NW_Pilot schrieb:
for a few hundred miles with only a compass. Now when the only approach you have is an NDB and the indicator don't work hahahaha!!! Trust me you don't want to be there it's not fun but, I trust you. All I said is that there are all the backup instrument needed to keep the plane flying. Now if your mission *relies* on electronic navigation aids, then it's a good idea to have such a backup handy. But not all missions rely on them, so I don't see the need to add them by default. Stefan |
Stefan wrote in
: Not that I want to excuse those system failures the least bit, and not that I would not have an adrenaline rush in that situation, but there *are* manual back ups for the critical items! At least in those planes I've seen so far, there has always been a "steam" AI, a "steam" ASI, a "steam" altimeter and a whisky compass. You can perfectly fly in IMC with this equipment. Sure, you can keep the plane aloft, but how would you navigate or fly an approach? By the compass and Dead Reckoning? I guess it's not that much different than an alternator / battery failure. But I think a total electrical system failure is pretty rare. And while often missed, there are warning signs that can give you advance warning of an impending electrical failure so that you can get to safety (VFR or on the ground) before you are left without effective navigation instruments (VOR, GPS, etc.). You can even control the amount of time you have by reducing consumption (ie: turning stuff off) and saving it for the necessary phases of your flight. Sensors fail frequently by comparison. Hell - fuel system sensors fail so frequently that every pilot I know checks his fuel level visually because the fuel sensors can't be trusted. There are even discussions about whether a fuel sensor that reads empty all the time is legally considered failed! There is built-in redundancy in the airplane electrical system - you have an alternator and a battery. Having your redundant electrical system essentially undermined by a poorly designed glass panel that fails completely when any one sensor misbehaves is unfortunate at best, and is added risk that seems unjustifiable. |
On Mon, 2 Oct 2006 12:47:44 -0700, "NW_Pilot"
wrote in : After sitting for 70 hours on Cessna version of the G1000 Scares the hell out of me and it takes a lot to scare me! To many bugs and failure in 70 hours of flight! Look at my finial day the Tach. even failed! Was that a mechanical tach? I would write a report of your experience detailing the equipment failures that occurred, and politely and respectfully send copies to Cessna and Garmin. If you word it, so that it contains implicit references to their exposure to civil liability, and express your disappointment with the performance of their products, who knows how they may respond. They may try to appease you with a perk or two. If not, forward the report to AOPA, FSDO, and AvWeb. :-) |
![]() "Larry Dighera" wrote in message ... On Mon, 2 Oct 2006 12:47:44 -0700, "NW_Pilot" wrote in : After sitting for 70 hours on Cessna version of the G1000 Scares the hell out of me and it takes a lot to scare me! To many bugs and failure in 70 hours of flight! Look at my finial day the Tach. even failed! Was that a mechanical tach? I would write a report of your experience detailing the equipment failures that occurred, and politely and respectfully send copies to Cessna and Garmin. If you word it, so that it contains implicit references to their exposure to civil liability, and express your disappointment with the performance of their products, who knows how they may respond. They may try to appease you with a perk or two. If not, forward the report to AOPA, FSDO, and AvWeb. :-) Larry, That's a great Idea and the Tach. was part of the G1000 system I am not sure of the cause of the failure did not hang around in Beirut long enough to find out the diagnostics. See Photo http://www.alexisparkinn.com/photoga...ch_Failure.jpg |
Larry Dighera writes:
I would write a report of your experience detailing the equipment failures that occurred, and politely and respectfully send copies to Cessna and Garmin. If you word it, so that it contains implicit references to their exposure to civil liability, and express your disappointment with the performance of their products, who knows how they may respond. They may try to appease you with a perk or two. If not, forward the report to AOPA, FSDO, and AvWeb. :-) Most software licenses disclaim all responsibility for everything except an unreadable CD, although these disclaimers have never been thoroughly tested in court, as far as I know. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Recently, Mxsmanic posted:
Larry Dighera writes: I would write a report of your experience detailing the equipment failures that occurred, and politely and respectfully send copies to Cessna and Garmin. If you word it, so that it contains implicit references to their exposure to civil liability, and express your disappointment with the performance of their products, who knows how they may respond. They may try to appease you with a perk or two. If not, forward the report to AOPA, FSDO, and AvWeb. :-) Most software licenses disclaim all responsibility for everything except an unreadable CD, although these disclaimers have never been thoroughly tested in court, as far as I know. The kind of software that you're using isn't likely to get you killed. This is a different ballgame altogether. Neil |
Mxsmanic wrote in
: Most software licenses disclaim all responsibility for everything except an unreadable CD, although these disclaimers have never been thoroughly tested in court, as far as I know. Most software licenses are not certified by the FAA. Software that is certified by a regulatory organization typically is held to a bit of a higher standard than the desktop software pushed out by Microsoft. Another good example is FDA certified software in the Pharmacuetical industry. They too have a CFR much like aviation does, and have rigorous standards for testing and certification before any change can be made. |
![]() Larry Dighera wrote: Was that a mechanical tach? I would write a report of your experience detailing the equipment failures that occurred, and politely and respectfully send copies to Cessna and Garmin. If you word it, so that it contains implicit references to their exposure to civil liability, and express your disappointment with the performance of their products, who knows how they may respond. They may try to appease you with a perk or two. If not, forward the report to AOPA, FSDO, and AvWeb. :-) And a NASA Report. -- Gene Seibel Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html Because we fly, we envy no one. |
So, the uncommanded FIS rebooting was a known issue, and both manufactures chose to release their products for use? Money talks. I hope the premiums are paid current on their errors and omissions insurance policies. Software seems to be mysteriously immune to this sort of lawsuit. -- Transpose mxsmanic and gmail to reach me by e-mail. |
NW_Pilot writes:
When on the phone with Cessna engineering and Garmin support they said they had a similar problem during stalls and slow flight. I guess reboots are to be expected during stalls and slow flight, given how incredibly rare and improbable these things are, eh? -- Transpose mxsmanic and gmail to reach me by e-mail. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
