Robert M. Gary writes:
I wish more companies had such great service. Great service is a good thing, but a better thing is equipment that doesn't need service to begin with. Having great service doesn't help when your equipment fails in flight. -- Transpose mxsmanic and gmail to reach me by e-mail. |
You CLEARLY don't fly airplanes.
EVERYTHING breaks "Mxsmanic" wrote in message ... Robert M. Gary writes: I wish more companies had such great service. Great service is a good thing, but a better thing is equipment that doesn't need service to begin with. Having great service doesn't help when your equipment fails in flight. -- Transpose mxsmanic and gmail to reach me by e-mail. |
karl gruber writes:
You CLEARLY don't fly airplanes. I have worked with computers. EVERYTHING breaks Only computers break in certain ways--ways that are extremely dangerous for safety-of-life applications. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... karl gruber writes: You CLEARLY don't fly airplanes. I have worked with computers. And you obviously weren't very good at it if all you make a month is $647. |
![]() Mxsmanic wrote: Robert M. Gary writes: I wish more companies had such great service. Great service is a good thing, but a better thing is equipment that doesn't need service to begin with. Having great service doesn't help when your equipment fails in flight. If you've discovered a way to produce 100% defect free products let me know. Would you come work for me? I'll pay you $2.5m each year we are 100% defect free. -Robert |
The key is REDUNDANCY. Lets say computer one has a probability of
breaking of .01 (1 out of 100). Computer B has a probability of breaking of .01. If their probabilities of breaking are independent of each other then the probability of BOTH breaking is .0001 (1 in 10,000). Perhaps each G1000 install should be accompanied by a totally seperate GPS/Com, much like it has totally seperate AI, airspeed and altimeter. Robert M. Gary wrote: Mxsmanic wrote: Robert M. Gary writes: I wish more companies had such great service. Great service is a good thing, but a better thing is equipment that doesn't need service to begin with. Having great service doesn't help when your equipment fails in flight. If you've discovered a way to produce 100% defect free products let me know. Would you come work for me? I'll pay you $2.5m each year we are 100% defect free. -Robert |
![]() Doug wrote: The key is REDUNDANCY. Lets say computer one has a probability of breaking of .01 (1 out of 100). Computer B has a probability of breaking of .01. If their probabilities of breaking are independent of each other then the probability of BOTH breaking is .0001 (1 in 10,000). Perhaps each G1000 install should be accompanied by a totally seperate GPS/Com, much like it has totally seperate AI, airspeed and altimeter. It does. There are two GPS units, with two antenna. The antenna are located in the base of the comm antennas. (some students get confused by the GPS antenna behind those, but its just for XM weather). Before take off part of the take off checklist is to go to the aux page and see the signal strength for both GPS units. I've had the GPS fail in flight and only noticed a "ALERT" pop up, but no change in service. -Robert, G1000 CFII |
On 6 Oct 2006 10:08:22 -0700, "Robert M. Gary"
wrote: It does. There are two GPS units, with two antenna. The antenna are located in the base of the comm antennas. (some students get confused by the GPS antenna behind those, but its just for XM weather). Actually, on the newer installs the LH antenna fin is an XM/COM/GPS-in-one. RH fin is just COM/GPS and the only other protuberance on the upper center fuselage is the OAT probe. |
Doug writes:
The key is REDUNDANCY. Lets say computer one has a probability of breaking of .01 (1 out of 100). Computer B has a probability of breaking of .01. If their probabilities of breaking are independent of each other then the probability of BOTH breaking is .0001 (1 in 10,000). The problem is common-mode failures. If one computer has a software bug, the other one will have it, too, unless the two computers contain different software. So just duplicating parts won't necessarily help. You just end up with two G1000's rebooting instead of one. -- Transpose mxsmanic and gmail to reach me by e-mail. |
If you've discovered a way to produce 100% defect free products let me know. Would you come work for me? I'll pay you $2.5m each year we are 100% defect free. That's about what it might cost, depending on the project. But just because it is expensive doesn't mean it can be sacrificed for safety-of-life applications. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Garmin GpsMap 396 - Flight Test #2 | Mike Spera | Owning | 17 | July 9th 06 01:21 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
