NW_Pilot's Trans-Atlantic Flight -- All the scary details...
Old October 2nd 06, 08:47 PM posted to rec.aviation.piloting
NW_Pilot
Default NW_Pilot's Trans-Atlantic Flight -- All the scary details...
"Larry Dighera" wrote in message
On Mon, 2 Oct 2006 11:47:43 -0700, "NW_Pilot"
wrote in
When on the phone with Cessna engineering and
Garmin support they said they had a similar problem
during stalls and slow flight.
So, the uncommanded FIS rebooting was a known issue, and both
manufactures chose to release their products for use? One would have
thought Cessna would have learned not to do that from their seat-rail
issue. I hope the premiums are paid current on their errors and
omissions insurance policies.
Yea, its a scary thought! The G1,000 System is nice when it works "Great IFR
platform for situational awareness" But they do need some manual back up of
some critical items for safe IFR flight. I know I would not fly into IFR
conditions in a G1000 equipped airplane with my family or a passenger on
board. After sitting for 70 hours on Cessna version of the G1000 Scares the
hell out of me and it takes a lot to scare me! To many bugs and failure in
70 hours of flight! Look at my finial day the Tach. even failed!
Old October 2nd 06, 08:55 PM posted to rec.aviation.piloting
Gig 601XL Builder
"NW_Pilot" wrote in message
IFR platform for situational awareness" But they do need some manual back
up of some critical items for safe IFR flight. I know I would not fly into
IFR conditions in a G1000 equipped airplane with my family or a passenger
on board. After sitting for 70 hours on Cessna version of the G1000 Scares
the hell out of me and it takes a lot to scare me! To many bugs and
failure in 70 hours of flight! Look at my finial day the Tach. even
failed!
I think you did good. This whole adventure and your handling of it has IMHO
wiped away the stain on your reputation that was the 150 roll.
Old October 2nd 06, 09:04 PM posted to rec.aviation.piloting
Stefan
Not that I want to excuse those system failures the least bit, and not
that I would not have an adrenaline rush in that situation, but there
*are* manual back ups for the critical items! At least in those planes
I've seen so far, there has always been a "steam" AI, a "steam" ASI, a
"steam" altimeter and a whisky compass. You can perfectly fly in IMC
with this equipment.
Hardly a critical item.
Stefan
Old October 2nd 06, 09:47 PM posted to rec.aviation.piloting
NW_Pilot
"Stefan" wrote in message
into IFR conditions in a G1000 equipped airplane with my family or a
passenger on
"steam" altimeter and a whisky compass. You can perfectly fly in IMC with
this equipment.
Stefan
I would not say perfectly you can hold straight and level and do climbs and
descents but without a reliable source of navigation except for a compass
(which has it's errors) and the deviations in Greenland area can be as much
as 40 degrees then add the wind correction makes for challenging navigation
for a few hundred miles with only a compass. Now when the only approach you
have is an NDB and the indicator don't work hahahaha!!! Trust me you don't
want to be there it's not fun but, it is a rush up until the moment you turn
on your portable gps and it downloads your present position and draws a line
to the nearest airport 200+ miles away!
Old October 2nd 06, 10:22 PM posted to rec.aviation.piloting
Stefan
I trust you. All I said is that there are all the backup instrument
needed to keep the plane flying. Now if your mission *relies* on
electronic navigation aids, then it's a good idea to have such a backup
handy. But not all missions rely on them, so I don't see the need to add
them by default.
Stefan
Old October 3rd 06, 01:42 PM posted to rec.aviation.piloting
Judah
Stefan wrote in
Sure, you can keep the plane aloft, but how would you navigate or fly an
approach? By the compass and Dead Reckoning? I guess it's not that much
different than an alternator / battery failure. But I think a total
electrical system failure is pretty rare. And while often missed, there are
warning signs that can give you advance warning of an impending electrical
failure so that you can get to safety (VFR or on the ground) before you are
left without effective navigation instruments (VOR, GPS, etc.). You can
even control the amount of time you have by reducing consumption (ie:
turning stuff off) and saving it for the necessary phases of your flight.
Sensors fail frequently by comparison. Hell - fuel system sensors fail so
frequently that every pilot I know checks his fuel level visually because
the fuel sensors can't be trusted. There are even discussions about whether
a fuel sensor that reads empty all the time is legally considered failed!
There is built-in redundancy in the airplane electrical system - you have
an alternator and a battery. Having your redundant electrical system
essentially undermined by a poorly designed glass panel that fails
completely when any one sensor misbehaves is unfortunate at best, and is
added risk that seems unjustifiable.
Old October 2nd 06, 09:41 PM posted to rec.aviation.piloting
Larry Dighera
On Mon, 2 Oct 2006 12:47:44 -0700, "NW_Pilot"
wrote in
Was that a mechanical tach?
I would write a report of your experience detailing the equipment
failures that occurred, and politely and respectfully send copies to
Cessna and Garmin. If you word it, so that it contains implicit
references to their exposure to civil liability, and express your
disappointment with the performance of their products, who knows how
they may respond. They may try to appease you with a perk or two. If
not, forward the report to AOPA, FSDO, and AvWeb. :-)
Old October 2nd 06, 10:08 PM posted to rec.aviation.piloting
NW_Pilot
wrote in
Larry, That's a great Idea and the Tach. was part of the G1000 system I am
not sure of the cause of the failure did not hang around in Beirut long
enough to find out the diagnostics.
See Photo
http://www.alexisparkinn.com/photoga...ch_Failure.jpg
Old October 2nd 06, 10:32 PM posted to rec.aviation.piloting
Mxsmanic
Larry Dighera writes:
Most software licenses disclaim all responsibility for everything
except an unreadable CD, although these disclaimers have never been
thoroughly tested in court, as far as I know.
Old October 3rd 06, 12:08 AM posted to rec.aviation.piloting
Neil Gould
Recently, Mxsmanic posted:
If not, forward the report to AOPA, FSDO, and AvWeb. :-)
The kind of software that you're using isn't likely to get you killed.
This is a different ballgame altogether.
Neil
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
