed pilot couldn't bust the Chevy. And a good CFI/CFII/ATP couldn't glide back to the airport unless the dead engine under the cowl was a Chevy. Hmm. I flew a Subaru that burned a valve when the mixture was adjusted to lean for cruise. The 16-valve engines have really slender valves, just about the same size as you'd find in your Briggs & Stratton, and they heat up REALLY fast and will burn instantly if they get a tiny bit too hot. It's one reason they had electronic fuel injection in the car: to protect the engine. I had my son's Suzuki 1.6 Litre 16-valve apart last week, same problem: burned valve, and it had the same tiny little valves. The stem was so small (0.215" ) that the valve grinder chuck would barely close enough to hold onto it. Such small stems don't transfer heat well at high power settings (like in an airplane). Therefore, many auto conversions may run well and smooth and deliver decent power and get good mileage, but they have to be run much more carefully than the old Lyc with it's massive sodium-filled valve stems and thick valve heads. The pilot who blew the jug off his engine likely treated it that way all the time for a long time and it finally bit him. He was asking for detonation and got it, and NO engine would stand for detonation for any length of time. The Lyc or Continental will stand for more abuse, except for shock cooling or persistent really rough power handling. Lycoming, for instance, says that you can lean their normally-aspirated direct-drive engines any way you want when at 75% or less; just try THAT with your Soob or Suzuki. Dan |
![]() Bret Ludwig wrote: I watched a CFI/CFII/ATP young stud at a FBO I work at lose a O-235-L2C in the pattern and still wind up in a supermarket parking lot. Would have been a beautiful rollout if not for those pesky parking dividers! I also saw an ob/gyn with his wife and four rug rats in a cabin class twin run an engine up and for some stupid reason pull the prop ALL THE WAY BACK at full power. A cylinder on the right side of #2 came off and went through the cowling. If it had been a left hand jug one or more people would have died for certain. Sorry, I'd rather fly a Chevy. So a ham-handed pilot couldn't bust the Chevy. And a good CFI/CFII/ATP couldn't glide back to the airport unless the dead engine under the cowl was a Chevy. Hmm. I flew a Subaru that burned a valve when the mixture was adjusted to lean for cruise. The 16-valve engines have really slender valves, just about the same size as you'd find in your Briggs & Stratton, and they heat up REALLY fast and will burn instantly if they get a tiny bit too hot. It's one reason they had electronic fuel injection in the car: to protect the engine. I had my son's Suzuki 1.6 Litre 16-valve apart last week, same problem: burned valve, and it had the same tiny little valves. The stem was so small (0.215" ) that the valve grinder chuck would barely close enough to hold onto it. Such small stems don't transfer heat well at high power settings (like in an airplane). Therefore, many auto conversions may run well and smooth and deliver decent power and get good mileage, but they have to be run much more carefully than the old Lyc with it's massive sodium-filled valve stems and thick valve heads. The pilot who blew the jug off his engine likely treated it that way all the time for a long time and it finally bit him. He was asking for detonation and got it, and NO engine would stand for detonation for any length of time. The Lyc or Continental will stand for more abuse, except for shock cooling or persistent really rough power handling. Lycoming, for instance, says that you can lean their normally-aspirated direct-drive engines any way you want when at 75% or less; just try THAT with your Soob or Suzuki. Dan A lot of good points, Dan, and I would like to add a little: I think a lot of people run their conversions--or proposed conversions--much too fast! That doesn't mean that I have ever completely withdrawn automotive conversions from my consideration. Once you get away from the LSA criteria, some candidates really stand out and some in GM's Vortec series really stand out. However, before I actually undertake such a project, I would very carefully review the portions of Part 23 that pertain to VNE. There are portions of Part 23 where I would probably cut some corners for my probable mission profiles, such as the propeller to ground clearance for a tail wheel type aircraft, but I would not deviate from the VNE definitions--because unusual an attitude recovery could be needed when I least expect it. Obviously, this does not improve the power to weight ration of the conversion. I still like some of them; but it's not a "done deal" and, if it's supposed to be a club project flown by several pilots to be determined later, fuggeddaboudit! Peter |
Hard Starting Cold Continental Engines | M.E. Borner | Owning | 16 | December 6th 05 04:13 AM |
Continental IO-520A operating data? | Michael | Owning | 7 | November 26th 04 08:38 PM |
Continental A65-8 engines on EBAY | [email protected] | Aviation Marketplace | 0 | November 16th 04 04:30 AM |
Continental Airlines Complaint - A Newspaper article | John B. | Piloting | 40 | October 21st 03 04:07 PM |
Continental IO-360 question | Jeff P | Owning | 0 | September 21st 03 08:03 PM |
