However, in this case, the fuel sensor failure caused a total system
failure, Actually, we do not know this. We can assume it, and the evidence is pretty strong, but there might have been other factors which we don't know. True. In addition to the fuel sensor "overload" (it didn't really fail -- it just sent info to the G1000 that made no sense), he also experienced a CO sensor failure, and (later) a tach failure. It's hard to say what caused what to happen, without more data. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Recently, Jay Honeck posted:
However, in this case, the fuel sensor failure caused a total system failure, Actually, we do not know this. We can assume it, and the evidence is pretty strong, but there might have been other factors which we don't know. True. In addition to the fuel sensor "overload" (it didn't really fail -- it just sent info to the G1000 that made no sense), he also experienced a CO sensor failure, and (later) a tach failure. It's hard to say what caused what to happen, without more data. I agree that we are in no position to determine the cause of the problems; they could be specific to this particular unit, or caused by damage during the installation of the ferry tank and other panel mounted items rather than the general design of the G1000. However, it still troubles me that Garmin told NW_Pilot that the system can experience similar problems during stalls and in slow flight. That *does* sound like the G1000 has some design issues that need sorting out. Neil |
Neil Gould wrote:
Recently, Jay Honeck posted: However, in this case, the fuel sensor failure caused a total system failure, Actually, we do not know this. We can assume it, and the evidence is pretty strong, but there might have been other factors which we don't know. True. In addition to the fuel sensor "overload" (it didn't really fail -- it just sent info to the G1000 that made no sense), he also experienced a CO sensor failure, and (later) a tach failure. It's hard to say what caused what to happen, without more data. I agree that we are in no position to determine the cause of the problems; they could be specific to this particular unit, or caused by damage during the installation of the ferry tank and other panel mounted items rather than the general design of the G1000. However, it still troubles me that Garmin told NW_Pilot that the system can experience similar problems during stalls and in slow flight. That *does* sound like the G1000 has some design issues that need sorting out. Neil I just went back and reread his account. ( I'm not flaming Steven but if you've read his emails before you know that his written words can often be difficult to read for content ) He said that the fuel readings went to red Xs ( as a properly designed system with a out of spec sensor should ) after flying ( and venting excess fuel for 7 hours ) Then he got a CO2 warning then a GPS-1 failure. It was after the GPS1 failure that the unit rebooted. Now failure of the fuel system I would not want a reboot for but in some situations failure of the primary navigation system may be grounds for a reboot depending on what failed. After the reboot completed he was missing readings like fuel and airspeeds. He mentions other errors but does not say what they were. He does not specifically say that the system rebooted again directly. He said in summery it was continually rebooting but I question that. Steven - Was it rebooting or did it just reboot once after the initial failure? He mentions that on downwind the fuel readings were working again but then failed again during turn to final. Did the sensors starting given valid information after the fuel burned off enough to have then in range and then fail again during the turn? Not sure. He does mention the G1000 rebooting again during his landing. Was this the second reboot? Did other instruments fail again? Too many questions and not enough information to say for sure. |
![]() "John Theune" wrote in message news:tLuUg.6710$vT1.5556@trndny03... Neil Gould wrote: Recently, Jay Honeck posted: However, in this case, the fuel sensor failure caused a total system failure, Actually, we do not know this. We can assume it, and the evidence is pretty strong, but there might have been other factors which we don't know. True. In addition to the fuel sensor "overload" (it didn't really fail -- it just sent info to the G1000 that made no sense), he also experienced a CO sensor failure, and (later) a tach failure. It's hard to say what caused what to happen, without more data. I agree that we are in no position to determine the cause of the problems; they could be specific to this particular unit, or caused by damage during the installation of the ferry tank and other panel mounted items rather than the general design of the G1000. However, it still troubles me that Garmin told NW_Pilot that the system can experience similar problems during stalls and in slow flight. That *does* sound like the G1000 has some design issues that need sorting out. Neil I just went back and reread his account. ( I'm not flaming Steven but if you've read his emails before you know that his written words can often be difficult to read for content ) He said that the fuel readings went to red Xs ( as a properly designed system with a out