On Thu, 5 Oct 2006 00:58:54 -0700, "NW_Pilot"
wrote in : So when the Garmin system went down, other than HF Communications provided by a portable transceiver, and the flight controls, the only other functional instruments and operable systems you had were the OAT thermometer, EGT, magnetic compass, attitude indicator, altimeter, intermittent tachometer and airspeed indicator? No navigation equipment, auto pilot, VHF communications, fuel gages, engine oil pressure nor temperature gages? Have I finally got it right? When the system went down the only things I had was My Portable GPS, HF Com, Portable VHF Com, Steam Attitude Indicator, Steam Airspeed Indicator, Steam Altimeter, Whiskey Compass! Every thing else was tied to the G1000 and was useless or not to be trusted as accurate in that situation. They don't even have a slip/skid ball in the thing when the G1000 goes blink that's intergraded also! Thanks for the information. Can you tell me more about the overpressure in the wing tank(s), and the fuel entering the pitot-static system causing the loss of the airspeed indicator? Here's all I have: Apparently the added pressure in the fuel tanks pushed the floats in the fuel tank up, which got the Garmin confused, causing an error that made it reboot. The loss of the airspeed indicator was caused by fuel vapors entering the pitot tube -- which also caused the CO2 detector failure! Has anyone figured out what happened to cause fuel to enter the pitot-static system? Have you any idea of the magnitude of the added pressure you mentioned? Where there rubber bladders in the wing tanks? |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
