Creating a swaged hole in the bottom of a fuel tank.
Old October 6th 06, 12:15 PM posted to rec.aviation.homebuilt
Ebby
Default Creating a swaged hole in the bottom of a fuel tank.
I'm thinking with .090" to stretch the hole would only be larger to accept a
larger bolt for stretching the swedge. Perhaps 3/8" instead of 1/4". I
have some experimenting to do.
Ebby
"Ernest Christley" wrote in message
Ebby wrote:
Ernest,
I think I understand your description. I am going to send you a picture
of how I interpret your instructions. To me it seems like the tool you
describe is similar to a radio chassis punch. Is that correct? Instead
of punching a hole, your device pulls a slug of aluminum through a hole
in the plywood 2x4 side of the aluminum.
Also are you saying that once the tool and aluminum are all clamped
together the hole dug out of the hole saw will press through the aluminum
sheet creating the swaged hole? I do have to mention that the swage will
result in a flanged hole that I can use to weld my finger strainer and
sight gauge fittings. Should a hole larger than the 1/4" hole you
mentioned be drilled in the aluminum first so the male swage block will
pull down through easier to create the flange.
I'm all ears to solve this fabrication problem.
Ebby
I think I answered you with direct email, but for the greater audience....
I'd use the "chasis punch", as you describe it, to make the swage and then
use a step drill to cut the hole. That will help avoid unwanted cracks
around the hole from the stretching. You can make a larger hole, but
remember that you're stretching the aluminum. Keep the hole as small as
possible.
Ebby wrote:
Dear All,
I am starting to build my center section fuel tank and need information
about how to swage holes in the bottom of the tank so that I can edge
weld the six fittings specified in the plans. Four of the fittings are
finger strainers and one is for the sight gauge. There is one more
hole on the top for the filler. As there are only six holes in three
different diameters, I was thinking about doing it using simple hand
techniques rather than expensive tooling.
Here is my idea. The tank is .090" 5052. I planned on drilling holes
(.180+flange dimension) undersize in the aluminum. Then centering the
holes over 3/8" steel plate with holes .180 oversize, then use a
polyethelene bossing hammer to swage the edge of the hole into the
female die hole. The holes in the female die would have the edges
relieved to accomodate a bend radius. It might be time consuming but
educational.
Any advice or previous experience to share
A piece of 1/2" plywood and a couple chunks of 2x4. Tack plywood to one
of the blocks and use a small hole saw with a 1/4" centering bit to cut
the inside diameter of the swage. The piece that you dig from the hole
saw goes on one side of the aluminum. Use a bigger hole saw, centering
on the same 1/4" hole, cut the outside diameter of the swage, then drill
the 1/4" hole all the way through the block. Drill a 1/4" hole through
the other block. Drill a 1/4" hole where the swage will go.
Thread a sufficiently long bolt through a fender washer, the block with
the plywood attached, the aluminum, the piece you dug out of the small
hole saw, the other 2x4 block, then another fender washer. Spin a nut
down to extrude the swage.
I don't know if this will work on .090, but I've used this technique on
thinner material.
Old October 16th 06, 12:31 AM posted to rec.aviation.homebuilt
Ebby
If anyone is interested, I worked out a solution to the swage problem.
Thanks to input from three different newsgroups I successfully am now able
to swage holes for my aluminum fuel tank. To view the results go to the
metalworking.com dropbox and look for the files called "SwageDie". I posted
them earlier today.
Thanks for the help.
Ebby
"Ebby" wrote in message
a larger bolt for stretching the swedge. Perhaps 3/8" instead of 1/4". I
Ebby
Ebby wrote:
Ernest,
aluminum sheet creating the swaged hole? I do have to mention that the
swage will result in a flanged hole that I can use to weld my finger
strainer and sight gauge fittings. Should a hole larger than the 1/4"
hole you mentioned be drilled in the aluminum first so the male swage
block will pull down through easier to create the flange.
Ebby
audience.... I'd use the "chasis punch", as you describe it, to make the
swage and then use a step drill to cut the hole. That will help avoid
unwanted cracks around the hole from the stretching. You can make a
larger hole, but remember that you're stretching the aluminum. Keep the
hole as small as possible.
Ebby wrote:
Dear All,
information about how to swage holes in the bottom of the tank so that
I can edge weld the six fittings specified in the plans. Four of the
fittings are finger strainers and one is for the sight gauge. There
is one more hole on the top for the filler. As there are only six
holes in three different diameters, I was thinking about doing it
using simple hand techniques rather than expensive tooling.
educational.
one of the blocks and use a small hole saw with a 1/4" centering bit to
cut the inside diameter of the swage. The piece that you dig from the
hole saw goes on one side of the aluminum. Use a bigger hole saw,
centering on the same 1/4" hole, cut the outside diameter of the swage,
then drill the 1/4" hole all the way through the block. Drill a 1/4"
hole through the other block. Drill a 1/4" hole where the swage will
go.
thinner material.
Old October 16th 06, 09:28 PM posted to rec.aviation.homebuilt
Morgans[_2_]
If anyone is interested, I worked out a solution to the swage problem. Thanks
to input from three different newsgroups I successfully am now able to swage
them earlier today.
Good Job!
The journey is half the fun, right? g
Jim in NC
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 06:13 PM
"Tanks on both" checklist item Koopas Ly Piloting 46 December 12th 03 03:42 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
