Steve Foley writes:
Please cite the FAA regs. It's not an FAA regulation, it's just a fact of using a parachute. You don't just slip one on and jump. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Mxsmanic" wrote in message
... Steve Foley writes: Please cite the FAA regs. It's not an FAA regulation, it's just a fact of using a parachute. You don't just slip one on and jump. You do if the plane is on fire. |
Steve Foley writes:
You do if the plane is on fire. You can jump without a parachute if the plane is on fire, too; the results will be much the same, if you have no parachute training. This is a key reason why parachutes are not present in civilian aircraft. Most passengers don't have the training necessary to use them. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic,
You can jump without a parachute if the plane is on fire, too; the results will be much the same, if you have no parachute training. And again, you go on about something you are utterly clueless about. You are wrong. This is a key reason why parachutes are not present in civilian aircraft. Most passengers don't have the training necessary to use them. No, it is not. Parachutes are not present, because they aren't needed. In gliders, the risk of a mid-air is much higher, so they are often issued - to untrained passengers as well. Training consists of "pull here". It's all that's needed. -- Thomas Borchert (EDDH) |
Exposed Electrical Wires in Boeing 737 Fuel Tanks! | Larry Dighera | Piloting | 0 | July 17th 06 06:13 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
C-172 Fuel | [email protected] | Piloting | 23 | November 23rd 05 09:39 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
First flight tests of systems to mitigate fuel tank explosions | Peter Duniho | Piloting | 1 | July 16th 03 10:49 PM |
