cost to install engine analyzer (4 cyl)?
Old October 2nd 06, 12:29 AM posted to rec.aviation.owning
Ray Andraka
Default cost to install engine analyzer (4 cyl)?
Denny wrote:
On a low compression, low horsepower, carbureted engine, a fancy
analyzer is only going to waste your money and make you frustrated...
denny
I disagree. It'll pay for itself the first time your engine hiccups.
Mine paid for itself within the first 20 hours it was installed. I had
a situation (new engine) where the engine would get rough at the top of
the climb as soon as you pulled the throttle back. The engine monitor
showed that the #1 cylinder was going cold when that happened, which
pointed exactly where to look for the problem.
A year later, I had one cylinder that was suddenly getting lean too
quickly. The monitor told me exaclty where to look for an intake leak,
which was found within 10 minutes of pulling off the cowl.
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
