1) All avionics software implements internal isolation to prevent one
part of the system from taking down another part. 2) A faulty fuel reading cannot cause the system to reboot. In addition to testing every possible faulty fuel value, I've tested every combination of faulty sensor readings related to this thread and am unable to get anything out of the ordinary to happen. The picture of the fuel sensor with the red X is correct behavior when a gauge is fauly or giving erroneous data. 3) When the system reboots due to a software error, a very obvious message with a very obvious color is displayed on the screen prior to the reboot. Was this seen? I have seen no mention of it. 4) FYI to a few: the CO message is indicating an error in the detector, not CO in the cabin. What was going on with the second display? Was the "Initializing System" message being displayed each time it 'rebooted'? During the 15minute intervals between reboots, how operational was the system? I won't delve into the actual debate issues of whether to go glass, realtime reliability vs. features demanded, benefits vs. risk of various situational awareness methods, or anything like that. I'm just trying to get the facts straight. No software engineer would claim a flawless system, but the facts so far do not allow for a simple answer such as the fuel gauge or airspeed indication being the only cause. Something very strange had to be going with where that escaping fuel was going. If it was affecting three gauges (airspeed, co detector, fuel) in a measurable way, who knows what it could have been doing to less obvious internal wirings of the aircraft. I've never heard of a report of a continuously rebooting system, and there are a lot out there. The somewhat drastic customizations and the newness of the aircraft add to suspicion. That said, there's no excuse for a failure, wherever in the aircraft that failure is determined to be. PS: I appreciate the balanced feedback and analysis of most of this group. Don't feed the 20% trolls. |
![]() "g1000_eng" wrote in message ups.com... 1) All avionics software implements internal isolation to prevent one part of the system from taking down another part. 2) A faulty fuel reading cannot cause the system to reboot. In addition to testing every possible faulty fuel value, I've tested every combination of faulty sensor readings related to this thread and am unable to get anything out of the ordinary to happen. The picture of the fuel sensor with the red X is correct behavior when a gauge is fauly or giving erroneous data. 3) When the system reboots due to a software error, a very obvious message with a very obvious color is displayed on the screen prior to the reboot. Was this seen? I have seen no mention of it. 4) FYI to a few: the CO message is indicating an error in the detector, not CO in the cabin. What was going on with the second display? Was the "Initializing System" message being displayed each time it 'rebooted'? During the 15minute intervals between reboots, how operational was the system? I won't delve into the actual debate issues of whether to go glass, realtime reliability vs. features demanded, benefits vs. risk of various situational awareness methods, or anything like that. I'm just trying to get the facts straight. No software engineer would claim a flawless system, but the facts so far do not allow for a simple answer such as the fuel gauge or airspeed indication being the only cause. Something very strange had to be going with where that escaping fuel was going. If it was affecting three gauges (airspeed, co detector, fuel) in a measurable way, who knows what it could have been doing to less obvious internal wirings of the aircraft. I've never heard of a report of a continuously rebooting system, and there are a lot out there. The somewhat drastic customizations and the newness of the aircraft add to suspicion. That said, there's no excuse for a failure, wherever in the aircraft that failure is determined to be. PS: I appreciate the balanced feedback and analysis of most of this group. Don't feed the 20% trolls. Do you expect me to believe you are a Garmin Engineer using a hotmail e-mail addy and a 1 time poster under this username :-) It's kind of funny once the aircraft was on the ground for 24 hours and there was no further fuel venting and every thing dried up the G1000 worked flawlessly until the tach failed some hours later during the flight because of a Bad Sensor "not confirmed yet just an educated guess" There was no alert about the reboot it was like some one just cut the power to the displays then restored power the system did a standard reboot things started to fail then it would reboot again. I will be talking with the customer again upon delivery of future aircraft and will report the avionics tech's findings on that airplane that is if they have anyone that is certified and has the knowledge to work on and diagnose the G1000 over there! |
