Dress Code
Old September 22nd 06, 11:06 AM posted to rec.aviation.piloting
Larry Dighera
Default Dress Code
On Fri, 22 Sep 2006 05:17:36 GMT, Don Tuite
wrote in
using Agent as my newsreader. your
posts fail to wordwrap. Is that something I can fix on my end?
Select Word Wrap on the View pull-down menu.
Old September 22nd 06, 05:10 PM posted to rec.aviation.piloting
Don Tuite
Default Dress Code
On Fri, 22 Sep 2006 10:06:25 GMT, Larry Dighera
wrote in
Thanks. It's actually in the "Message" PD Window, and it doesn't
affect Jose's posts.
Don
Old September 22nd 06, 06:38 PM posted to rec.aviation.piloting
Larry Dighera
Default Dress Code
On Fri, 22 Sep 2006 16:10:37 GMT, Don Tuite
wrote in
wrote in
That's probably because you are running a newer version than me.
and it doesn't affect Jose's posts.
It should wrap the text to the right boundary of the message pane,
instead of forcing you to use the horizontal scroll bar at the bottom
of the pane to view the end of his lines.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Run up for plug clearing Roger Long Piloting 78 October 18th 04 03:39 AM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
Need Help with Northstar M1 Loran Jerald Malin Owning 4 December 8th 03 05:38 PM
