Earlier this summer I was seriously considering an EI analyzer and asked
for more details. Here's the answer along with an estimate of labor hours: ----------------------------- 1. In regards to the UBG-16, the long-term memory of the "Normalized" mode can be used without the MUX-8A data recorder if you choose to. The "Normalized" mode is the mode in which you can graphically compare current operating temps derived from the Lean mode with previous temperatures at the same configuration. This is extremely useful in identifying trending temperatures. If a CHT or EGT start to drift from what they were prior you will immediately spot it and hopefully avoid serious engine damage. The MUX-8A is an 8 channel "black box" that outputs to a PC or laptop. I feel it is a worth while install, it's quick, included in the packages, and its extremely useful. 2. UBG-16 is roughly going to take 4-10 hours, possibly slightly more, for a typical four cylinder. Installer experience and aircraft specific challenges are going to be the biggest factor here. 3. Part# UBG-16-4 MEM includes 4-EGT Probes, 4-CHT Probes, Extension thermocouples, and the MUX-8A data recorder. ( You get a free oil, carb, or OAT probe as well as a rebate!) 4. Part# FM-FLOW can be ordered free as part of the UBG-16 rebate as well as the free probe. This will report gal. p/hr. on the UBG-16. If you would prefer a totalizer instrument with GPS interaction the FP-5L can be purchased as a rebate for $269.00 (normally $778.00) 5. The UBG-16 is configurable to compliment your existing panel. The unit is designed to accept up to 16 inputs of your choosing. Or you can simply run just EGT/CHT on it. It is completely up to you. I see a lot of people adding RPM, volts/amps, and fuel or oil pressure. The indication on older equipment just isn't as reliable as what is available today. Plus, any function you choose to add to the UBG-16 will output to the MUX-8A recorder. ---------------------- Installation would be in an O-360 in a cherokee. Hope this helps. 4-10 hours @ $50-70/hr becomes $200-700 for the install. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
