Fuel tank balance
Old September 23rd 06, 11:02 PM posted to rec.aviation.piloting,rec.aviation.student
Roy Smith
Default Fuel tank balance
In article xwhRg.1082$Rp3.261@dukeread12, "new_CFI"
as far as left/right/both/off, normaly you set it on both and forget it.
some planes have left/right/off, I alternate every 15 min.
Every 15 minutes? That seems a bit excessive. Once an hour should keep
things pretty much in balance. If you want to get fancy, do your first
switch after a half hour, then every hour after that.
On a long flight, keeping track of fuel is more than just mindlessly
switching tanks every so often. As an example, on a recent flight I took,
we started out with 72 gallons usable, burned about 16 gph in cruise. The
POH prohibits takeoffs on any tank less than 1/4 full.
We had about 3 hours to our destination, at which there was no fuel
available; we had another 1/2 hour hop to someplace with fuel on the way
back.
We burned one tank down to 20 gallons, then from the other one for the rest
of the 3 hour leg. When we had our destination in sight, we switched to
the fuller tank for the landing. We took off again on that fuller tank,
and switched back to the lower one most of the 1/2 hop to where we could
get fuel, then switch back to the fuller one again in the pattern and
landed on that. This make sure that on both landings, we were running off
a tank that was just a little under half full, so we wouldn't have any
problems if we needed to do a go-around. It also mean that if we landed at
our fuel spot and discovered we couldn't get any fuel for some unexpected
reason, we still had a half-full tank to take off on again.
Moral: I'd rather have one half-full tank and one almost empty one than
have two that are 1/4 full.
Old September 24th 06, 01:07 AM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley[_2_]
"Roy Smith" wrote in message
I switch every 1/2 hour, on the 1/2 hour. I burn from the left tank when the
minute hand is on the left side of the clock (30 - 59 minutes past the
hour), and the right tank when the minute hand is on the right side of the
clock (0 - 29 minutes past the hour). That way I can tell by looking if I
remembered to switch tanks.
The least I've ever landed with was 14 gallons (out of 50). That was 2 legs.
Old September 24th 06, 04:36 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Steve,
when the
minute hand
What'S that? ;-)
Otherwise, nice trick.
Thomas Borchert (EDDH)
Old September 24th 06, 04:39 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley[_2_]
"Thomas Borchert" wrote in message
Steve,
when the
minute hand
What'S that? ;-)
That's the thing I forget to wind prior to each flight g
Old September 24th 06, 01:29 AM posted to rec.aviation.piloting,rec.aviation.student
new_CFI[_1_]
well, for me, more often is easter to remember. And on those long flights,
its the only thing to do.... unless you have a ADF and can find a good AM
station.
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 06:13 PM
C-172 Fuel [email protected] Piloting 23 November 23rd 05 09:39 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
First flight tests of systems to mitigate fuel tank explosions Peter Duniho Piloting 1 July 16th 03 10:49 PM
