![]() Jack wrote: Tim Mara wrote: absolutely NOT........RainX causes rain to form tiny droplets which are then blown off by wind......you want no droplets at all...ever.. tim "Jack" wrote in message et... Bob Caldwell wrote: The bigger issue is with flying in rain. The highly polished, waxed finish will bead up with water droplets. The rougher surface will shed water without forming the really draggy (is that a word?) droplets. Same as if you waxed your windshield in your car, water beads up instead of sheeting off. So if and when you have to blast through that virga line the drop in performance will not be as severe. So, should we be using RainEx on our wings? But many do wax the wings -- and so get BIG drops -- do they not. Is the only answer to stay out of the rain and/or simply clean your wings with pure water, but never apply any protective finish? Jack Re Wax- Some airfoils don't want to be polished and waxed. The Wortman FX 67-150/170 series is an example of this. These like a little(400grit at 45 degrees) roughness. When my PIK climb started to drop off, I'd give it a bit of a scuff. I washed with dish soap and wiped dry without a lot of rinsing. Soap wetted out rain and it tolarated rain much better. Otherwise, when the rain drop hits the canopy- put the gear down. hard to keep looking nice when doing this though. UH |
Hank's experience echoes mine. I kept my LS-3 (same airfoil as PIK-20B;
also Mosquito, Nimbus 2, etc.) at 400 grit most of the time and it did seem to make a difference in the rain. Keeping it clean was no problem. Water worked for most things. And for stubborn bugs, just sand them off. ![]() Chip Bearden ASW 24 "JB" |
Hank's experience echoes mine. I kept my LS-3 (same airfoil as PIK-20B; also Mosquito, Nimbus 2, etc.) at 400 grit most of the time and it did seem to make a difference in the rain. Keeping it clean was no problem. Water worked for most things. And for stubborn bugs, just sand them off. ![]() Cheez, all this talk about rain. Chip, you need to come out West and fly in the sun! It's more fun, and it eliminates sanding time. Waxing time might increase, but you are rewarded with a shiny glider. And one more thing: if you do fly in the rain out West, that's because there is good lift there. Saved myself quite a few times by thermalling on the edge of a rain shaft. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Osan’s 51st Fighter Wing to get its own coin | Otis Willie | Military Aviation | 0 | April 5th 04 10:44 PM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