of spec sensor should ) after flying ( and venting excess fuel for 7 hours ) Then he got a CO2 warning then a GPS-1 failure. It was after the GPS1 failure that the unit rebooted. Now failure of the fuel system I would not want a reboot for but in some situations failure of the primary navigation system may be grounds for a reboot depending on what failed. After the reboot completed he was missing readings like fuel and airspeeds. He mentions other errors but does not say what they were. He does not specifically say that the system rebooted again directly. He said in summery it was continually rebooting but I question that. Steven - Was it rebooting or did it just reboot once after the initial failure? He mentions that on downwind the fuel readings were working again but then failed again during turn to final. Did the sensors starting given valid information after the fuel burned off enough to have then in range and then fail again during the turn? Not sure. He does mention the G1000 rebooting again during his landing. Was this the second reboot? Did other instruments fail again? Too many questions and not enough information to say for sure. Will solve this question, It had to many reboots to count! The unit would reboot then start showing items failing then reboot again start showing items failing then reboot again and again for a few hundred miles! After each reboot it took about 10 to 15 min to reboot again. The fuel sensors starting given valid information upon the reboot after landing and I still had Co2 and GPS Failure On Landing and airspeed was still a Red X! I only took note of the critical errors I tried my best to document them all but I am not superman I still needed to fly the plane. |
Recently, NW_Pilot posted:
"John Theune" wrote in message news:tLuUg.6710$vT1.5556@trndny03... Neil Gould wrote: Recently, Jay Honeck posted: However, in this case, the fuel sensor failure caused a total system failure, Actually, we do not know this. We can assume it, and the evidence is pretty strong, but there might have been other factors which we don't know. True. In addition to the fuel sensor "overload" (it didn't really fail -- it just sent info to the G1000 that made no sense), he also experienced a CO sensor failure, and (later) a tach failure. It's hard to say what caused what to happen, without more data. I agree that we are in no position to determine the cause of the problems; they could be specific to this particular unit, or caused by damage during the installation of the ferry tank and other panel mounted items rather than the general design of the G1000. However, it still troubles me that Garmin told NW_Pilot that the system can experience similar problems during stalls and in slow flight. That *does* sound like the G1000 has some design issues that need sorting out. Neil I just went back and reread his account. ( I'm not flaming Steven but if you've read his emails before you know that his written words can often be difficult to read for content ) He said that the fuel readings went to red Xs ( as a properly designed system with a out of spec sensor should ) after flying ( and venting excess fuel for 7 hours ) Then he got a CO2 warning then a GPS-1 failure. It was after the GPS1 failure that the unit rebooted. Now failure of the fuel system I would not want a reboot for but in some situations failure of the primary navigation system may be grounds for a reboot depending on what failed. After the reboot completed he was missing readings like fuel and airspeeds. He mentions other errors but does not say what they were. He does not specifically say that the system rebooted again directly. He said in summery it was continually rebooting but I question that. Steven - Was it rebooting or did it just reboot once after the initial failure? He mentions that on downwind the fuel readings were working again but then failed again during turn to final. Did the sensors starting given valid information after the fuel burned off enough to have then in range and then fail again during the turn? Not sure. He does mention the G1000 rebooting again during his landing. Was this the second reboot? Did other instruments fail again? Too many questions and not enough information to say for sure. Will solve this question, It had to many reboots to count! The unit would reboot then start showing items failing then reboot again start showing items failing then reboot again and again for a few hundred miles! After each reboot it took about 10 to 15 min to reboot again. The fuel sensors starting given valid information upon the reboot after landing and I still had Co2 and GPS Failure On Landing and airspeed was still a Red X! I only took note of the critical errors I tried my best to document them all but I am not superman I still needed to fly the plane. First of all, I think you did a superb job of handling all aspects of this fiasco. It has to be awfully distracting to have your controls constantly rebooting while you're trying determine whether you can get to safety. Your description of the installation quality of the aux tank and other items in the panel that could have been done better with a hacksaw and a drill makes me suspect that the G1000 was damaged during this process. The only thing that makes me think that the G1000 design may have problems is their telling you that the unit experiences problems in normal flight configurations. I'm curious about *which* problems, but that's only a curiosity; I'd have a hard time trusting the unit if there aren't backup gauges. Neil |