"NW_Pilot" wrote:
"g1000_eng" wrote in message ups.com... 1) All avionics software implements internal isolation to prevent one part of the system from taking down another part. 2) A faulty fuel reading cannot cause the system to reboot. In addition to testing every possible faulty fuel value, I've tested every combination of faulty sensor readings related to this thread and am unable to get anything out of the ordinary to happen. The picture of the fuel sensor with the red X is correct behavior when a gauge is fauly or giving erroneous data. [ ... ] Do you expect me to believe you are a Garmin Engineer using a hotmail e-mail addy and a 1 time poster under this username :-) Just FYI, the poster used Google Groups, which tacks on a header indicating the IP address of the poster; in this case that header is: Injection-Info: e3g2000cwe.googlegroups.com; posting-host=69.247.168.62; posting-account=YoF8rQ0AAABFBsk62Tpp2wBJ_FD_CVG_ I used the "dig" utility on one of my Linux machines to see what host name(s) might be associated with that 69.247.168.62 address. It came up with this: c-69-247-168-62.hsd1.ks.comcast.net. Looks like a Comcast account in Kansas, based on my understanding of how ISPs like Comcast assign host names to IP addresses. Garmin is headquartered in Kansas. So the possibility can't be immediately ruled out based on where the poster is posting from. |
Jim Logajan wrote:
"NW_Pilot" wrote: "g1000_eng" wrote in message ups.com... 1) All avionics software implements internal isolation to prevent one part of the system from taking down another part. 2) A faulty fuel reading cannot cause the system to reboot. In addition to testing every possible faulty fuel value, I've tested every combination of faulty sensor readings related to this thread and am unable to get anything out of the ordinary to happen. The picture of the fuel sensor with the red X is correct behavior when a gauge is fauly or giving erroneous data. [ ... ] Do you expect me to believe you are a Garmin Engineer using a hotmail e-mail addy and a 1 time poster under this username :-) Just FYI, the poster used Google Groups, which tacks on a header indicating the IP address of the poster; in this case that header is: Injection-Info: e3g2000cwe.googlegroups.com; posting-host=69.247.168.62; posting-account=YoF8rQ0AAABFBsk62Tpp2wBJ_FD_CVG_ I used the "dig" utility on one of my Linux machines to see what host name(s) might be associated with that 69.247.168.62 address. It came up with this: c-69-247-168-62.hsd1.ks.comcast.net. Looks like a Comcast account in Kansas, based on my understanding of how ISPs like Comcast assign host names to IP addresses. Garmin is headquartered in Kansas. So the possibility can't be immediately ruled out based on where the poster is posting from. And I would not expect a engineer from Garmin to use his real name and email address because as a engineer I doubt he is authorized to speak for the company. That does not stop him from commenting in a much more knowledgeable way then a lot of the posts about this issue. |
![]() "John Theune" wrote in message news:M6jVg.8501$pS3.1688@trnddc01... Snip And I would not expect a engineer from Garmin to use his real name and email address because as a engineer I doubt he is authorized to speak for the company. That does not stop him from commenting in a much more knowledgeable way then a lot of the posts about this issue. As I said in my last message If Garmin would like more info from me I am instructed to tell them to put it on paper and place the request in the mail! |
John Theune writes:
And I would not expect a engineer from Garmin to use his real name and email address because as a engineer I doubt he is authorized to speak for the company. I wouldn't expect him to use a pseudonym that creates the impression that he is an engineer, either. Most companies have policies that prohibit such behavior, because of liability issues. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Jim Logajan" wrote in message .. . "NW_Pilot" wrote: "g1000_eng" wrote in message ups.com... 1) All avionics software implements internal isolation to prevent one part of the system from taking down another part. 2) A faulty fuel reading cannot cause the system to reboot. In addition to testing every possible faulty fuel value, I've tested every combination of faulty sensor readings related to this thread and am unable to get anything out of the ordinary to happen. The picture of the fuel sensor with the red X is correct behavior when a gauge is fauly or giving erroneous data. [ ... ] Do you expect me to believe you are a Garmin Engineer using a hotmail e-mail addy and a 1 time poster under this username :-) Just FYI, the poster used Google Groups, which tacks on a header indicating the IP address