![]() Peter Dohm wrote: I noticed in another post that the Continental O-200 is back in new manufacture again. I was the OP, and now see that I can't seem find any specs. They have a phone number posted for additional information on each engine/series and I do plan to follow up. Peter I thank you for passing on the info. best news since christmas. Stealth Pilot I gave them a call today at the number shown on their web site by clicking through to http://tcmlink.com/engines/index.cfm?lsa=yes and learned that: 1) The "old" O-200 is still in production and still available new. 2) The new engine is expected to be called IO-200, and Planned to be available some time next year Planned to be certified for LSA under FAR Part 33 Has a target weight under 200 pounds Has a terget TBO of 2000 hours Other improvements should include crossflow heads, revised oil sump, and electronic ignition. Sounds like the cylinders are similar to the IO-240 and the 6-cylinder IO-360, which are cross-flow engines. Which bore? I'm in agreement with you that an engine with these numbers is a winner, except that what with the high prices of the experimental IO-240 and the experimental O-200, one would expect the IO-200 to bear a hefty price-tag. |
![]() wrote in message ps.com... Peter Dohm wrote: I noticed in another post that the Continental O-200 is back in new manufacture again. I was the OP, and now see that I can't seem find any specs. They have a phone number posted for additional information on each engine/series and I do plan to follow up. Peter I thank you for passing on the info. best news since christmas. Stealth Pilot I gave them a call today at the number shown on their web site by clicking through to http://tcmlink.com/engines/index.cfm?lsa=yes and learned that: 1) The "old" O-200 is still in production and still available new. 2) The new engine is expected to be called IO-200, and Planned to be available some time next year Planned to be certified for LSA under FAR Part 33 Has a target weight under 200 pounds Has a terget TBO of 2000 hours Other improvements should include crossflow heads, revised oil sump, and electronic ignition. Sounds like the cylinders are similar to the IO-240 and the 6-cylinder IO-360, which are cross-flow engines. Which bore? I'm in agreement with you that an engine with these numbers is a winner, except that what with the high prices of the experimental IO-240 and the experimental O-200, one would expect the IO-200 to bear a hefty price-tag. That's how it sounds to me as well, and I do expect that hefty price tag. With the aid of a Google search, I was able to find a list of partial specs at http://www.tcmlink.com/producthighlights/ENGTBL.PDF which shows all of the older engine sizes O-200 through IO-360 having the same stroke, with the O-200 and O-300 having a smaller bore. Therefore, the bore and stroke of the O-200 and O-300 makes the most sense; and even suggests the possibility of an IO-300 in the future. (Remember that you read it here first.) BTW, I forgot to mention in the earlier post that I was also told that they are designing a new oil sump integral with the crank case. The O-300 has had that forever and it does facititate a very sleek cowling. There is a good justification for an FAR Part 33 certified engine and FAR Part 35 certified propeller in that, as I understand it, an appropriately equipped LSA can have Night and IFR within its operating limitations when flown by a qualified pilot and can still be flown Day VFR by a Sport Pilot. Peter |
![]() Peter Dohm wrote: [...] BTW, I forgot to mention in the earlier post that I was also told that they are designing a new oil sump integral with the crank case. The O-300 has had that forever and it does facititate a very sleek cowling. There is a good justification for an FAR Part 33 certified engine and FAR Part 35 certified propeller in that, as I understand it, an appropriately equipped LSA can have Night and IFR within its operating limitations when flown by a qualified pilot and can still be flown Day VFR by a Sport Pilot. Peter Thanks, Peter, for your splendid commentary and data provided in this thread. It makes wading through RAH worth it. |
Hard Starting Cold Continental Engines | M.E. Borner | Owning | 16 | December 6th 05 04:13 AM |
Continental IO-520A operating data? | Michael | Owning | 7 | November 26th 04 08:38 PM |
Continental A65-8 engines on EBAY | [email protected] | Aviation Marketplace | 0 | November 16th 04 04:30 AM |
Continental Airlines Complaint - A Newspaper article | John B. | Piloting | 40 | October 21st 03 04:07 PM |
Continental IO-360 question | Jeff P | Owning | 0 | September 21st 03 08:03 PM |