![]() "Neil Gould" wrote in message m... Recently, NW_Pilot posted: "John Theune" wrote in message news:tLuUg.6710$vT1.5556@trndny03... Neil Gould wrote: Recently, Jay Honeck posted: However, in this case, the fuel sensor failure caused a total system failure, Actually, we do not know this. We can assume it, and the evidence is pretty strong, but there might have been other factors which we don't know. True. In addition to the fuel sensor "overload" (it didn't really fail -- it just sent info to the G1000 that made no sense), he also experienced a CO sensor failure, and (later) a tach failure. It's hard to say what caused what to happen, without more data. I agree that we are in no position to determine the cause of the problems; they could be specific to this particular unit, or caused by damage during the installation of the ferry tank and other panel mounted items rather than the general design of the G1000. However, it still troubles me that Garmin told NW_Pilot that the system can experience similar problems during stalls and in slow flight. That *does* sound like the G1000 has some design issues that need sorting out. Neil I just went back and reread his account. ( I'm not flaming Steven but if you've read his emails before you know that his written words can often be difficult to read for content ) He said that the fuel readings went to red Xs ( as a properly designed system with a out of spec sensor should ) after flying ( and venting excess fuel for 7 hours ) Then he got a CO2 warning then a GPS-1 failure. It was after the GPS1 failure that the unit rebooted. Now failure of the fuel system I would not want a reboot for but in some situations failure of the primary navigation system may be grounds for a reboot depending on what failed. After the reboot completed he was missing readings like fuel and airspeeds. He mentions other errors but does not say what they were. He does not specifically say that the system rebooted again directly. He said in summery it was continually rebooting but I question that. Steven - Was it rebooting or did it just reboot once after the initial failure? He mentions that on downwind the fuel readings were working again but then failed again during turn to final. Did the sensors starting given valid information after the fuel burned off enough to have then in range and then fail again during the turn? Not sure. He does mention the G1000 rebooting again during his landing. Was this the second reboot? Did other instruments fail again? Too many questions and not enough information to say for sure. Will solve this question, It had to many reboots to count! The unit would reboot then start showing items failing then reboot again start showing items failing then reboot again and again for a few hundred miles! After each reboot it took about 10 to 15 min to reboot again. The fuel sensors starting given valid information upon the reboot after landing and I still had Co2 and GPS Failure On Landing and airspeed was still a Red X! I only took note of the critical errors I tried my best to document them all but I am not superman I still needed to fly the plane. First of all, I think you did a superb job of handling all aspects of this fiasco. It has to be awfully distracting to have your controls constantly rebooting while you're trying determine whether you can get to safety. Your description of the installation quality of the aux tank and other items in the panel that could have been done better with a hacksaw and a drill makes me suspect that the G1000 was damaged during this process. The only thing that makes me think that the G1000 design may have problems is their telling you that the unit experiences problems in normal flight configurations. I'm curious about *which* problems, but that's only a curiosity; I'd have a hard time trusting the unit if there aren't backup gauges. Neil After this Issue I think that there should be manual back up gauges and instruments for the required equipment under FAR 91.205! |
![]() "NW_Pilot" wrote in message . .. After this Issue I think that there should be manual back up gauges and instruments for the required equipment under FAR 91.205! If I were flying the kind of flying you are doing I'd invest in a 496. It would give you at lease some level of backup for almost everything in the plane except radio and engine instruments. |
On Tue, 3 Oct 2006 12:16:50 -0700, "NW_Pilot"
wrote in : ! I only took note of the critical errors I tried my best to document them all but I am not superman I still needed to fly the plane. Was it not equipped with an auto pilot? |
Larry Dighera schrieb:
am not superman I still needed to fly the plane. Was it not equipped with an auto pilot? Probably linked to the G1000... |
Stefan wrote:
Larry Dighera schrieb: am not superman I still needed to fly the plane. Was it not equipped with an auto pilot? Probably linked to the G1000... The 172 I flew with the G1000, it was linked. Besides, after that avionics failure, I'm not sure I'd trust anything else. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
