![]() Ron Natalie wrote: Robert M. Gary wrote: But not if the course reversal is a hold right? Nope, the 480 does exactly one turn around the hold (unless you press SUSP then it sits there and goes around until you release it). Intertesting. The G1000 is not that good. It crosses the hold and puts a message above the attitude suggesting an entry. Once it crosses the hold it goes into suspend mode and then puts the hold at the top of the sequence. As a result, it crosses the holding fix and then tries to do a 180 to get back to the fix. As a result, it just wonders around. The expectation is that you will engage "heading" mode in the autopilot. However, once you turn back final inbound, it does automatically unsuspend and sequence after recrossing the holding fix. If you want multiple holds you have to manually suspend it again. -robert |
Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 07:00 PM |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
Loading luggage in other than Mooney | Robert M. Gary | Piloting | 21 | June 28th 04 06:23 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 8th 03 11:35 PM |