of the poster; in this case that header is: Injection-Info: e3g2000cwe.googlegroups.com; posting-host=69.247.168.62; posting-account=YoF8rQ0AAABFBsk62Tpp2wBJ_FD_CVG_ I used the "dig" utility on one of my Linux machines to see what host name(s) might be associated with that 69.247.168.62 address. It came up with this: c-69-247-168-62.hsd1.ks.comcast.net. Looks like a Comcast account in Kansas, based on my understanding of how ISPs like Comcast assign host names to IP addresses. Garmin is headquartered in Kansas. So the possibility can't be immediately ruled out based on where the poster is posting from. Well, this is Usenet and I think that if it was really a garmin rep/engineer why would they hide themselves with a hotmail account! It will take a lot for Garmin to win my opinion and respect of them and their products/systems if ever. Due to maybe a software flaw in their system it could have taken my life or someone else's and probably will take a someones in the future lets hope it's not mine. I will still fly the G1000 for customers that hire me me to fly them I will Just be more cautious of them! Would I take my family or friends in one IFR conditions no way not ever!! Not until Garmin/Cessna can prove to me that the G1000 will operate for 100+ hours without some sort of bug or failure!! Asking me to place my family in one in IFR conditions would be the same as asking me to put a gun to their heads and play Russian Roulette with them and I take my family in IFR conditions in my cessna 150! I have also been in contacted by an aviation publication about my experience on the G1000 not sure if I want to do the interview or not? I know I should just to expose that there maybe a potential fatal bug/flaw in the system! If Garmin would like more info from me I am instructed to tell them to put it on paper and place the request in the mail! Now I am done talking about the G1000 and it's problems, Lets all talk about other aviation related things! |
on the G1000 not sure if I want to do the interview or not? I know I should just to expose that there maybe a potential fatal bug/flaw in the system! I think you should. But... be sure it's a respected publication with even handed coverage, and be sure you have all your facts right as well as you can, all your speculations identified as such, and all your ducks in a row. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Recently, NW_Pilot posted:
Well, this is Usenet and I think that if it was really a garmin rep/engineer why would they hide themselves with a hotmail account! It will take a lot for Garmin to win my opinion and respect of them and their products/systems if ever. Due to maybe a software flaw in their system it could have taken my life or someone else's and probably will take a someones in the future lets hope it's not mine. Your experience sounds to me more like a hardware problem than software. For example, the continuous rebooting may be caused by an intermittent ground connection to the G1000, causing its power to switch on and off. Given that the panel was "hacked" by the same outfit that made the poorly kludged aux tank system (a system that clearly does have a major design flaw) and gave you the bogus operating instructions, I am far more suspicious of them than Garmin. The G1000 was only the most obvious indicator of a major problem somewhere in the aircraft. I have also been in contacted by an aviation publication about my experience on the G1000 not sure if I want to do the interview or not? I know I should just to expose that there maybe a potential fatal bug/flaw in the system! If it were me, I wouldn't do such an interview, as there is no conclusion about the real cause of the problems you experienced. To point the finger on the basis of pure speculation would leave you vulnerable. As can be seen from the discussion that this has generated, inuendo can go a long way toward creating a lasting negative impression that has no basis in fact -- yet. Neil |
On Fri, 06 Oct 2006 09:17:52 GMT, "Neil Gould"
wrote in : Given that the panel was "hacked" by the same outfit that made the poorly kludged aux tank system (a system that clearly does have a major design flaw) and gave you the bogus operating instructions, I am far more suspicious of them than Garmin. That is reasonable. With the fact that Mr. Rhine was operating portable equipment on the flight, there is potential for some interaction there too. And it's reasonable that a small metal shaving produced during the Garmin installation may have been dancing on a circuit board someplace. Clearly we don't have enough facts to reliably diagnose the cause of the infinite reboot, but I am thankful to be made aware by Mr. Rhine's experience of the utterly unacceptable situation that is caused when the Garmin system becomes inoperative. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
