Ray Andraka wrote:
It took me about 20 hours to install an EDM-700 with EGT,CHT,oil temp, and carb temp probes on my Cherokee Six. It isn't hard work, just very time consuming. If you are at all handy, I'd suggest you find a mechanic that will let you do the install under his supervision. You'll get it in the way you want it, learn stuff about your plane and save some money (well if you don't count the value of your time anyway). I should add, that 20 hours included the time to remove the existing single cylinder EGT, move the clock, move the autopilot switches and 2 circuit breakers, cut the panel and make a 2-1/4 instrument overlay, and fabricate and install and wire a new subpanel for the relocated circuit breakers plus the new one for the monitor. My EDM-700 is installed where the spare fuses once were, which were replaced by the switches and breakers when the AP and strikefinder were installed. Without that panel work, it would probably have been about 12 hours to pull all the wires, install the sensors, add the circuit breaker and connect it all up. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
